GL553VW REV 2.0 No display
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    L800 P_CHG_LX_30 - 8.38V
    L80-05 +VCCSA13 -1.053
    2 +1.35VO_VGA -0V
    1 +VCCGT 0V
    2 +1.2VO_DDR -1.215V
    1 VRM_PWRGD 3.3V
    hope someone can guide me if my processor is already dead?
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Re: GL553VW REV 2.0 No display
    2 +1.35VO_VGA -0V
    1 +VCCGT 0V
    1 VRM_PWRGD 3.3V
    Im missing my voltage at DRAMRST
    also I dont have my 32khz
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      Me_ac_present- 3.2v
      suswarn#/suspwrdnack 0v
      pm_rsmrst# 3.2v
      pm_susc# -3.3v
      pm_susb# 3.3v
      sys_pwrok 3.2v
      • kalilinux25
        • Mar 2018
        • 2089
        • ZAMBOANGA SIBUGAY
        so hard to test some resistors beacuse I dont have access to a schematic
        • kalilinux25
          • Mar 2018
          • 2089
          • ZAMBOANGA SIBUGAY
          hope someone can help
          • lapfix
            • Mar 2020
            • 2720
            • my workshop
            Same here , but ...all voltage are present expect
            +VCCGT 0V
            and Dramrst and CPUdramrst
            Dramrst at pin 108 ram socket = 0.060v
            Trace this line until R203 470 OHM , resistance are ok and got 1.2v from one side and 0.060v from other ....No short to GND..
            Try official bios and one from SMDFlea but same issue.
            PLT-rst are present
            present too : all-sys pwrgood / vrm pwrgood / Pm- pwrok / vccgt pg / syspwr-ec .
            What to check else!!
            thank you
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              VCCGT at 0V is not something to bother. On many boards it doesnt rise(If you test with dso, you will get a pulse for a fraction of second). However, when dramrst# is pulled low, there is no question of VCCGT rising. Dramrst# is controlled by cpu and the resistor is fine as per your observation. Bios could be a factor but you have already ruled that out.
              So in my opinion you are staring at cpu fault.
              • myth77
                • Feb 2017
                • 380
                • Croatia
                Boardview attached..with value of resistors. This boardview is a little strange...when you open it you have to flip board horizontally to show you the correct pins on board.
                • usyusy
                  • Sep 2021
                  • 171
                  • Pakistan
                  under microscope, traces could also be checked, if they are missing on somewhere
