RAZER BLADE advanced 2022 rtx 3080 no post/display rz09-0409cec3
  • pepebmx
    • Aug 2020
    • 11
    • Argentina
    Hi guys, i just got a brand new razer blade 15 rz09-0409cec3 that turns on keyboard light, fans but no display at all. I managed to get bios bin file from razer but im not sure if this chip is THE bios chip. It is a Gigadevice 25q64cig (Uee704 Aj2103) or something like that. I believe that is the bios chip, I uploaded photos from all of them in case i am wrong. https://drive.google.com/drive/folde...9M?usp=sharing If its ok i will remove it, read it with ch341A , backup and share bios file here so you can check what is wrong. I will try to flahs bios bin file from razer too. Will upload all together once im sure its the correct one. Wich program do you recommend to read it ?
    Thank u a lot!
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3634
    • slovakia
    Re: RAZER BLADE advanced 2022 rtx 3080 no post/display rz09-0409cec3
    i have this laptop on my bench few weeks ago. bad bios update. after flash dump from vendor. all ok
    • pepebmx
      • Aug 2020
      • 11
      • Argentina
      Could you give me some guidence? Im not able to read the chip with ch341
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3634
        • slovakia
        i think it is 1,8V ic. check by datasheet if u need adapter
        • eeenojhshe
          • Oct 2022
          • 5
          Hey - I’m trying to figure out the same thing. Which chip is it for the 16mb bios file?
          • eeenojhshe
            • Oct 2022
            • 5
            The only ic I haven't been able to dump is the Winbond W25R256JVEQ so I guess that must be it? It's almost flush with the motherboard though and is impossible to get clips on.
            If that is the bios chip - any tips on how to read/ write without desoldering?
            • Sephir0th
              • Oct 2020
              • 1289
              Dunno what's the question here. The datasheet of the Chips will give the answers. Top marking of the flash in question is W25R256JVEQ, so 256 / 8 = 32MB. It is WSON package so you have to put wires, or even better, to solder it on a suitable programming board.
              FairRepair on YouTube
              • eeenojhshe
                • Oct 2022
                • 5
                Thanks @sephir0th - Still new to hardware. Was looking for someone more experienced to make sure I’m on the right track. No real question I guess. Appreciate ya
                • mon2
                  • Dec 2019
                  • 14781
                  The best solution is to carefully remove the flash chip, solder it onto a small smd to dip bridge board. Then perform your reflashing.
                  Do you have a flash programmer? Which one?
                  Be careful to confirm the peak VCC pin voltage of your tool and the target flash device before proceeding. Else you can kill the flash memory device.
                  Ps: where in Ontario?
                  • eeenojhshe
                    • Oct 2022
                    • 5
                    Thanks mon2.
                    I’m in Toronto. I have an EZP2019+ that works at 3.3V, and a not volt modded ch341a. All good with pin alignment and stuff; being extra careful to not fry anything. Think I’ll be fine as long as I can find a tech somewhere willing to help with the soldering (open to suggestions if you know of anyone)
                    • mon2
                      • Dec 2019
                      • 14781
                      Recommend to phone around your area to ask about low level board repair techs - most likely cell phone repair techs.
                      If you are near Mississauga - contact via PM -> @mferna14.
                      • eeenojhshe
                        • Oct 2022
                        • 5
                        Appreciate the help! DM’d mferna , and have been calling around to see if any shops can do it
                        • theplop
                          Razer blade 2022, 14" PI480 wont boot to OS, freezes
                          by theplop
                          Razer blade 2022, 14" PI480, Ryzen 6900HX, 16gb ram
                          I picked up a Razer blade 14" (2022) from a friend who said it "overheated" and he replaced one of the fans. He gave up on it as windows wouldn't work/re-install. He gave it to me, and i've been working on getting linux on it. Installing Mint i was able to get about 1/4 through the installer before it froze. Now i can't even get the installer to boot. I am met with a kernel panic.... sometimes. Sometimes it just hangs on the boot sequence.
                          I've run memtest quite a few times, and more often then not...
                          03-20-2025, 06:42 PM
                        • 0xx
                          2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
                          by 0xx
                          Hi folks,
                          My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
                          What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
                          I assumed that Windows Update was interrupted due to closing...
                          09-14-2025, 03:46 PM
                        • Rangry
                          Razer Blade 15 2022, No internal display, Error Code 43
                          by Rangry
                          Hi! I have a Razer Blade 15 2022, with a RTX 3060.
                          One day, while using Linux, the internal display suddenly stopped working.
                          On Windows, it says that the internal GPU has stopped working (with error code 43).
                          I have tried removing the coin cell and the battery, and replacing the RAM, with no success on fixing anything.
                          I'm looking for directions to fix this problem, and, first of all, I would like to be able to access the BIOS and change some settings (which is currently impossible as it is always shown on the internal display). There is a setting...
                          05-29-2025, 07:01 AM
                        • Pawel Borowski
                          Solving Razer Blade 14 (2022) RZ09-0427 from scrap.
                          by Pawel Borowski
                          Hi folks,
                          I want to solve a Razer Blade 14 (2022) RZ09-0427 with Ryzen 9 6900HX and RTX 3070Ti from scrap, and I need your help with the diagnosis.
                          I have checked (I hope) all the voltage rails and found no shorts to GND and B+ except for the CPU VDDCR_SR rail (see the photo), which is near zero ohms to GND.
                          When plugged to PS, the laptop charges the battery, and after pressing start, it supplies voltage to all voltage rails except for CPU VDDCR_SR one and, of course, the dGPU, nothing more.
                          I have no experience in this type of repair, so please let me know if the low resistance...
                          05-05-2025, 07:37 AM
                        • istvanszasz99
                          Razer Blade 15 (2022) RZ09-0421 BIOS Modding / editing help request
                          by istvanszasz99
                          Product Name: Razer Blade 15 (2022)
                          Product ID: RZ09-0421
                          Motherboard: CH580
                          BIOS Versions I work with: 2.02 & 2.06
                          Bios File Size: 32,768 KB
                          Dear Forum Readers!
                          I'm looking for a BIOS modder or anyone with experience who would give me suggestions about my razer blade's BIOS settings.
                          I can view and edit the content of the BIOS .bin file with AMIBCP BIOS editor.
                          The BIOS files I'm working with are from badcaps.net and those are CLEAN BIOS files (anyone can find it with the search string: RZ09-0421).
                          !!! MY RAZER BLADE...
                          Yesterday, 05:52 PM
