Dell 7240 Laptop HDD led Continously blinking
  • sureshbobby
    • Mar 2015
    • 137
    • India
    Dear Friends,
    I have issue with dell latitude 7240 in which Laptop hdd led is continously blinking. Please help
  • ahmarzo
    Hp 15-cs laptop 5 times dc jack blinking white
    by ahmarzo
    I have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
    First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
    Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
    But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery...
    12-28-2024, 04:46 AM
  • mikey5791
    Dell laptop model PP24L won't start from ac adapter
    by mikey5791
    Dear all,
    Bought this used Dell laptop PP24L(studio 1435) in Jan 2022. It was running smooth on 64 bit Windows 7 pro from processor Intel core Duo T6400@2Ghz with 2GB RAM. The laptop battery was charging and working fine until few months back the opening screen will display something like "replacing the battery warning", press F1 to continue. Normally i press F1, the laptop will proceed to Windows and i can use as normal.
    But last week, after i pressed F1, the laptop just shut down. I suspected the laptop battery is dead. So i pulled out the battery and...
    03-24-2023, 09:06 PM
  • Mots06
    Old Dell E5400 Laptop ( Purchased in the year 2008)
    by Mots06
    Hi, I'm unable to find the motherboard number (PPID number) or the board view for this old laptop. My laptop won't start, and when I enter the serial number on the Dell website, it says the number is invalid. The sticker on the bottom is unreadable because it has faded over time. Unfortunately, I'm unable to start the laptop to use the power cell or explore other options.I needed the CMOS Cell & it also seems the Laptop will not start now because of the power switch issue, which is yet to be detected.
    Today, 01:56 AM
  • Bowline
    by Bowline
    06-11-2025, 10:13 AM
  • Calidebear
    Dell 3537 laptop doesn't boot without embedded display.
    by Calidebear
    I have this laptop for a long time, still it does it's job, like browsing, word , excel. Two years back laptop Hinge base broken but now it's damaging other parts of laptop so I tried to totally remove the embedded display cable from laptop and tried to boot only with external display monitor, but it doesn't boot and gives single beeps. BIOS checking the embedded display to be connected.
    So checked the schematics to bypass this issue.
    Found something but I don't know how to read this schematics.
    Dell 3537 mobo 9982p rev 3
    Schematics attached,...
    03-29-2025, 11:37 AM
