820-2915-A Wont power on with battery connected
  • beogeek
    • Apr 2018
    • 97
    • Serbia
    #61
    Re: 820-2915-A Wont power on with battery connected
    I'll report back once I get my hands on a replacement, I'm hoping it's the battery as this puzzle as you call it was definitely dialed up to 11 on the difficulty scale!
    • macattack600
      • Aug 2011
      • 97
      Order Apple original make sure your using original OEM Battery and Charger before you dig deep!
      Knock off cause alot of problems. In system profiler it identifies chargers and batteries , the chips are proprietary made in them.
      • beogeek
        • Apr 2018
        • 97
        • Serbia
        #63
        Knock off cause a ton of problems in system profiler it identifies chargers and batteries , the chips are proprietary made in them.
        Yes, I'm aware of that, the problem is finding an original, even the local authorized apple shop doesn't have them nor will it as according to them apple has discontinued support for these models so they no longer stock or manufacture these batteries...
        • mon2
          • Dec 2019
          • 13839
          See attached. Confirm the highlighted set of components.
          This is for the PPVBAT_G3H_CHGR_R.
          Measure the voltage @ CHGR_CSO_R_N (R7050, pin # 1&3).
          Measure the voltage @ CHGR_CSO_R_P (R7050, pin # 2&4).
          Then confirm the linked parts are as per the schematic. Check the resistance of the resistors.
          What is the voltage
          @ R7051, pin # 1 ? (with battery)
          @ R7052, pin # 1 ? (with battery)
          • beogeek
            • Apr 2018
            • 97
            • Serbia
            #65
            All readings are done with bat only.
            R7050 12.26v on all 1-4, resistance 0.02Ω
            R7051, pin # 1 - 11.73v
            R7052, pin # 1 - 12.26v
            The highlighted area around U7000 is all within specs, all remaining resistors around U7000 are within the spec also.
            • mon2
              • Dec 2019
              • 13839
              The voltage on R7051 does not look correct.
              Can you confirm the voltage @ R7051, pin # 2 ? It should match the voltage present on the current sense resistor = 12v26.
              Respectively, then remove all power, meter in the lowest resistance mode.
              Confirm the resistance of R7051.
              • beogeek
                • Apr 2018
                • 97
                • Serbia
                #67
                R7051, pin # 2 11.75V
                Tested with a Fluke 117 and a PeakMeter PM8236, Fluke 2.4Ω and peakmeter 2.3Ω
                • mon2
                  • Dec 2019
                  • 13839
                  Very strange.
                  See attached. Is my understanding correct ?
                  • beogeek
                    • Apr 2018
                    • 97
                    • Serbia
                    #69
                    Originally posted by mon2
                    Very strange.
                    Yes exactly, you're understanding is on par!
                    • mon2
                      • Dec 2019
                      • 13839
                      There is a 0v5 drop on a 'perfect conductor' (trace).
                      Meter in resistance mode. Check the resistance from R7051, pin #2 and the current sense resistor (pins 2&4). It should be 0 ohms or very close to this value.
                      If not, use a piece of wire to guarantee there is a solid connection between these 2 points.
                      Summary: You should not have a 0v5 drop @ pin # 2 of R7051.
                      • beogeek
                        • Apr 2018
                        • 97
                        • Serbia
                        #71
                        R7051, pin #2 to R7050 (pins 2&4) = 8.22MΩ WTF! I tested with both meters and both report the same thing!
                        • mon2
                          • Dec 2019
                          • 13839
                          Ok. This could be the root cause of your problems.
                          Jumper it with a solid wire - wirewrap wire is always good but I am dating myself .
                          • beogeek
                            • Apr 2018
                            • 97
                            • Serbia
                            #73
                            MON2 I could kiss you on the god damn mouth mate!!
                            I'm going to re-assemble it in a minute and see if the OS detects the battery!!!
                            • beogeek
                              • Apr 2018
                              • 97
                              • Serbia
                              #74
                              If anyone comes across this mega-thread, this is what was replaced in order for it to turn on with the battery connected.
                              U4900 (SMC) U7000 (ISL6259HRTZ), R7051, U5421, U5420, Q7055, D6990!
                              Just want to openly say I doubt I would have noticed that the resistance from R7051, pin #2 to R7050 (pins 2&4) we're 8.22MΩ instead of close to 0! After spending so much time on this I was just going in circles! All the praise goes to mon2, without your input and help and most importantly patience this would have done my head in for a long while!!! Thank you mon2 for all your help.
                              It's now charging, running off of battery, and running with battery and adapter connected!!! Bloody brilliant!!!!!!
                              • mon2
                                • Dec 2019
                                • 13839
                                Excellent! Well done. We all learned in the process and hope it will help future readers. TBH - we should have clued in on the R7051 which you replaced in your first post. Hindsight is always 20-20 but the fact that this part was defective made that entire leg a suspect.
                                When the world is calm and covid is nuked, not humanity, we will do a road trip and pick up SMDFlea from England, Piernov from France and come to visit you and party like it is 1999!! You have been warned
                                • beogeek
                                  • Apr 2018
                                  • 97
                                  • Serbia
                                  #76
                                  Yes R7051 was replaced, in fact, it was one of the first things I noticed that needed replacing. I tested the replacement on the board and out and it was in spec, so that is what took me on a wild goose ride as I assumed it was fine! I can't believe it was the trace that was the issue all along (if we're not counting the SMC, ISL, diodes etc)!!! You know what they say, two brains are better than one, in this case, only one was needed and it was yours, so hats off to you!!! I was just the surrogate surgeon!
                                  As for the party, let's do 1998, 1999 kind of sucked for this region hahaha. If you ever do plonk on by, do say hello, beers, and local foods on me!
                                  • Bowline
                                    by Bowline
                                    06-11-2025, 10:13 AM
                                  • code share
                                    Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                                    by code share
                                    I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                                    Here's what I've tried so far:
                                    • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                                    • Booted successfully on AC power only with the battery disconnected
                                    • Visual inspection of the battery — no swelling, burn marks, or connector damage
                                    • Battery
                                    04-21-2025, 12:50 PM
                                  • platinumsteel
                                    Macbook Pro 13'' 2017 A1708 Won't power on with battery connected.
                                    by platinumsteel
                                    Hi guys i have a 820-00840 that works fine and boots up as long a battery is not connected. I initially thought it was a bad battery so i went ahead and bought a new battery for it and slapped it in yesterday and realize that the same fault exists. When i screw in the battery and connect the little battery strip and i press the power button it will not power on.At that time If i connect the charger i get fan spin for 10 seconds then stops but the machine won't power on.If i disconnect the little battery strip and re-plug the charger the machine boots as normal.It's not the battery connector strip...
                                    03-03-2023, 10:17 AM
                                  • wraster
                                    Laptop stays on for only ~10sec when battery is connected, fine otherwise (Lenovo ThinkBook 15 G4 AMD)
                                    by wraster
                                    I have a Lenovo ThinkBook 15 G4 AMD (HLXB5 LA-M062P) that, when the battery is connected, starts up and shuts off in about 10 seconds, even when connected to power supply via USB-C charger. When the battery is disconnected, the computer stays on as in normal/expected operation (powered by USB-C charger input). I bought a new battery and see the exact same thing. My conclusion is it is not the battery itself but maybe some circuit or component involved in battery/DC-in crosstalk. I found a schematic but not boardview (request link below - sorry for the formatting, I'm not sure how to make an inline...
                                    Hi, I have a TB 15 Gen 4 that has an issue with the battery circuits. I believe the schematic is the same as this one: https://www.badcaps.net/forum/troubleshooting-hardware-devices-and-electronics-theory/troubleshooting-laptops-tablets-and-mobile-devices/schematic-requests-only/3522169-lenovo-thinkbook-14s-yoga-gen2-la-m062p
                                    02-25-2025, 11:33 PM
                                  • donnos
                                    A1989 820-00850 does not boot when battery is connected
                                    by donnos
                                    Hi All,
                                    have this macbook came in issues not able to turn on, found out the battery is blown(literally having holes in it). tried to do a battery swap and its still not booting up. However without battery connected, macbook boots up fine.
                                    Tried battery from another vendor, macbook boots but does not charge, system reports detects battery data and shows battery "service recommended". this at least tells me that the SMC/T2 is working.
                                    Tried changing ISL6240 chip and still the same. all 4 ports working fine,
                                    Checked current sensing resistors all...
                                    03-23-2023, 11:36 AM
