Another MacBook Pro 16"
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Ok this is another one we are working on, it turns on gets 20V goes up to 1.00 amps etc. Did a revive and what not but no image, did a restore, no image...
    LCD is not cracked btw, tested externally so works fine.
    Basically the computer is able to go into DFU and revive or restore etc. However the fans spin for about 10 seconds turns off then spins again for 10 seconds turns off.
    Power button turns the computer on and then it shuts off. even with power plugged in or on battery. I am sure this is an easy fix since the board turns on and it could be something on the board we can trace, just never came across this issue in this board.
    Board is clean and has no signs of water damage.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    Re: Another MacBook Pro 16"
    Check the voltage on L7211, L7221 and L7231, also check if caps lock works on keyboard
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 674
      Checking now.
      Caps lock turns on. Looks like the fans are staying on this time which is odd from last week. Updating with voltage readings here shortly
      sigpic
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 674
        Update:
        L7211 .78Volts
        L7221 .78Volts
        L7231 .78Volts
        God I hope this is not a bad CPU.
        sigpic
        • mon2
          • Dec 2019
          • 14498
          OK - need to ask, why is it game over once the CPU is considered bad ?
          Can the CPU not be swapped out ? (using a BGA rework station)
          Are these replacement CPUs not on Aliexpress ?
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 674
            It is game over for us since we do not have a BGA machine. We only have soldering machines. I mean we could mail it in for BGA rework of course but that lays the question if it is a CPU.
            sigpic
            • Stephen
              Meow Meow MEOW!
              • Apr 2020
              • 674
              Update:
              WTF is wrong with this machine.
              now the CPU is hot and the GPU is hot and fans are running
              Voltage on lines are now from .78 to 1.40Volts.
              Hello?!
              sigpic
              • Stephen
                Meow Meow MEOW!
                • Apr 2020
                • 674
                Any thoughts?
                sigpic
                • mon2
                  • Dec 2019
                  • 14498
                  Personally have not faced this issue yet but am working with a logic board that appears to hint (via diode mode testing) that the CPU is nuked. From assorted readings on Louis' forum and here, often it means the CPU is cooked. Remove all power.
                  Meter in diode mode.
                  Red meter probe to GROUND; Black meter probe to the vcore rails of the CPU.
                  What are the readings ?
                  We recently de-crated our BGA rework system (ZM model from China - used by Foxconn) which costs more than my car. Hope to test it out very soon. It is fully automatic but focus was to replace BGA / WLCSP devices and including repairs of dead CPU / PCH of these logic boards. It took 3 of us to lift the machine onto the table top (not that any of us are of Arnold's physique).
                  • Stephen
                    Meow Meow MEOW!
                    • Apr 2020
                    • 674
                    How much did it actually cost? I know the good machines from china run from 20,000 to 50,000. The really good automated ones are even more if you want one that never has issues. LOL but yeah man I want one for our shop one day. We only need one, because the odds of dead CPUS are slim but it be nice to have one. It would pay for itself if we had like maybe 200 devices that needed CPU swaps to resell.
                    sigpic
                    • mon2
                      • Dec 2019
                      • 14498
                      They list them @ $20k-$25k USD. It is their latest model with HD cameras and can support down to 0.5mm*0.5mm LED removal. We are working with 1.4*1.4mm FPGA devices (16 ball WLCSP package @ 0.4mm ball pitch). Openly, can repair these by eye / hand but it is nice to have a laser pointer and automatic tools to do the same. My hands are not as steady as they used to be but then again, flux and tweezer to make the BGA dance is a very good technique to follow (thanks Louis!).
                      I have heard someone recently bought a similar product for ~$13k-$14k USD. Due to the covid crunch, they offered us a promo price shy of this price. The vendor is very strong in Asia and attends all the trade fairs. They are coming to the USA for the upcoming APEX show - next week ?
                      We still have to clean up the solder pads by hand manually (ie. no vacuum system) but is with carbon fiber heaters, etc. which are mighty close to the features of a $50k-$60k units you will see on the market.
                      We are very interested to upgrade iMACs / macbooks on their memory and replace PCH / CPU devices. This in addition to reworking on of our designs with about 300-500 PCBAs where the silicon was announced by the mfr of having some bugs so we shelved the shipments. A local contract manufacturer wanted $100 per board for the rework with no guarantees - no thanks.
                      https://www.seamarkzm.com/products/z...ework-station/
                      • Stephen
                        Meow Meow MEOW!
                        • Apr 2020
                        • 674
                        Let me know when you get that machine working and we can partner together with our shop in America to ship our devices to you for BGA rework (bad CPUS, GPUS etc.)
                        sigpic
                        • VHS
                          • Oct 2020
                          • 13
                          Our shop is near Detroit, I already have some units I could send your way for repair and upgrades.
                          • ryogadan78
                            MacBook Pro 15" A1707 820-00281 turns on once in 10 (or maybe more)
                            by ryogadan78
                            I have this macbook that is behaving abnormally. Initially it had a battery life problem, after changing the battery everything seemed ok, but after about 5 days it started giving problems. It turns on once in 10 (or maybe more), more often after I unplug the battery connector and plug it back in. Sometimes after SMC reset. But it's not a stable rule. Visual inspection shows no problems, no signs of liquid contact or burning. Looking with the thermal camera I notice that the chip that heats up the most is U7220.
                            Any suggestions?​
                            05-24-2025, 04:26 AM
                          • Stephen
                            A1466 MacBook Air 13" 2017 Backlight issue works but then turns off
                            by Stephen
                            Hello, got a weird MacBook Air here
                            board looks fresh and no water damage, backlight works and turns on and stays on when installing OS etc. However, when the os is installed and when the system files are loaded before the login page the backlight goes out. I have wiped it, NVRAM reset, etc and even took some other instances and this blows my mind, never seen this before. Backlight just turns off once the OS is loaded. Anyone come across this and if so what would be the cause? I am certain its a board issue since I tested the LCD on another board and it stays on. Again the backlight works...
                            08-23-2023, 09:12 AM
                          • judamex
                            MacBook Air 820-00165 turns on But no green and orange light, not charge
                            by judamex
                            MacBook Air turns on without battery connected, no green or orange light comes on, I connect the battery and it shows battery with lightning and it restarts constantly.
                            03-06-2025, 03:55 PM
                          • Flasman90
                            Macbook Pro DFU Restore Issues
                            by Flasman90
                            I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                            - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                            - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                            08-30-2025, 10:27 AM
                          • iMuhtaseb
                            820-02020 A2338 Restore/Revive Failed
                            by iMuhtaseb
                            A2338 - Pristine condition.. I took out of the board and inspected it.. nothing.. as if the computer is barely used even.
                            Anyway, customer said they tried erasing/formatting it and it got stuck on Apple logo preventing to go further.. I asked them why they tried to erase it from the first place? They said it turned off randomly once.. then they erased it and it worked out for a few days then it shut off again..
                            I put the computer in DFU; I downloaded the latest Ventura IPSW and restored it.. during the "Installing.." it restarts then it shows the exclamation...
                            09-11-2023, 08:43 AM
