Nasty underfill
  • randoomkiller
    • Oct 2021
    • 9
    • Hungary
    Nasty underfill
    Hey there,
    I am currently working on a hobby project of mine where I try to replace a set of soldered on rams to 16GB just for the heck of it, but I've encountered a problem in the form of a nasty underfill.
    Look at the images
    What do you suggest?
    I've tried to scrape it off with a Qian Li 007, and even to move under a hot air station, but no luck.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Nasty underfill
    Is it Lenovo which uses a black colored glue to seal all bga's. Its very hard to remove them without damaging the foil on mb.
    • randoomkiller
      • Oct 2021
      • 9
      • Hungary
      Re: Nasty underfill
      Has anyone managed to do it?
      Also I've read that you could just "mill it down", could that work?
      • RethoricalCheese
        • Mar 2013
        • 1519
        • Estonia
        Re: Nasty underfill
        That's a 2nd gen carbon, yes?
        One method would be to heat it long enough to be sure that solder has melted and then use qianli to pry it off. Takes a bit of force.
        The other would be milling, indeed. Look for videos of iphone milling. They do it with CPU-s.
        Neither method is great or easy but it's not an easy task anyway.
        • mon2
          • Dec 2019
          • 14575
          Re: Nasty underfill
          Gathering that you are using a bottom side pre-heater to assist in the removal?
          Email Rewa with the details. They most likely have a solution for this by now in Shenzhen / China.
          Do update your progress here.
          • Adenitz
            Underfill chips
            by Adenitz
            Today I saw a video from PLD in which he replaced two chips CD3215 that had underfill. It was pretty complicated procedure of removing the chips and cleaning the board. What exactly is the purpose of underfill? Is it to protect chip‘s pins from liquid damage, to improve resistance to stress or shocks or something completely different?
            Thanks.
            09-12-2022, 01:56 PM
          • rediii
            ThinkPad X1 Yoga Gen 6 series fault
            by rediii
            - it is urgently recommended to update the bios to the latest version to prevent this series fault!
            - repaired 20 of them: in some cases all three chips have had to be replaced
            - all parts ordered here: mouser.com
            - exploded next gen fet (mainly used usb c port - replace it) - 20 times (15 times this was the only fault)
            TPD4S311YBFR
            TI USB Interface IC
            US HTS:8542390001 ECCN:EAR99 COO:PH
            - exploded ov protection ic
            FPF3380UCX
            onsemi Power Switch ICs - Power Distribution
            TARIC:8542399000 ECCN:EAR99 COO:PH
            -> you can use...
            05-01-2024, 10:26 AM
          • ktmmotocross
            MSI RTX2070 artefacts on load - replaced rams still bad
            by ktmmotocross
            I have this rtx2070 that have artefcts on load. mats show maybe two chips. after replace C1 and D0 chips it shows oposite chips. im confiused. is that because of MICRON ic? i know they goes bad in mass but this oposite errors confuse me
            MEmory ic is D9WCW...
            05-28-2022, 12:52 AM
          • piernov
            NVidia bumpgate
            by piernov
            Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
            Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
            May complete this post at a later date with more details.
            Basically issue is a combination of thermal dissipation of the chip with hotspot,...
            03-27-2021, 10:34 AM
          • s_specialist
            Lenovo ThinkBook 15 G4 IAP HLXA4 LA-L931P Rev 1A onboard ram disable
            by s_specialist
            Lenovo ThinkBook 15 G4 IAP HLXA4 LA-L931P Rev 1A device's onboard rams are faulty how can I disable the rams, can anyone help?
            Original bios is attached
            Serial No : MP2EF9WE...
            07-07-2025, 12:11 AM
