DFN and TDFN package differences and compatibility
  • electrocute
    • Mar 2021
    • 23
    • spain
    Hello. I've a noob question.
    For same component model, are DFN (dual-flat no-leads) and TDFN (thin dual-flat no-leads) packages compatible? What are the differences, only the thickness/thinness? Is there a package format listing with such details (DFN and other types of component packages)?
    I found some list on Wikipedia and some drawings/photos on datasheetdir but without specifying the differences.
    Thanks in advance.
  • mon2
    • Dec 2019
    • 14730
    Re: DFN and TDFN package differences and compatibility
    Hi. Yes.
    TDFN = will be the thinner version of the standard DFN so will be a lower height on the component.
    If possible, please share the part # and/or datasheet for more details. Often the datasheets will share a mechanical diagram for the proper pick & place placement equipment for the automated assembly. There it is critical that the parts have the proper height defined in the CAD tool. We have had this issue recently where our SMT head was turning on the vacuum to pick the part but we had the improper height definition so it was not creating the proper pressure to pick up the part. Kind of a gentle kiss to the top of the part and skipped to the next part on the tray feeling the part was not there. Chaos.
    Be sure to compare the pin to pin pitch dimension as well as the X & Y values. In general, only the height will be different.
    • electrocute
      • Mar 2021
      • 23
      • spain
      The part is APL3523AQBI-TRG_TDFN14_2X3 (Datasheet).
      I transplanted one from 330S_KBL_MB_V09 board to NM-A381 (see attached pictures, AFAIK they are the same). Still waiting for another part before testing it.
      The questions comes from wanting to buy the part for later use on 330S_KBL.
      • mon2
        • Dec 2019
        • 14730
        Yes, the 2 parts look to be drop-in equivalents. Personally would select the TI branded part for such repairs.
        • electrocute
          • Mar 2021
          • 23
          • spain
          Funny to see a failing component on the changelog/revisions for cutting costs (attached image).
          • mon2
            • Dec 2019
            • 14730
            I will bet that they started with TI (real branded; properly tested & qualified design) -> then used the offshore (their local) clone of the above to lower the costs. Happens all the time.
            To be honest, cannot paint everyone with the same dirty paintbrush. There are good quality manufacturers offshore but you have to do your homework to find them. We deal with numerous very high end suppliers (direct factory) for our PCBs; ESD & EMI parts for our designs. The same parts are 5-10x the costs under the private label in the USA / Canadian markets. The CEO did not want to discuss the 'private labelled' parts due to the margins they must be making and also non-disclosure agreements.
            One IC we use in high volume is < $2 USD in Taiwan yet about $15 USD in North America. Multiply that by 10k-50k buys = new cars ; homes. Greed in the resellers market.
            • francisew
              trying to recover data from the Toshiba / KIOXIA SSD on the XPS 13 2-in-1
              by francisew
              Continuing my saga of trying to recover data from the Toshiba / KIOXIA SSD on the XPS 13 2-in-1. It is actually a single-chip NVMe storage device, including the memory and controller in a single package (not an eMMC as I wrote above). The drive appears to come in two formats. One is the single-chip direct to board version included on the Dell XPS13 7390 2-in-1. The other format is an m.2 22x30 NVMe carrier board that also includes a handful of external power regulation components.
              It's unfortunate that I haven't been able to find datasheets for the Toshiba/KIOXIA BG4 series NVMe chips...
              09-15-2025, 06:27 PM
              Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
              The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
              Securing a good thermal interface between...
              10-07-2024, 04:35 AM
            • 2wtn
              CD3217B12 compatibility
              by 2wtn
              Hi all, have been lurking here for quite some time, and now my first post
              People who have experience replacing CD3217B12 chips (on macbooks), I have a few questions for you.
              As far as I understand, the CD3217B12 exists in more than one type and the different types are not cross-compatible. Is that correct? How many types are there in fact that you know of and which motherboards is each type compatible with? Do they look visually the same, or is there some difference in marking?
              What should I look at when buying these chips online, for example on...
              12-14-2022, 08:17 AM
            • Admin
              Other Useful Threads - Laptop Screen Compatibility, Useful ICs, BGA Chip Suppliers, NVidia bumpgate
              by Admin
              Some sticky topics have been moved to this thread:
              - finding a compatible laptop screen with LED-backlight.
              Most Common ICs - a list of the most common ICs (Integrated Circuits) required for repairing a laptop
              MOST COMMON IC FOR LAPTOP YOU SHOULD HAVE IN STOCK
              Let's Talk About BGA Chip Suppliers - anyone who repairs computers at component level has had to order chips from China at some point. Large BGA chips like graphics chips, chipsets and now CPUs are in increasing demand, due to their...
              12-27-2023, 03:43 AM
            • JSin21
              Compatibility of main boards between different variations of samsung MU6100
              by JSin21
              Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
              I have Samsung Smart TV UA65MU6100WXXY version DA01
              Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
              11-27-2023, 04:54 AM
