EDI73 LA-G711P REV 1.0 No display
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    EDI73 LA-G711P REV 1.0 (A00)
    2018-11-05
    INSPIRON 3480
    SERVICE TAG 3KLGDX2
    PCH_SRTCRST# CLRP1 - 3.0V
    PCH_RTCRST# CLRP2 - 3.0V
    YCL No 24mhz
    YC2 Reading 32.768 KHZ
    YE1 - 32.768 MHZ
    YL1 -25MHZ
    +5VALW -5V
    +3VALW -3V
    +3VLP - 3V
    SYS_PWROK-3.3V
    PRIM PWRGD - 3.0V
    +1.8V_PRIM - 1.7V
    +1.05V PRIM - 1V
    +1.8VALW_EC 1.7V
    +3VALW_EC -3.3V
    +1.2VP -1.2V
    PLI01 -+VCC_CORE - 0.8V
    PLG01 +VCC_GT - 0.6V
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: EDI73 LA-G711P REV 1.0 No display
    AFAIK, VCC_GT should appear for a second and go away(measured on DMM) on a working mb. If it remains constant-most likely CPU fault. I had a dell 3567(15341-1) with all rails coming up and i checked all power sequence-Didnt find anything wrong except VCC_GT always on at 0.65V whereas on a working mb it just comes up for a second and goes away. So decided to replace SOC and got display. Maynot be the same case but my experience suggests, if VCC_GT remains constant-most likely cpu failure.
    • kalilinux25
      • Mar 2018
      • 2089
      • ZAMBOANGA SIBUGAY
      maybe cause I have remove the short from the PCA01 +VCC_SA
      I already remove the bad caps now its just having low viltage reading to the coil
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        VCC_SA must come first. What is the voltage on VCC_SA coil?? Check the requirement of that IC connected to VCC_SA coil.
        • kalilinux25
          • Mar 2018
          • 2089
          • ZAMBOANGA SIBUGAY
          PLA01 coil has 0.8V
          PQA01
          1-G1 1.2V
          2,3,4 - 19V
          5,6,7 - 0V
          8 - 5V
          PUA01
          1. BST - 5.7V
          2. PMW - 1.1V
          3. EN - 5V
          4. VCC -5V
          5. DRVL -2.2V
          6. GND - 0V
          7. SW - 0.8V
          8.DRVH 0.9V
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            VCC_SA seems fine to me.
            • kalilinux25
              • Mar 2018
              • 2089
              • ZAMBOANGA SIBUGAY
              Thanks for the help sir. I already return the laptop because Its very complex problem. Thanks for the help
              • LaPCon_IT
                Ideapad 130-15IKB, LA-G202P rev.1.0 no picture, +VCCGT
                by LaPCon_IT
                Hi people,
                Ideapad 130-15IKB
                LA-G202P
                CPU: i5 8250U
                The laptop turns on without picture. All voltages are present except +VCCGT. Probably POST not starting because current stays around 300mA. I've checked resistance and voltages:
                PL602 - 28ohm - 1.0 VALWP - 1.04V present
                PL502 - 231ohm - 1.2VP - 1.2V
                PLA1 - 17ohm - VCCSA - 1.03V
                PLZ1 - 4ohm - VCCCORE - 0.84V
                PLZ2 - 4ohm - VCCCORE - 0.84V
                PLG1 - 7ohm - VCCGT - 0V
                The VCCGT comes from PUG1 (RT9610CGQW). Signals are:
                EN-5V,
                03-07-2023, 08:25 AM
              • Prott
                Surface Pro 4 - cycling VCC_CORE, no VCCGT
                by Prott
                I have a Microsoft Surface Pro 4 (i5, 8 GB) that originaly had a swollen battery and was crashing during Windows install. I replaced the SSD with a new one (from another surface) that had OS installed. As a result of this the Windows booted, but few seconds after the start it went into "Locking" screen and turned off.
                Now the "fun" starts:
                Upon removal of the motherboard from the case the fault changed:
                - When I start the tablet the VCCSA goes to 1.1 V for half a second and shuts off, followed by 1P2V_DUAL going to around...
                01-04-2023, 02:33 PM
              • ktmmotocross
                Asus GL553VW restart under load/SOLVED/ - What is purpose of +VCCGT ?
                by ktmmotocross
                Hello.
                Have this asus Asus GL553VW that restart under load when install or start system.
                By scope i found that middle phase not work and +VCCGT s 0V even when working. Dont have chip so i took one from +VCCGT and replace middle CPU phase IC. Now have all phases working and laptop work like it should have.
                So what is that +VCCGT for? I see that it goes to CPU so im was thinking about IGPU but i see it found and install drivers for intel without problems and works ok when nvidia drivers was not installed...
                05-25-2021, 03:29 AM
              • skynet85
                MSI MS-16JB (MS-16JB1) does not rise +VCCGT
                by skynet85
                Hello, before me, the board was flashed (main) I don't know about the EU, after pressing the main voltages rise + 3VSUS 3.3v,
                +5VSUS 5v, +1_2VDIMM 1.2v, +1.0VSUS 1v, PEX_VDD 1v, +VCCSA 1.1v, PL9 +VCCIO 0.9v, +VCC_CORE PL10 PL11 1v, +VCCGT PL12 PL13 0V resistance 4.8 ohm, PLT_RST# 3.3v EC_ALLSYSPG 3.3v , H_VCCST_PWRGD_R 1v
                Measurements PU8 ISL95855HRTZ
                1)PSYS 0
                2)IMON_B 0
                3)NTC_B 0.3
                4)COMP_B 4
                5)FB_B 0
                6)RTN_B 0
                7)ISUMP_B 0
                8)ISUMN_B 0
                9)ISEN1_B 0
                10)ISEN2_B 0
                11)FCCM_B 0
                12)PWM1_B 2.5...
                05-06-2022, 11:03 AM
              • fcnamcoi
                Need help Bios Dell Vostro 3580 EDI73 LA G711P Rev 1.0 (A00) Clean Me
                by fcnamcoi
                Tag : 6JZXZX2
                Clean Me
                Original file :...
                02-25-2023, 03:40 AM
