Hello all... I was wondering if replacing the EFI chip can remove an MDM enrollment if the chip is programmed with a different serial number. Basically I want to program a serial from a junk board to it and install it to a board that currently has MDM locked to it. It is linked to the serial number is it not? Has anyone tried it and did it work or not? If it didn't work please tell me why. Thank you!
820-00165 MDM removal
by mmx01Hi,
The machine was/is password locked for BIOS. You can imagine I am writing here because things did not go as planned... I downloaded and edited both main bios and EC rom flash chips with 866II+ programmer using RCUnlocker for EC and BIOS patcher for BIOS. Verification goes ok for all files but now the computer is not even turning on.
When I press power on, white LED goes on but as soon as I release the power button it goes back to sleep. No beeps or other sings of life. Soldering of both chips is verified with continuity test, all is connected okay. Both chips were...-
by bruce35HP 600 G3 MT
SERIAL NUMBER MXL8301K1C Serial number in the file in bios
SERIAL NUMBER CZC72988BY original serial number of the safe original serial number of the safe
Thank you very much...-
by touftaf7301Hello everyone,
I have an ASUS TUF A17 (model TUF707NV-HX088W, motherboard NJS / DA0NJSMBAF0 Rev F) that is locked by an UEFI BIOS password.
I have already checked the BIOS guides, methods, resources and tools section but could not find a working method for this specific model.
Details:
– Make/Model: ASUS TUF A17 TUF707NV-HX088W
– Motherboard: NJS / DA0NJSMBAF0 Rev F
– Serial number: S7NRCX05W03829E
– Issue: UEFI BIOS password locked (no access to BIOS setup or boot options)
– BIOS dump attached below (read with RT809F)...-
Channel: BIOS Requests ONLY!
by KABYhello every one
i have bought seconde hand chromebook i fund that its locked by administrator by serial number can someone help me with this
i tried rcunlocker nothing happend enrollment dev mod nothing CHANGED IN bios
when i change serial number laptop wont turn on ( i change only one number in bios bin not everythin)
can someone help me with it!!!!
the serial number is NXHKAEF006321039717600
ORIGINAL BIOS BIN...-
by DannyxGood day folks. I got a project on hand and would like some thoughts on whether it's possible to achieve, albeit impractical. You know me - I like to over-complicate stuff
The setup: I got a Paradox EVO192 alarm panel, a serial-to-ethernet adapter and an official PCS250 GSM communicator.
The task (TL/DR): connecting both the ethernet adapter AND the communicator to the single serial port of the Paradox panel. Connecting their TX/RX lines in parallel the data would get all messed up. At the very most, I THINK I could parallel the RX pins of the ethernet adapter... - Loading...
