Toshiba Satellite - Locks up when plugged in
+ More Options
Posts
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Interesting one here. I've got a Toshiba Satellite that will lock up almost as soon as you plug it into AC. If you run it off the battery, it won't lock up at all and runs fine until the battery runs out.
    Tried a brand new ac adaptor and still has the issue. Doesn't seem to be overheating, and I even pulled it apart and put new AS5 on the CPU heatsink. Didn't find anything else noticibly wrong when I was in there, either.
    Any thoughts?
    Ludicrous gibs!
  • mockingbird
    • Dec 2008
    • 5484
    Re: Toshiba Satellite - Locks up when plugged in
    Did you check for a lint carpet between the heatsink and the grill?
    • dood
      Deputy dood
      • Mar 2004
      • 2462
      Cleaned everything when I had it apart.
      I've found some other people online having the same issues - noone has been able to solve it. Tried BIOS updates, no go. I'm thinking it might be a piece of hardware that's disabled when running on battery, and then turns itself back on when plugged in and causes the laptop to lock up. The laptop locks up whether it's in Windows or not.
      Ludicrous gibs!
        • 31170
        bad caps in the hv stepdown probably.
        • mockingbird
          • Dec 2008
          • 5484
          Did you try removing components? (i.e. modem card, wifi card...)
          • Wizard
            • Mar 2008
            • 2296
            Carefully check the SMD electrolytic capacitors, especially small ones in critical control circuits for power MOSFETs.
            Cheers, Wizard
            • insomnia
              • Jan 2010
              • 17
              could be bad caps alright but i would also check to see if it is a bad joint on the dc jack
              • Rainbow
                • Aug 2005
                • 1375
                Just fixed one Satellite A300. This is caused by a bad cap. A big one - NEC/TOKIN 0E907 (900uF/2.5V) under the CPU. Mine had 900uF but probably lost some of its magic, resulting in >100mV ripple on CPU power. Adding 1x 100uF and 5x 10uF ceramic caps fixed the problem.
                • Biancocf
                  • May 2011
                  • 7
                  Hello everybody , im new here , but i promise to do my best to help on this fantastic forum! , i need a little help here , i remove this capacitor now the mobo does not boot , how can i dessolder the capacitor from anither board without destroy it?
                  • Biancocf
                    • May 2011
                    • 7
                    can you help me to solve this problem? i need to change this capacitor and it's too weak to temperature... please it's my first bad service here...
                    • severach
                      • Aug 2007
                      • 1055
                      The only good method I've found for quickly and safely removing large 2 terminal SMD parts like caps and diodes is with 2 soldering irons. One in each hand and a tantalum cap lifts off in seconds with minimal heat. A SMD hot air gun and one soldering iron works also but the part gets a lot more heat before coming off.
                      The cap can be put on the same way with 2 irons but the result doesn't look good and the part gets a lot of heat while fussing with the position. Removing the solder from one pad and using 1 iron usually produces a higher quality result.
                      sig files are for morons
                      • ablacon64
                        • Jan 2011
                        • 89
                        Go for Rainbow tip. That huge capacitor is usually responsible for that. Keep in mind that it has four soldered terminals in it. I had success by preheating the motherboard (150ºC) and then using a hot air rework station to remove it.
                        Two soldering irons won't do for that one (or at least will be very difficult).
                        But in my case I replaced then with 4 330u 2.5v tantalun SMD capacitors.
                        • Biancocf
                          • May 2011
                          • 7
                          can you post a picture ? i want to see the finish job , the space is too short to 4 caps here , if possible of course...
                          • Biancocf
                            • May 2011
                            • 7
                            Wooooww!! it work's !!! i change a little bit the prescription but it's perfect!!
                            i put 10 ceramic caps on right side and 4 470u tantalum on left side and now it's like a new one , thankyou everybody , now i want to post a pic of the job to help others , can someone help me to post a pic ? what max specs of the pic please...
                            • retiredcaps
                              • Apr 2010
                              • 9271
                              Use the manage attachment functions (below text area) and please do not post inline.
                              Max jpg is 2000x2000 and around 4MB.
                              --- begin sig file ---
                              --- end sig file ---
                              • Biancocf
                                • May 2011
                                • 7
                                i help this help others , thank's
                                • ablacon64
                                  • Jan 2011
                                  • 89
                                  Unfortunately, I made this fix some time ago, the notebook is with the client. But I made a (terrible) drawing. Hope it helps.
                                  • ablacon64
                                    • Jan 2011
                                    • 89
                                    I had the opportunity to solve another one with that same problem, this time I took some pictures. Hope it helps.
                                    The notebook is a Toshiba Satellite A305-S6872.
                                    The first image shows the capacitor removed, board cleaned.
                                    The second, new solder added to the pads.
                                    And finally, the finished job.
                                    • azry
                                      • May 2011
                                      Thanks all for that pictures... i never thinking to do this before!
                                      • unlockdev
                                        • 81
                                        I Hav toshiba L300 blinking power adapter i thinks the problem in the caps to cos i check the power mosfet ist oki ???
                                          Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro A40-C-1P5 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A40-C-1P5 boardview and Satellite Pro A40-C-1P5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 06:10 AM
                                          Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro R50-C-17C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-C-17C boardview and Satellite Pro R50-C-17C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          09-06-2024, 05:40 AM
                                          09-06-2024, 05:27 AM
                                          Toshiba Satellite Pro Satellite Pro R50-EC-11J Notebook Specification for Upgrade or Repair
                                          This specification for the Toshiba Satellite Pro Satellite Pro R50-EC-11J Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R50-EC-11J boardview and Satellite Pro R50-EC-11J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          09-06-2024, 08:10 PM
