Dell Latitude e7440 (LA-9591P) diagnostic
  • ggman
    • Feb 2021
    • Ukraine
    Hello Friends
    I need your help in Dell Latitude e7440 (LA-9591P) diagnostic.
    The issue is that laptop doesn't start if power button applied, the power LED on but than off after several seconds, no image appeared on the screen, cooling fan doesn't on.
    I have checked power distribution on the motherboard:
    +PWR_SRC – 13,6V
    +5V_ALW – 5,1V
    +3,3V_ALW – 3,3V
    +3,3V_ALW_PCH – 3,3V
    +3,3V_RTC_LDO – 3,3V
    +3,3V_SUS – 0V
    +1,35V_MEM – 0V
    +5V_RUN – 0V
    +3,3V_RUN – 0V
    +1,05V_RUN – 0V
    +VCC_CORE – 0V
    Signals from UC1H (CPU):
    SIO_SLP_S0 – 3,2V
    SIO_SLP_S3 – 0V
    SIO_SLP_S4 – 0V
    SIO_SLP_S5 – 0V
    SIO_SLP_A – 0V
    Signals from MEC5075:
    A_ON – 0V
    Signals from MEC5048:
    SUS_ON – 0V
    RUN_ON – 0V
    The problem is that I didn't find power on sequences for this motherboard.
    Could you please advise power on sequences for LA-9591P.
    The avlible schematic is attached.
    Thank you.
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Dell Latitude e7440 (LA-9591P) diagnostic
    SIO_SLP_S0 – 3,2V
    SIO_SLP_S3 – 0V
    SIO_SLP_S4 – 0V
    SIO_SLP_S5 – 0V
    SIO_SLP_A – 0V
    100% sure about this?
    • ggman
      • Feb 2021
      • Ukraine
      Hello Piernov
      Thank your reply
      I have rechecked again signal on JAPS1 connector.
      SIO_SLP_S3, SIO_SLP_S4, SIO_SLP_S5 and SIO_SLP_A always 0V. But when I checked SIO_SLP_S0 voltage at first was 0,13V, than I disconnected ground probe and connected it again the voltage inceased up to 3,13V, than I pressed power button and when power had LED off the voltage become 0,13V again, when I moved ground probe again the voltage increased.
      I attached video
      What do you thing, could it be cause of the issue?
      Regards
      • albasiba
        • Nov 2015
        Hello Ggman, I have the same issue with the same laptop. Did you find any way to solve this problem?
        Regards,
        Ali
        • stefanbs
          Stefan
          • Jun 2018
          • 16
          The SPU (SoC ) dies on these laptops, most probably this is what happened to yours.
          • maki
            • May 2011
            • 6
            Do you mean CPU ?
            • s22o
              • Feb 2016
              • España
              Disconnect +DCIN JACK. Disconnect cell 3.3v from JRTC1. Press SW1 for 20s. Connect +DCIN JACK 19.5V. Works.
              Same symptoms. Tried.
              • carrneiro
                • Mar 2020
                • poland
                LOL
                  DELL Latitude E7440 Ultrabook 7000 Specification for Upgrade or Repair
                  This specification for the DELL Latitude E7440 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E7440 boardview and E7440 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude...
                  09-06-2024, 04:40 PM
                  09-06-2024, 04:10 PM
                • diamon
                  Looking for Dell Latitude 5520 / 5530 / 5540 RJ45 network connector replacement
                  by diamon
                  I have a Dell Latitude 5530 with a damaged RJ45 network connector. See the attached pictures.
                  Have already searched on Farnell / Aliexpress / Ebay and had contact with several suppliers on Aliexpress and Ebay, but they cannot deliver this connector.
                  Is there someone inside the EU, who has these connector(s) or perhaps defective motherboard(s) for these laptop models I have mentioned in the topic title.
                  Pictures of these boards:
                  Dell Latitude 5520 https://www.ebay.com/itm/256052956663
                  Dell Latitude 5530 https://www.ebay.com/itm/125844181534
                  Dell...
                  02-28-2024, 12:51 PM
                • F R 2568
                  Dell Latitude 5420 does not start (no post) need help to find the reason why
                  by F R 2568
                  Hello all,
                  this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                  I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                  If the laptop is only connected to the AC adapter (battery removed):
                  When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                  The power/battery...
                  01-08-2025, 05:45 AM
