820-3330 stuck on usbmultitouch driver
  • bdawg
    • Oct 2014
    • 13
    Will not load into macOS or ASD. When running verbose mode it always stops at usbmultitouch driver. Just stops there. I have scoped the board for missing parts and corrosion and all looked good. I have replaced u5701 and u2700 with no change. Both get necessary voltages to operate. What else do I look for at this point? Thank you!
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: 820-3330 stuck on usbmultitouch driver
    Booting into Linux or WIndows?
    Send picture of verbose mode.
    • bdawg
      • Oct 2014
      • 13
      Have not tried Linux or Windows. I will post a photo of the screen later once I get home. Thank you very much!
      • osrex
        LED DRIVER KEEPS DYING
        by osrex
        Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
        i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
        i have no datasheet at all for the LED lights, all i have is its length.
        long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
        as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
        05-05-2025, 03:36 PM
      • Stunt
        Hp Laptop Stuck on Hp protected by hp sure start screen
        by Stunt
        Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
        I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
        I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
        Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
        screen that's it and stuck there. I left it until the following day and i still...
        09-02-2025, 01:51 PM
      • howardc64
        Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
        by howardc64
        Problem
        Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
        Model & Board Pics
        Conflicting Spec
        Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
        https://www.shopjimmy.com/vizio-gj-2k1...
        10-10-2024, 01:16 PM
      • charif
        Audio Driver for Thomson P14C4BK128
        by charif
        Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
        I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
        The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
        Here are the details:
        • Model: Thomson P14C4BK128
        • Operating System: Windows 10 64-bit
        If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
        Thanks in advance for your help!
        04-30-2025, 05:41 PM
      • bohaboha
        how to install gl usb2.0 uvc camera device driver on windows 10
        by bohaboha
        Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
        but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
        any help?
        01-26-2025, 08:33 PM
