820-01987-A Macbook Pro A2289
  • jimanez11
    • Jan 2015
    • 93
    Have a Macbook Pro A2289 that I bought off of ebay with cited "Juice Damage". The damage didnt look too bad on the site, and honestly doesnt look that bad in actuality. But alas, it is indeed fairly bad (at least to my incredibly limited knowledge). Armed with a silk-screen image of the board layout, multi meter, schematic, and a very limited understanding of how logic boards function, I remain (unsurprisingly) vexed by the situation. The current status of the machine is as follows:
    - USB C volt tester indicates the board is pulling a steady 20.1v
    • amperage bounces up to sometimes 400mA, sometimes 380mA for a split second before going to 0, then back up to around 200mA, and then staying at a constant 20mA until restarted.
    - PPBUS_G3H is a steady 12.61 throughout the board
    - PP3V3_G3H is steady 3.3 throughout the board
    - PPVCC_S0_CPU is .84v for about 10 or so seconds (until the board only takes .2amps) and then drops (measured on both L7210 and L7220)
    - PPVCCGT_S0_CPU is completely non-existent when measured on L7410 and L7420 (which made me trace this back to U7400)
    - U7400 is getting required 5v on VCC and 12.61v (from PPBUS_HS_CPU).
    Then I traced this back to U7100 and pulled the following from the test pads:
    - CPUCORE_PWM1 (PP7100) - quick flash to 2.3v when power applied, then to around .6v for a few seconds before dropping and holding at .038v
    - CPUSA_PWM (PP7102) - gets up to .47v and then switches to low
    - CPUGT_PWM2 (PP7104) 2.55v for 10 seconds, then low
    - CPUGT_PWM1 (PP7103) 2.55v for 10 seconds, then low
    It looks like there is some gunk under Q7660 and under C8412 has a solder tail, so it may have been replaced? Not sure though.
    When everything is hooked up and plugged in:
    - power button responds when pressed to power on and held to turn it off
    - fan spins for a second or two, then stops
    - Keyboard backlight is very dim
    - Able to get into DFU Mode with another macbook, so USB is sending / receiving info.
    - Trackpad will also click until powered off
    - No image or backlight and screen is broken
    I reached out to the person I purchased the machine from and he didnt try any repairs, just "scrubbed the juice off with alcohol and a stiff brush". The "stiff brush" part may explain why I found a .01uF capacitor stuck to the adhesive around the trackpad (still no idea where it came from).
    Appreciate the advice and any knowledge / guidance / next steps you all are willing to share.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: 820-01987-A Macbook Pro A2289
    No idea why would you buy a very difficult board to repair when you have not much experience, especially from eBay and with a broken screen (second most expensive part after logic board and extremely difficult to find a good quality one), on top of that it'll probably be iCloud locked…
    In any case the board turns on so next step is getting a known good screen.
    • jimanez11
      • Jan 2015
      • 93
      Thanks for the response Piernov - understand that the screen is an expensive part, but got a decent deal on the machine itself. Purchase mechanism and associated decisions aside, its good to know that the board is turning on. I was under the impression that it required 600ma to get to S0, and never saw that come up so wasn't sure. It will likely be a while before a new screen comes in - will post back if any other issues are noted.
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 674
        I bought a new oem screen for $315 and worked perfectly. Don’t know if that price is still normal or not today...but careful on the prices.
        sigpic
        MEOWING IN THE IMPOSSIBLE UNIVERSE!
        • jimanez11
          • Jan 2015
          • 93
          So now have a known good screen and still no image internally or externally. Machine pulls 20v and looks like its booting - gets up to roughly 600ma without battery connected and then goes down and holds steady at ~470 ma. All power rails appear to be turned on and all big coils appear to have the correct voltages. The capslock button does not toggle when pressed and there is still no image. I cant see an LCD enable signal being sent out by the CPU either. Is this a "no brain" case, or would it potentially be a bios issue or something else? Have read a few posts where a reflow of the CPU could possibly remove any gunk from underneath it, but would want that to be a last ditch effort I think. I am able to enter DFU mode and successfully run through the revive process, but there is still no USB activity (led on thumb drive does not blink at all) when plugged in or image on screen afterwards. Any advice on where to go next would be greatly appreciated.
          • jimanez11
            • Jan 2015
            • 93
            Any guidance or next steps, or is there anything else I should be looking at? Am still trying to learn correct methodology for troubleshooting logic board repair, so any guidance is appreciated!
            • Flasman90
              Macbook Pro A2289 MXK62LL/A (661-14770) - No Startup
              by Flasman90
              Hi everyone - first time poster on here looking to embark on my first repair! Thank you in advance for any help!
              My Macbook only turns on when the charger is plugged in and only the trackpad and fans show signs of life. The display, caps lock light and touchbar do not turn on. There was previous liquid damage to the touchbar but after cleaning and drying the laptop was operational for a year without any issues. There doesn't seem to be any sign of liquid damage to the board, at present.
              What I have done so far:
              - All of the routine diagnostic methods including...
              08-29-2025, 08:38 AM
            • baglaivlad
              MacBook Pro A2289 (820-01987-A) No boot/image, but boots to DFU
              by baglaivlad
              Hi everyone. Just a reminder I am not a professional repair technician, fixing Apple electronics is my hobby.
              Recently got my hands on MacBook Pro A2289 with interesting behavior. Pristine condition, no water damage, no visual issues whatsoever. It has no image, no CapsLock, no life except the fan is spinning. But it is able to boot into DFU and recognized by another MacBook. I tried to revive and restore the laptop, but the process ends when the MacBook usually should show an Apple logo with a progress bar. I assume the main power lines and T2 are working. It seems like the Intel...
              01-09-2024, 09:55 PM
            • Woodsworth
              MacBook Pro A2289 no signs of life except clicking trackpad and charging
              by Woodsworth
              I hope this is the correct place to post about this device. I originally posted regarding this on iFixit so see the details from that post below:
              "I'm hoping someone can give their opinion on the symptoms I'm seeing before I spend any more time and put money into this. I got this MacBook from a customer and after looking at it they decided they didn't want it.
              It doesn't turn on and there's no visual signs of life. I have tried resetting the NVRAM, SMC, power cycling, unplugging the battery, using the charger with the battery unplugged. Removed the...
              03-15-2024, 04:06 AM
            • modtool
              Macbook Pro A2289 EMC 3456, MLB 820-1987-A, broken U6903, stuck at 5v
              by modtool
              Dear friends,
              a close friend of mine gave me this machine, she told me that the last days the fan was going high and that it was heating up too much for the usual things, and that suddenly one morning it didn't start anymore .
              I opened it and inspected carefully with a high magnifying lens, found no oxydized spots but a short on PPBUS_G3H , then a blown U6903.
              I changed U6903 with a new one, PPBUS_G3H became 558 (measuring with red probe to gnd , and black on F7000) , PP3V3_G3H_RTC 463.
              Now when I plug the usbc cable (original Apple 61W power supply), nothing starts automatically,...
              10-25-2025, 05:09 AM
            • Zparts01
              MacBook A2289 820-01987
              by Zparts01
              I have a problem I'm hoping someone can help me with. I have an A2289 MacBook that had some liquid damage. After repairing any areas that had corrosion, I was able to get it to show 20v but only .01a on the multimeter. It was consistent on all ports, however I could not get the MacBook to go into DFU mode. I read that I should refllash U4770 and after grabbing the bin from this site I did just that. After soldering the chip back on the board, now I have DFU mode, but the thing is, it won't revive or restore, giving me the error that the device left the DFU state or something to that effect. The...
              02-04-2024, 02:07 PM
