Hp spectre 13. Charging issue. Very confusing!
  • Ussovak
    • Jan 2020
    • 5
    Re: Hp spectre 13. Charging issue. Very confusing!
    The TPS65982 is the PD controller. Your charger talks to it directly via the CC1 or CC2 lines on the USB-C port. Each USB-C port has their own controller. Perhaps you have an open CC1/CC2 line from your USB-C port to the TPS65982 chip.
    If not replacing the TPS65982DA with a new one should resolve the issue.
    • mon2
      • 13861
      I will suggest to source a fair cost PD bus analyzer tool. Many are now < $100 USD. Then using the tool, you can validate the traffic of the communication between the PD adapter and the PD controller on the logic board.
      I know there are assorted models on Aliexpress but the better tools are the ones from Cypress or ST Semiconductor for power delivery designs. Just a suggestion. These PD bus analyzer tools work with a normal PC and logs the bus traffic on Windows to show the packets, the power delivery contracts, etc.
      • flat-earther
        ASUS X54H laptop thinks it's always charging even with charger unplugged
        by flat-earther
        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
        Windows also shows ''Plugged in'' when charger is not connected.
        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
        If I let battery run out and say it has 3% Windows will...
        06-24-2025, 09:32 AM
      • Simone Vergani
        Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
        by Simone Vergani
        I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
        To assist with troubleshooting, I'm attaching two power circuit schematics:
        • Power
        03-05-2025, 02:25 PM
      • ahmarzo
        la-j081p charging issue
        by ahmarzo
        Have Dell la-j081p laptop with battery issue.
        First the laptop was not charging pqb25 was short after changing pqb25 and pqb26 the laptop starts charging and runs properly on charger but battery it shutdown after 10 seconds.
        And when powered on only on battery the laptop turns off after 8-10 second without giving display.have tried another battery on another working laptop and it's working fine
        I have changed charging ic and pqb25 ,pqb26 and pqb13.
        When adapter is disconnected the laptop stays on battery for 8-10 sec then abruptly shutdown everytime.
        This is the link...
        04-24-2025, 05:16 AM
      • DominikPechac
        MacBook Air A1466 820-00165 Charging Issue
        by DominikPechac
        I have a problem identifying a problem on this MacBook Air A1466 with board 820-00165.
        A customer came in with a problem, the laptop was not charging. Otherwise, it works fine - runs from a battery without an issue. The battery is original, the customer also provided his original charger.
        However, when I was diagnosing the issue, I turned the laptop off, checked the board, etc. When I put everything back together, the laptop was charging (I inserted the charger and then turned the laptop on). After unplugging the charger and plugging it back,...
        04-05-2024, 02:20 AM
        HP Spectre x360 Spectre x360 - 13-aw0197tu Hybrid (2-in-1) 13 Specification for Upgrade or Repair
        This specification for the HP Spectre x360 Spectre x360 - 13-aw0197tu Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 - 13-aw0197tu boardview and Spectre x360 - 13-aw0197tu schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
        09-06-2024, 12:10 PM
