820-3787 No LCD_BKLT_EN
  • kory
    • Jan 2020
    • 8
    This is quite a head-scratcher for me, just received a board yesterday from a customer and it has a shorted LCD cable and connector on the LCD assembly. Backlight circuit resistance without the screen is the nominal >150kOhm. Using a good test screen I still have no image and no backlight.
    This is where it gets weird...
    Prior work on been done on this board, appears that there was liquid around backlight circuit area in the past and the fuse F7700 was replaced with a wire.
    LCD_PWR_EN is good 5V but LCD_BKLT_EN is near 0V. Resistance on LCD_BKLT_EN line is 9.9kOhm (as expected).
    GPU Rails seem good except for one:
    I checked GPU power rails, all enables are 3.3V: P1V35GPUFB_EN, P1V05_S0GPU_EN, P1V8GPU_EN, P3V3GPU_EN, GPUVCORE_EN are all 3.3V going into U9600. Coming out of U8710 is the P1V05_S0GPU_PGOOD and it is good at 3.3V. P1V05_GPU_LL is 1.05V as expected. GPUVCORE_PGOOD is 3.3V and GPUFB_PGOOD is 3.3V as well.
    TP_GPU_PGOOD2 => GPU_PGOOD2 is not good though, it is around 0.1V.
    In the schematics and board I can't figure out exactly what this is for and why it would be low. There is a testpad connecting to pin/ball 110 (L4) on U9600 and in the schematic (page 66) it says "NO PU ON 3V3 and 1V8 PGOODS SINCE THEY ARE SYNTHETIC." There is no pull-up resistor to the 3.3V rail, so is 0.1V normal?
    Another question, do we normally need a screen attached to get LCD_BKLT_EN or can I continue working with only the board to get LCD_BKLT_EN working first before attaching a known-good screen?
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: 820-3787 No LCD_BKLT_EN
    You have to get image on the internal LCD before worrying about backlight. And similarly machine must POST properly before worrying about image.
    GPU_PGOOD2 is not used.
    You always need LCD to be connected when troubleshooting image/backlight problems.
    • kory
      • Jan 2020
      • 8
      Thanks Piernov, I appreciate your response. I thought I was testing with a known good screen but I had grabbed the wrong one (I need to read my labels on the back first), sorry about that. So here is the update, blinking folder due to missing SSD but still no backlight and LCD_BKLT_EN is still near 0V. Fuse voltage is 12.5V (but recall prior work on the board replaced it with a wire). So the backlight chip is not being told to turn on by U9600. Everything else seems fine, could it be that this new short in the screen burned out U9600?
      Thanks!
      • kory
        • Jan 2020
        • 8
        Geez, the prior work and liquid damage is making me forget the basics, SMC_LID is 0V.
        • Mgiffune
          by Mgiffune
          06-09-2024, 10:28 AM
        • reformatt
          by reformatt
          07-31-2025, 08:37 PM
        • totof
          LG 43UF640V backlight good but black screen and no sound
          by totof
          Good morning.
          I have a problem with my LG Smart 43UF640V TV. It starts, the backlight comes on but nothing is displayed on the screen and there is no sound.
          I thought it was a TCon problem and ran various tests. If I disconnect one or the other of the cables from the tcon to the panel then the screen is white on the side where the cable is disconnected and black on the other side. If the two cables are disconnected the screen is completely black.
          In the 4 configurations I measure exactly the same voltages on the tcon card (model V15 43UHD TM120 Ver0.4) :
          HVDD : 7,28...
          04-13-2024, 11:37 PM
        • Chrissygizmo
          by Chrissygizmo
          02-10-2025, 12:33 AM
        • totof
          EU55JS9000T black screen and sound good
          by totof
          Hello.
          I have this issue on my Samsung EU55JS9000T TV.
          Backlight is good when the one connect box in not connected to the TV and I can launch the TCON screen test with the remote control.
          But when I connect the one connect box the backlight immediatly turn off, the sound is OK (TNT source).
          I dont know if the problem is from the one connect box or from the internal motherboard of the TV.
          I open the one connect box (reference BN96-37087R) and all seems good, simply the Hawk-P CI is very hot after 5 minutes (~65 degres).
          Is someone have experience...
          09-25-2023, 03:23 PM
