x202e rev 2.0 no power
  • kalilinux25
    • Mar 2018
    • 2089
    • ZAMBOANGA SIBUGAY
    Hi I have a problem with this board no power Ive tested the 5Vis present 3v is not present on my pmw rt8239bzqw pin 9 has no output of 3v
    Plese guide me if this pmw is dead
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: x202e rev 2.0 no power
    You need to check pin 15 for LDO 3.3V and pin14 for LDO 5V. If both are present and you dont have voltage on 3V coil-it may be suspend logic is involved and 3V will be present after switching on. Do check Entrip/FB pins as well. Btw, Pgood is present??
    • stingerchamp
      • Sep 2020
      • 425
      • Pakistan
      In addition
      Check ton resistor value , ton effects phase value
      if ldo and logic is ok as suggested above
      • ammarben
        • May 2013
        • 63
        • algeria
        1- perhaps L2 cut no continuity
        2- ther is no feed back pin5 so check R6 and R7
        • kalilinux25
          • Mar 2018
          • 2089
          • ZAMBOANGA SIBUGAY
          pin 6 has no voltage readings
          • kalilinux25
            • Mar 2018
            • 2089
            • ZAMBOANGA SIBUGAY
            r6 and r7 has a coreect value
            • kalilinux25
              • Mar 2018
              • 2089
              • ZAMBOANGA SIBUGAY
              pin 5 no voltages
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                You didnt answered what is on pin14/15
                • kalilinux25
                  • Mar 2018
                  • 2089
                  • ZAMBOANGA SIBUGAY
                  pin 14 has 5v 15 has 3.3v sir sorry for late replies
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Try replacing the IC-may be bad.
                    • kalilinux25
                      • Mar 2018
                      • 2089
                      • ZAMBOANGA SIBUGAY
                      Thanks sir Ill replace it and update you sir
                        • 21133
                        In your first post you say the chip is a rt8239b B ,the picture you posted is the A version. Make sure you have the correct part on the board,check the boardview
                        • kalilinux25
                          • Mar 2018
                          • 2089
                          • ZAMBOANGA SIBUGAY
                          do you have a boardview sir?
                          • kalilinux25
                            • Mar 2018
                            • 2089
                            • ZAMBOANGA SIBUGAY
                            Rt8239b
                            • stingerchamp
                              • Sep 2020
                              • 425
                              • Pakistan
                              Voltage on all pins?
                              Do you have same issue or resolved?
                              • Tynan Dill
                                by Tynan Dill
                                Assuming...
                                11-22-2024, 01:46 PM
                              • PantherDave
                                by PantherDave
                                Hi all!
                                05-29-2024, 02:01 PM
                              • GLISIT
                                by GLISIT
                                01-16-2025, 02:29 PM
                                03-31-2024, 02:12 PM
                                09-06-2024, 05:59 AM
