z5wah la-b161p
  • pippo_one
    • Aug 2010
    • 127
    • Vicenza
    z5wah la-b161p
    Hi
    I have a mainb LA-B162P (cpu i5 + nvidia gpu) which sometimes turns on and after a few seconds turns off and on again as a continuous loop. or it stays on expelling heat from the fan that runs normally, but in both cases always with the black screen both internal and external, sometimes I appreciate a backlight flash for a second in the internal monitor.
    i downloaded the schematic and i went to check all the voltages of the mainb and i'm ok, so i thought it was a problem with the bios ... i argued about everything and more but i have so much confusion about the procedure of how to flash from a machine that turns on electrically but does not send any signal on the screen .... KINDLY someone can teach me the steps to perform
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: z5wah la-b161p
    Find the PLT_RST signal on the mainboard and measure its voltage.
    • pippo_one
      • Aug 2010
      • 127
      • Vicenza
      Re: z5wah la-b161p
      Dear Caspian, I identified PLT_RST in the "U30" ic
      pins 1 and 2 are 3.36 volts to pin 4 there is 3.36 volts
      but when the mainb turns off and the loop starts again the voltages go to 0 volts
      pls ...any other suggestions?
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        Re: z5wah la-b161p
        have you reprogrammed the Bios chip?
        Usually, two or three different Bios dumps should be tested to reach a conclusion whether the issue is Bios or not.
        • pippo_one
          • Aug 2010
          • 127
          • Vicenza
          Re: z5wah la-b161p
          Hello, as specified above I have followed several tutorials to reload the bios in the cmos ... but none were successful ... I ask please if anyone has a bios for this mainb ... but above all if you can teach me step to step how can I rewrite the bios in the cmos, and if you need some tools
          • caspian
            • Oct 2015
            • 1591
            • Laptop
            Re: z5wah la-b161p
            You need an external Flash programmer. Desolder the Bios IC and reprogram it using the programmer.
            There are many videos and tutorials on the net that teach Bios programming an external Flash programmer.
            • pippo_one
              • Aug 2010
              • 127
              • Vicenza
              Re: z5wah la-b161p
              Hi, I bought a new EZP2019 programmer and I am ready to program the bios, (I have seen some tutorials and I think I am able to do it) so in summary I have a z5wah la-b162p i5 with Nvidia gpu with i / o ENE and cmos bios eFEON qh64-104hip
              please does anyone have a bios for this mainb?
              also I happened to have an identical mainb with the same problems always with ENE but the cmos bios is a WINBOND 25q64fvsiq
                • 22024
                Re: z5wah la-b161p
                Post your request and bios backup in the "BIOS Requests ONLY!" forum please -
                https://www.badcaps.net/forum/forumdisplay.php?f=40
                  • 22024
                  Re: z5wah la-b161p
                  Try on battery only,charger only and charger plus battery.Remove charger and battery,press power button for 10 seconds, then disconnect the LVDS screen cable and connect to external, try again.
                  • Stephen
                    MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                    by Stephen
                    MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                    03-15-2024, 09:37 AM
                  • www
                    LG L192WS-BN backlight turns off after 1 second
                    by www
                    I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                    I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                    03-24-2024, 05:26 PM
                  • zklgfs
                    Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                    by zklgfs
                    I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                    08-11-2025, 02:14 PM
                  • andrhouseolly
                    Dell Precision 5510, AAM00 LA-C361P Rev:2.0 turns on, no image.
                    by andrhouseolly
                    Hi.
                    I kindly ask you to help me solve the problem.
                    Dell Precision 5510, motherboard AAM00 LA-C361P Rev:2.0
                    The board turns on, there is no image.
                    Read more. When the power supply is connected, the front panel indicators light up briefly.
                    When you press the power button, the button indicator lights up. The board works
                    there is no image, there is no matrix initialization, there is no image on HDMI.
                    When turned on, the fans do not spin, but when they warm up they start spinning.
                    When you turn off the button, the fans spin up to full speed for a short...
                    05-11-2024, 03:14 PM
                  • pippo_one
                    la-b162p need Bios
                    by pippo_one
                    Hi
                    Now I bought a new EZP2019 programmer and I am ready to program the bios, (I have...
                    05-02-2021, 06:11 AM
