Hello everybody . I have an Asus laptop that turns on but does not display the screen. I continued with the voltage measurement.19 v is ok 3.3v is ok 1.5 volts in RAm is ok. but in cpu I do not have 1.0v or 1.2v ... how much can the processor have. And the processor was cold ,, .. After some measurements I noticed that PQl8104 was short. I removed it and replaced it with mosfet 6414A I do not know if it is a choice but please tell me .. I put it in the charger I see that the cpu is hot but there is no image. I did the bios that I found in this forum but again the same problem After the voltages in Pl8102 it is 0v and in Pl801 it is 0 v..This laptop has NCP81216A chip. Please tell me what I can do to diagnose the problem. Thank you   This is board view ....And the FAn not spining . I try to turn of laptop but turn on agin for 2 sec.
					Asus x541u vcc core missing
 Re: Asus x541u vcc core missing
 B+ is the main 19v rail.
 0.3 ohm is a short. This plus CPU heating up is not good news. Interrupt the VCORE power line as close to the CPU as you can and measure the voltage on it. If the voltage is normal after you replaced the mosfet, and the mosfet you replaced was the high side switch, then there is a good chance the 19v went straight into the CPU and you now have a donor board...Comment
 This means there's a short in the CPU and its pulling down the voltage, which is why you should test it by interrupting the VCORE line to verify it. Pull out the coil or some other component in the path to the CPU to verify. However, it does appear that your CPU is dead...Comment
 I dont know what PL801/802 do. I cant open boardview because im at work.
 What do you mean you "closed" the line? The 0v you're seeing is because the short on the CPU sends the voltage to the ground. This is why I am telling you you need to _disconnect_ the CPU to verify that the voltage goes back to normal when the CPU is disconnected.
 ok pl801 and 802 are behind the mosfet that supply the processor with voltage. that should give 1.5 volts or less .. when I disconnect these I have no voltage. yes it is logical not to give because the cpu is in shorttt ... In processor i have 1.0 v coming from 2 points pjp 8104 and 8303. when I disconnect these laptops it turns on for a while and turns off .. now I have left only pjp 8303 connected and the cpu heats up a bit. pjp 8104 connect +vccsa and +vcccio_cpu pjp8303 connect +1.0vo and +1.0vsusLast edited by arber1232; 12-04-2020, 06:27 AM.Comment
 i mean i cut lineI dont know what PL801/802 do. I cant open boardview because im at work.
 What do you mean you "closed" the line? The 0v you're seeing is because the short on the CPU sends the voltage to the ground. This is why I am telling you you need to _disconnect_ the CPU to verify that the voltage goes back to normal when the CPU is disconnected.Comment
 If that's the case, I'd put an oscilloscope probe on mosfet gates. If nothing's there, then check enable signals on the DC-DC converter that feeds it, then the converter itselfok pl801 and 802 are behind the mosfet that supply the processor with voltage. that should give 1.5 volts or less .. when I disconnect these I have no voltage. yes it is logical not to give because the cpu is in shorttt ... In processor i have 1.0 v coming from 2 points pjp 8104 and 8303. when I disconnect these laptops it turns on for a while and turns off .. now I have left only pjp 8303 connected and the cpu heats up a bit. pjp 8104 connect +vccsa and +vcccio_cpu pjp8303 connect +1.0vo and +1.0vsusComment
 0.3Ohms on cpu line may not be short as cpu is soldered. +1.8V is present?? Check all pwrgood signals.Comment
 CPU VCore should be around 6 ohms to ground.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
 PL8101 is iGPU VCore but it should be around the same value than CPU VCore.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
			This specification for the ASUS ZenBook 14 Gun Grey FHD (1920 x 1080) 16:9 Intel Core i5-10210U Processor NVIDIA GeForce MX250 512GB M.2 NVMe PCIe SSD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14 Gun Grey FHD (1920 x 1080) 16:9 Intel Core i5-10210U Processor NVIDIA GeForce MX250 512GB M.2 NVMe PCIe SSD boardview and 14 Gun Grey FHD (1920 x 1080) 16:9 Intel Core i5-10210U Processor NVIDIA GeForce MX250 512GB M.2 NVMe PCIe SSD schematic. Our users have donated over...09-06-2024, 05:30 PM
			by plummmmI am trying to identify a potential missing component from an Asus X570-P motherboard. I could not find a boardview for that exact motherboard, but I did find one for the X570-Pro here https://www.badcaps.net/forum/troubl...prime-x570-pro
 The component missing on my board I believe is a small 3 pin device above the Nuvoton Super IO. The X570-Pro uses a similar Nuvoton and there's a similar looking SMD just...
			by Balu56Hello everyone,
 I'm facing an issue with a PlayStation 5 (Model EDM-010) that I'm currently stuck on, and I was hoping to get your advice.
 Problem Description & Symptoms- When I press the power button, the console beeps once briefly.
- After that, nothing else happens (no blue light, no fan activity).
 Troubleshooting & Measurements So Far
 I have already taken the following diagnostic steps:- Power Supply: I've removed and tested the PSU. It provides a stable 12V.
- Visual Inspection: I inspected the motherboard under a microscope
 10-16-2025, 08:03 AM
			by khabibASUS STRIX G531GT MISSING PM_SLP_SUS#
 Hello guys i have ASUS laptop that power on but can't switch ons , i trying using power sequence and last missing PM_SLP_SUS# .
 here what i measure already:
 EC_RST# 3.3V
 SRTCRST# 3v
 +3VA_RTC 3V
 RTCRST# 3V
 ME_SusPwrDnAck 0V
 AC_PRESENT 3.3 V
 AC_IN_OC# 0V
 PS_ON 3,3V
 +3VA_DSW 3.3V
 DPWROK_EC /R 3.2V
 PM_BATLOW# 3.3V
 SM_INTRUDER# 2.8V
 PM_SLP_SUS# -----> MISSING VOLTAGE ( but sometime this voltage is present )
 THat is can confirm PCH relate issue...05-28-2024, 01:30 AM
			by gurj1979Hey guys.
 Need help with this one.
 Fan not spinning due to missing PWN Fan signal.
 Also 5 seconds from powering up it freezes, unless in BIOS.
 But as soon as Windows starts to load, it will freeze.
 CPU is COLD / Room temp when it freezes.
 I've replaced the CPU, same problem.
 Replaced SIO/KBC IT8987e and reprogrammed - same problem.
 Replaced fan - same problem.
 Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
 Checked the Thermal sensors around CPU and Board to the SIO/KBC and...08-19-2024, 05:22 PM
- Loading...
