Help 820-3437-B NO power on
  • brumbrum
    • Sep 2016
    • 24
    • Italy
    I have a 820-3437-B macbook Air, and I need your help cause it's a really weird case.
    At the benginning, it was dead, so here what I did:
    - Replaced SMC from an identical donar board
    - Removed one dead Ram chip that become really hot and was shorted, so now there are only 6gb on board and nomore 8gb
    I thought it was ok after these fix, but now the behaviour is really strange:
    With dc magsafe plugged only on board disassembled from macbook:
    • All voltages look good, I get even VCORE, about 1.7volt
    • I get 1 second green light, after stuck on orange light, fan start and stop spinning (like an smc reset), and after that speeds until max full ramp
    • If I plug an usb mouse is powered only 1 sec meanwhile fan starts after stop
    With board assembled on macbook:
    • Battery is charging
    • no charm, no video, no backlight, nothing
    • I get 1 second green light, after stuck on orange light, but fan is stuck slow spinning, like a good boot, and cpu is hot, but nothing happens
    • If I press power button on Mac with magsafe connected I can reboot it, it's responsive; with only battery charged and no magsafe, if I press power button no response
    Can you give me any advice or explain me what is happening? I'd really appreciate it, thank you
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: Help 820-3437-B NO power on
    Board won't POST without all RAM chips. Should probably cause 3 beeps but not sure.
    • brumbrum
      • Sep 2016
      • 24
      • Italy
      Are you 100% sure? Avtually I don't have any beep.
      So should I replace all 4 ram chips?
      • zpi
        • Feb 2018
        • 132
        • Lithuania
        You can put identical one back. Board will not post woth three ram chips 100%
        • brumbrum
          • Sep 2016
          • 24
          • Italy
          I soldered a new one, now full ram, but same identical behaviour
          • zpi
            • Feb 2018
            • 132
            • Lithuania
            Is ram identical? It cannot be from diffrent manufacturer
            • brumbrum
              • Sep 2016
              • 24
              • Italy
              yes, from the same donar board of smc, same part number and same brand
              • zpi
                • Feb 2018
                • 132
                • Lithuania
                I guess smc is also from same part number logic board? Also did you tryed smc bypass mode?
                • brumbrum
                  • Sep 2016
                  • 24
                  • Italy
                  Yes of course, from a same number model board that I bought appositely.
                  Thanks for the tip, But if I keep pressing power button and connect magsafe (with or without battery it's the same) I got only orange light and fan is not spinning. When I release the power button, Green light for 1 second and after orange, but fan is spinning and same behaviour like described in first post
                  • brumbrum
                    • Sep 2016
                    • 24
                    • Italy
                    I changed also bios from donar board.. but still nothing
                    • zpi
                      • Feb 2018
                      • 132
                      • Lithuania
                      Does board make two bootloops as it should? Also check all spi rom termination resistors and vias
                      • brumbrum
                        • Sep 2016
                        • 24
                        • Italy
                        could I get S0 and Vcore if any spi were missing?
                        • zpi
                          • Feb 2018
                          • 132
                          • Lithuania
                          Yes, CPU is reading EFI, and to do that it needs vcore.
                          • piernov
                            • Jan 2016
                            • 4437
                            • France
                            Most of the time these boards will power cycle before VCore can even turn on if there's an issue around SPI ROM, because the PCH cannot read the soft straps.
                            • brumbrum
                              • Sep 2016
                              • 24
                              • Italy
                              All SPI are good. I'm starting to think that the problem is the cpu/gpu
                              • envym
                                by envym
                                Hi everyone!
                                06-27-2025, 08:54 AM
                                MagSafe Audio Board MacBook Pro 15" A1226 Left I/O 820-2102 Boardview
                                MagSafe Audio Board MacBook Pro 15" A1226 Left I/O 820-2102 Boardview...
                                10-28-2024, 03:29 AM
                              • shivahoj
                                Macbook A1297 Mid2010 820-2361a Magsafe schematic?
                                by shivahoj
                                Hello, the Magsafe connector of the above Macbook was defective(burnt pins). It is located on a small DC-IN board labeled 820-2361a sitting in the top right corner of the macbook, connected to the main PCB with 5 separate cables.
                                While replacing the magsafe, I must have unsoldered and lost a small SMD Resistor that is silkscreen-labeled R1 on the solder side(opposite of the magsafe and ferrite filter). It carries the 1bit-bus to the Amber/green LED driver chip in the Magsafe plug, and without connection to the 1-bit chip in the plug, the macbook won't charge.
                                ¿Can anyone please provide...
                                12-31-2020, 08:13 AM
                              • Flasman90
                                Macbook Pro DFU Restore Issues
                                by Flasman90
                                I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
                                - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
                                - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
                                08-30-2025, 10:27 AM
                              • paparazzo79
                                Charging macbook pro mid 2014 15" with magsafe 2 60W charger
                                by paparazzo79
                                Hi guys.
                                May I charge this model with 60 W charger?
                                I know it requires 80 W to charge, but don't want to buy one.
                                If it specifically requires and 60 W can damage macbook and vise versa, I guess I will have to buy 80 W one....
                                09-28-2024, 02:47 AM
