A1990 won't turn on.
  • MicroSMD Lab
    • Sep 2018
    • 145
    • Trinidad and Tobago
    Hi, I'm working on an A1990 820-01041-A macbook pro. 5.10V, 0.02A on USB-C meter. PPBUS_G3H seems to be shorted, 0.8ohm across C3501.
    This is my first touchbar repair and I know that the ISL9240 is very difficult, if not impossible to find so I want to be very careful. I used voltage injection to locate shorts before but I just want to make sure that this is a good method for this model macbook. What is the maximum voltage/current I should use? Is it a good idea to remove F7000 and F7001 and test for short again to see if the short is on PPVBAT_G3H_CHGR_REG?
  • MicroSMD Lab
    • Sep 2018
    • 145
    Re: A1990 won't turn on.
    Oh, and I forgot to mention, no physical damage observed, no corrosion. I checked all the large inductors and the only ones that were low ohms were L7330 (15.3ohm) and L7420 (5ohm) but both are CPU lines so I'm thinking these values are not unusual.
    • piernov
      • Jan 2016
      • 4435
      • France
      Always start at 1V, limiting current isn't really needed, make sure no large BGA is heating up, increase voltage if you can't find anything heating up.
      Yes you can isolate the circuit by removing F7000 and F7001. It's very likely that the short to ground is on the system side.
      • MicroSMD Lab
        • Sep 2018
        • 145
        Ok, so reading another thread about troubleshooting a short on PPBUS_G3H, I saw that you recommended testing inductors against PPBUS_G3H.
        Doing this I got L7420 = 5.7ohm (PPVCCGT_CPU_PH2), LA340 = 3ohm (PPVCORE_S0_GFX_PH3) which are 1.5V and 1.0V respectively. Since PPBUS_G3H is a 0.8ohm short I'm thinking it's safe to go ahead with the voltage injection but I just want to be sure.
        I'm thinking that since my short is very low that this may not be necessary but I still have a lot to learn so my level of uncertainty is high...lol.
        • piernov
          • Jan 2016
          • 4435
          • France
          Yes with a 0.8ohm short to ground it's unlikely that there is a high-side MOSFET shorted. On this board, there shouldn't be any power rail with this low resistance to ground. On some other boards (like with 1000-series or newer NVidia GPU) it could be the case so you always have to be careful.
          So always start with 1V and check if any BGA die warm up. If one of them is warming up stop injecting voltage and find the shorted high-side MOSFET.
          • MicroSMD Lab
            • Sep 2018
            • 145
            Voltage injection went well, I started at 2A then 3 then 4. I was able to feel a little warmth at 4A after 5-6 secs. C9081 was shorted. There was a little corrosion which I missed because that was the only area of the board that had a little dust and I did not clean it.
            Replaced the Capacitor and the board seems to be booting, 19.7V and current made it up to 1.4A then leveled around 870mA. When I put the board in the machine and connected everything it did not boot, the current leveled out to 30mA, voltage was still 19.7V.
            I disconnected everything and tested the board outside again and it leveled out to 870mA again. Put it back in, connected everything one by one and tested, got fanspin and current peaked around 1.4A, leveled around 900mA then dropped a little lower, fanspin was continuous up to the LCD connection which I did last, then no fanspin, current went to >1A then leveled out to 30mA.
            I did not use the LCD bracket, not sure it that is an issue.
            I looked at a video where Paul Daniels said some of the LCD cables were problematic.
            I don't have USB C to HDMI so I can't test with external monitor at the moment.
            Last edited by MicroSMD Lab; 10-07-2020, 05:31 PM. Reason: Forgot some information
            • MicroSMD Lab
              • Sep 2018
              • 145
              Ok finally got my USB C hub and the system boots fine with an external display. I checked the LCD daughter board but no physical damage. Didn't remove the LCD connector from the logic board side yet, hopefully the issue is there. If not, I'm not sure where to start looking.
              • MicroSMD Lab
                • Sep 2018
                • 145
                Ok, so I removed the LCD connector from the logic board and no signs of physical damage. I did diode mode checks on the pins and the only ones that stood out are 10, 16 and 43 which read OL and of course pin 14 but that's unconnected. I'm thinking pin 10 should be OL but I'm not sure about pins 16 and 43. If this is similar to iPhones in any way, maybe the face time camera could be faulty? Not sure how to move forward.
                • MicroSMD Lab
                  • Sep 2018
                  • 145
                  Well after doing diode mode readings on the LCD, I was satisfied enough that it had to be something that would only show up with the both parts connected (LCD to Logic board) then I wondered if I needed to have the lid open. Now I feel so dumb.
                  System boots fine. Thanks for all the help as usual piernov and I always take no response from you as "you need to give me more to work with" so I keep digging.
                  • pajdek
                    Lenovo Y700-17ISK turn on and off
                    by pajdek
                    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                    09-20-2023, 02:49 AM
                  • evandrocarlosv
                    MacBook Pro A1990 15 2019, motherboard 820-01814-A, won't turn on.
                    by evandrocarlosv
                    I have this machine, one of the few that arrives on the bench without a short on PPBUS_G3H. At least these voltages are present. I also have the PP3V3 voltage on L7660 and P5VG3 on L7600. I'm not used to dealing with machines where the shorts are not on PPBUS_G3H, so I need help from my colleagues to analyze where this sequence is failing. From what I've measured, the SSD voltages are fine.
                    The analyzer shows it as seen in the attached photo....
                    11-25-2024, 05:23 AM
                  • RdeveLabs
                    MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                    by RdeveLabs
                    To all the members here...
                    Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                    So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                    05-05-2025, 04:59 AM
                  • robante15
                    Acer Aspire 4520 won't turn on after reboot
                    by robante15
                    Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                    It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                    The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                    If I remove the...
                    04-06-2024, 06:50 PM
                  • masoksian
                    Dell latitude e7470 not turn on .power buton on off and Run Power problem
                    by masoksian
                    I am dealing with the problem of turning on and off my Dell e7470 notebook.
                    The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                    The system does not turn on, there is no post.
                    I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                    The problem continues in the same way.
                    I tried to turn on the Fn key, nothing came to the screen....
                    02-15-2025, 12:08 PM
