Missing 3.3va on Acer 14
  • lezsimply
    The Wanderer
    • 645
    • Philippines
    Good day everyone. I have an Acer One 14 (Z1401-C9JN) with board model NCBT411 ver 2.0, that's missing 3.3va. It has a 5v to 3.3v converter which is supplied by 5va.
    As you can see in the image, 5va is present on red circle c171, c197 and c164. But no output on L7 coil. Found out that output rail is shorted to ground. I removed c179, c199 and c169 cirlced in yellow but short still remain. components circled in light blue is not present (na). It's still shorted even after I removed ic u7.
    Does that mean I need to check all components that is supplied by 3.3va to find short? For the start I removed ic u20. Short still there.
    I have attached schematic here. Hope to hear some advice. Thanks
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3601
    • slovakia
    Re: Missing 3.3va on Acer 14
    locate shorted component by injecting 3V 2A and check for heating component by hand and if u locate area pour some IPA to locate burning component
    if u cannot locate area go higher with current because if u have shorted big IC it can dissipate a lot of heat
    • Duranitron
      • Jul 2014
      • 544
      • Philippines
      Never stop LEARNING because life never stops TEACHING!
      • Duranitron
        • Jul 2014
        • 544
        • Philippines
        in my opinion for short circuit i started first with 1v 1A oncrease the wattage as you progress too much wattage can burn off small pcb tracks .. trace all the circuit that uses 3.3v
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3601
          • slovakia
          not needed to start with 1V on 3.3V rail. this voltage u r using only on main 19V rail when u dont know if u have shorted highside mosfet so u need to start on 1V because of CPU and GPU
          1Vx1A= 1W that is way too small heat to feel it
          • lezsimply
            The Wanderer
            • 645
            • Philippines
            Sorry guys for very late reply. Tried injecting 1v to 3v, there's no component heating up. But when I use charger the only component getting hot is the cpu. No luck on finding any.
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3601
              • slovakia
              what was current consumption when inect 3,3V?
              • lezsimply
                The Wanderer
                • 645
                • Philippines
                unstable 0.06 amps. Sometimes it goes 1.16 then goes low again. weird
                • ktmmotocross
                  Boardkiller
                  • Feb 2014
                  • 3601
                  • slovakia
                  u r searching for short, why u use charger?
                  • lezsimply
                    The Wanderer
                    • 645
                    • Philippines
                    I used both bench supply and charger. So far processor is the only one heating up. On charger it can easily heat up but on bench supply it takes about 15v.
                    • Spider1211
                      • Oct 2019
                      • 532
                      • Mauritius
                      Is SoC itself getting hot or something near it? If it is the SoC, which part is getting hot? The PCH side (small square) or the CPU side (rectangle shape)?
                      • lezsimply
                        The Wanderer
                        • 645
                        • Philippines
                        Only the processor is installed on this motherboard. Please check image.
                        I got new development. I cleaned motherboard with 90% isoprophyl. Now 5v and 3.3v are present. When I press power button laptop turns on but turns off after 10 to 12 seconds initially.
                        I'm checking diagram for power sequence to see if any voltage missing. I'll get back soon. Thanks. Spider.
                        • Spider1211
                          • Oct 2019
                          • 532
                          • Mauritius
                          Your board is NCBT411 and schematic is for NCBT419, are they similar?
                          Glad to hear you have 3.3V again though. Any history of the laptop? Was it water damaged, etc?
                          • lezsimply
                            The Wanderer
                            • 645
                            • Philippines
                            So far everything looks similar and also I found this pdf here but its difficult to navigate as it redirects to some page.
                            Owner told me they use laptops usb port for charging most of the time. When laptop is on, they close lid then charge tablet or phone on usb and leave it. Then one day it didn't work.
                            That's the first thing I checked, no short on usb port supply.
                              09-06-2024, 05:27 AM
                            • Kshi
                              acer a515-52g-4830 5valw 3valw missing
                              by Kshi
                              hello,
                              this is my third time trying to revive dead laptops.
                              I got this acer does not have power light
                              First I test
                              dc 19v-ok but +5valw and +3valw is missing
                              i remove the board to test more but i didnt find anything
                              no shorts no corrosion
                              but i get +3vlp and +5vlp present
                              and now i dont know what to do anymore
                              hope someone can help me and improve my skill
                              Link to schematic - https://www.badcaps.net/forum/troubl...nd-mobile-devi...
                              07-24-2025, 12:22 PM
                              Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook 3 Specification for Upgrade or Repair
                              This specification for the Acer Swift Acer Swift 3 Ultraschlankes Notebook Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 Ultraschlankes Notebook boardview and Acer Swift 3 Ultraschlankes Notebook schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                              09-07-2024, 05:00 AM
                              Acer Aspire Acer Aspire 7 Charcoal Black Notebook 7 Specification for Upgrade or Repair
                              This specification for the Acer Aspire Acer Aspire 7 Charcoal Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire 7 Charcoal Black boardview and Acer Aspire 7 Charcoal Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                              Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                              This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                              09-07-2024, 04:10 AM
