GPU common problem
  • myth77
    • Feb 2017
    • 380
    • Croatia
    GPU common problem
    Usually when i detect that cpu or gpu are dead i dont repair such motherboard because first i dont have equipment and its too much trouble...But i have seen often lately the same graphic problem and now i am couries what is it?
    So i attached the picture and its allways looking the same as in the picture...As far as i remember most of the gpu-s were gtx 1060, gtx 1070, maybe even r9-290...
    So, is this from picture gpu dead or vram or? what is your expirience on this?
  • peste
    • Dec 2016
    • 12983
    • ROMANIA
    Re: GPU common problem
    in my opinion video chip ..you can try heating the video chip..with great care ..use flux paste..only to test ...
    • dellxps15
      • Feb 2014
      • 1591
      • italy
      me too would think of gpu problem...
      • Duranitron
        • Jul 2014
        • 544
        • Philippines
        reflow will cure it.. if not.. u need to replace the gpu...if thats an old laptop.. try to test the ddram usually some laptop uses the high mem of the ram to use as video ram.. hope this helps...
        Never stop LEARNING because life never stops TEACHING!
        • mosfetratus
          Sure Not
          • Feb 2019
          • 174
          • Resistron
          mostly faulty GPU chip, you can run furmark to crash it.
          • jasko_jacker
            • Oct 2014
            • 1137
            • italy
            Since 25 years of experience with gpu. A rework, reflow
            , Etc, don't solve the problem, only a new chip from
            a good seller soldered with a proper equipment can definitely solve thus type of issue.
            Personally I use only Bga removed mechanically (with a CNC) from a donor board.
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3609
              • slovakia
              it depends on chip and its condition. have MANY reworks that works until now like 5years
              • Deusjevoo
                • Sep 2010
                • 21
                Curious how you do that.
                Isn't removing a (underfilled) BGA with CNC to preserve the PCB to accept new or donor chips ?
                Destroying the BGA in the process ?
                Don't see why a normally lifted BGA wouldn't be usable again?
                Doing it for years without problems, no need for CNC, reball it and and runs for years again.
                • jasko_jacker
                  • Oct 2014
                  • 1137
                  • italy
                  CNC Is a good method to have a unstressed bga,
                  especially for cpu that has distortion problems. It"s (you do not put the whole board under the CNC but only the area that concerns the chip) has advantages, the chip can be resold because it does not show signs of heat, and if you do a laser reballing the condition Is like new.
                  about the duration of the reflow it's a matter of luck and I can't risk working on the same card twice after the customer has paid a lot for the repair.
                  • Duranitron
                    • Jul 2014
                    • 544
                    • Philippines
                    i rather stick to may bga rework station in pulling out bga chip.. if you have a good reflow profile it can safely remove the chip without the stress on the chip.. my opinion..
                    • jasko_jacker
                      • Oct 2014
                      • 1137
                      • italy
                      It is also my opinion with some chips, for example hm170 or similar, but with bga especially the U series (6500U, 7500U, etc) or high-end GPUs (which absorb a lot of heat especially during the desoldering phase) I prefer to have more possibilities . The problem as everyone knows is the medium and long term duration (normally I provide a six month warranty). Intel, for example, recommends that 3 heating cycles not be exceeded
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3609
                        • slovakia
                        plus i preffer baking ic on 130c one hour before procedure
                        • Duranitron
                          • Jul 2014
                          • 544
                          • Philippines
                          i agree. to prevent popcorning ..
                          • Weelcup
                            TopTech
                            • Oct 2017
                            • 302
                            I was wondering if the leaded balls are feasible to replace the lead free balls on high end cpu or gpu as it have a lower melting temp and therefore a lower heat risk during the soldering process.
                            • jasko_jacker
                              • Oct 2014
                              • 1137
                              • italy
                              Yes it is possible, however there are some problems. The pads on both the board and the chip must be very clean:
                              if too much lead-free alloy remains and a solder profile is used for the classic sn / pb alloy it is possible that (especially on large copper areas) the soldering is not complete (semi-liquid alloy).
                              In my opinion it is advisable to use a slightly higher profile,
                              around the 205 below the chip, pay attention to position the thermocouple well for those who use an air top heater, (the air flow must not touch the thermocouple) and use a flux for the lead-free alloy.
                              • piernov
                                • Jan 2016
                                • 4437
                                • France
                                When I replace a chip I always reball it with leaded solder beforehand. It takes time and it's pretty annoying especially with low quality stencils, but much less trouble when soldering without the proper equipment. I haven't found a usable direct heat stencil for Skylake-H yet for example…
                                If you have a good BGA rework station with a good profile and not too much humidity, you'll save a lot of time (and sanity) by putting the chip as-is with lead-free solder.
                                • Weelcup
                                  TopTech
                                  • Oct 2017
                                  • 302
                                  Super.
                                  I have had some gtx1050 and 1060 replacements with leaded balls. Also worked for i5 8300h i7 7700hq.
                                  The reason i asked was to make sure the that my job will last for long from solder ball types prespective.
                                  And yes i fully understand that point. I usually remove all the leadfree residues from the board by leaded tin. Before using desolder coper.
                                  Honestly, after replacing the gpu i felt a lower performing temperature which was very surprising giving the fact that leadfree is lower resistant than leaded ! But the fans run very smoothly.
                                  I chip like gtx1060 is relatively heavy. I am not sure about 205c with leaded balls. I usually use 200 at max for rich copper boards (thick boards) but 195 at max for others.
                                  • Weelcup
                                    TopTech
                                    • Oct 2017
                                    • 302
                                    Thanks,
                                    It is actually a night mare without stencil. I have a bit of a shaky hand and it takes hours to put the balls in place. I have had a long journey with proper stencil until recently i found one source on aliexpress who sell a bit more expensive but honestly he deserve every penny. You will never regret mate... try one and i am sure you will buy all the set from this store...
                                    andi CO.,Ltd Store
                                    https://a.aliexpress.com/_BOAZax
                                    I am pretty sure this will help you... 100% fit no stencil bent even with U series CPUs like i7-7500U...
                                    • Duranitron
                                      • Jul 2014
                                      • 544
                                      • Philippines
                                      Thanks,
                                      andi CO.,Ltd Store
                                      i agree.. putting leaded solder balls keep less stress to the bga chip.. in my opinion i always buy good bga chip with leaded balls already on it in that way... you only need to keep the moisture out by heating the chip to 100 - 130 degrees for 1 or 2 hours before fussing it to the mobo.. make sure to use the best temp profile...
                                      • Deusjevoo
                                        • Sep 2010
                                        • 21
                                        @Duranitron If you "always buy good bga chip with leaded balls already on it" you always buy REFURBISHED BGAs.
                                        New BGAs are lead free only.
                                        Which is why I prefer reballing myself as I know it's an original chip, no risk buying a fake one.
                                        • theone111
                                          by theone111
                                          3. Problem: TV shuts down
                                          07-22-2024, 10:36 AM
                                        • yoritomo
                                          Sony KDL-37EX402 the TV in dead, no LED, motherboard problem.
                                          by yoritomo
                                          Hello
                                          The TV does not show any sign of life , I started the troubleshoot as this , no power Led, no reaction when pressing the power button.
                                          I checked the Power coming out from the power supply, the 3.3V_standby is correct and steady, then I checked the 1.2V_standby produced by IC6001 which Is good as well.
                                          So I decided to control the main IC , IC4000 , he does not output any oscillation on the Xtal, Then I am now bloacked there.
                                          The schematic is downloadable at Eletrotanya website , the schema is weird because the processor is not represented...
                                          01-23-2025, 05:55 AM
                                        • Zeonalbasta
                                          Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                          by Zeonalbasta
                                          i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                          The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                          09-13-2024, 01:17 PM
                                        • Crystaleyes
                                          Dead Roland AX synth - Capacitor problem?
                                          by Crystaleyes
                                          Got a question regarding how best to identify what the problem is on the main pcb of this Roland synth.
                                          Symptoms are, that it turns only for a second... All the lights and display flash, then it turns off.
                                          I had thought it could be a shorted cap so removed the main pcb and tested all the caps for a short to ground using a resistence tester, however none were.
                                          Next I pulled out the Chinese T7 component tester and found 7 caps which are connected in parallel, all reading 36pF (when these caps are rated between 470 and 10uF). None of the other caps on the...
                                          07-28-2023, 06:28 AM
                                        • Gibon378
                                          Problem with stopping audio and video for no reason
                                          by Gibon378
                                          PC Specs:
                                          • CPU: Ryzen 5 1600
                                          • GPU: GTX 1080 Palit JetStream
                                          • MOBO: ASRock ab350 PRO4
                                          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                          • PSU: XFX 650W (don't remember what model)
                                          • OS SSD: ADATA SP920
                                          • OS: Windows 10 21H2
                                          Problem description:
                                          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                          11-19-2022, 09:41 AM
