hitachi flora 270gx bugs
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    oh dear, where to start?
    this used to be my laptop, but by dad is using it now.
    it was iffy now and then, but all was well last time i used it.
    but now, with the addition of a 60gb hd and xp home, something unrelated happened:
    the f2 ans 2 keys do not work. not in bios, not in windows. external keyboards via usb or ps/2 work fine.
    i assume it could be a lose ribbon cord
    note- it is a rare Japanese import, but the parts are acer- including the keyboard which had an acer no. on it last i checked.
    also, do you think its worth a battery? it has a hollow dummy unit now. i once tried to fix it but the batteries were turds which i sent back for refund.
    sigpic
    (Insert witty quote here)
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: hitachi flora 270gx bugs
    first, happy fingers screwed it up. it should say "the "f2" and "2" keys do not work"
    also,
    update- the "s" key is also not working. all other keys are fine.
    sigpic
    • mockingbird
      • Dec 2008
      • 5484
      I just had an nc4000 with a few keys that did not work. 9,o,l,. and the Windows key.
      It did turn out to be the ribbon, but in my case, you could tell it was the keyboard because of the sequence of the keys (Those keys run in a diagonal line). Luckily, I bought a new keyboard off egay with a few missing keys for like $10.
      It could be the circuitry and changing the keyboard might not help you.
      • OKRPKCOMP
        Hitachi flora se210 need bios
        by OKRPKCOMP
        Need bios hitachi flora se210
        board code micro- star ms-13571...
        03-18-2023, 11:09 AM
      • TheJeanox
        HP x360 14-CD Laptop 3 keys not working (G/H/ESC/) Help please!!
        by TheJeanox
        The laptop suffered a liquid spill which caused the keyboard to be damaged (the liquid did not reach the motherboard).
        I bought the replacement part, when I tested it before assembling it I realized that the aforementioned keys do not work but the keyboard is fine, it was tested on another computer and indeed all the keys work.
        On pin #32 of the keyboard connector there is a voltage of 3v, when pressing the keys that do not work the voltage drops to 1.3v~1.5v but if I press any of the keys that do work the voltage does not drop, at this point I can no longer understand...
        11-07-2024, 12:40 PM
      • nader_guesmi
        Samsung UE65TU7172 – BN41-02751C – CI+ ECP Keys Missing / Digi Card Not Working
        by nader_guesmi
        Hey everyone,
        I’m working on a Samsung UE65TU7172 with mainboard BN41-02751C. The TV powers on normally, I’ve applied the latest software update, and all measured voltages are correct.
        Problem: The CI+ module doesn’t read the Digi card.
        I accessed the service menu (using Mute + 2 + 4 + 7 + Exit) and ran the CI+ test. The results show:
        • CI+ production keys: Success
        • ECP keys: Not installed
        So the TV doesn’t even attempt to communicate with the CAM/card.
        I’ve tried multiple Digi cards (both old and new), and they work fine on another...
        09-09-2025, 03:04 PM
      • tfatt
        Hitachi Flora Se210 Bios Locked x3
        by tfatt
        Hi There,
        Anyone able to help me to look and remove the bios password on this Hitachi Flora Se210 model, (bios password locked).
        Attahced the dump file and screenshots of the bios model....
        10-22-2021, 03:22 AM
      • Jaime Morillo
        Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
        by Jaime Morillo
        Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
        The TV was stuck on the logo and I couldn't access the update menu.
        I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
        The image result was good, but the image is inverted.
        The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
        Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
        08-18-2025, 11:38 AM
