Gateway MA7 laptop won't charge or run off of A/C
+ More Options
Posts
  • theoj
    • Jan 2012
    #61
    Re: Gateway MA7 laptop won't charge or run off of A/C
    A footnote to my above posting. I'm looking at the board through a microscope, looks like two of the tiny black s/m resistors have gone open circuit, the other two read 15ohm in circuit - anyone know the values of these and that of the capacitor (C937) or should I just take a guess!
    • mrdownlow
      • Mar 2012
      • usa
      #62
      I also did 'Dobbers' method with success! Thanks for the tip!!
      • bazthespazz
        • Jan 2011
        • 11
        #63
        I used filesponge's method and it brought my MX6955/MA7 back to life......kind of. Now it won't boot and it tells me no hard drive is found even though when you get in to the CMOS settings it shows the hard drive exists. Thinking maybe the hard drive was corrupt I tried to reinstall XP but got the same message, no hard drive found. Also the charging light has stayed red even though I've had it plugged in for over 3 hours. Could it be a bad battery and could a bad battery keep it from booting?
        • Spitz
          • Oct 2010
          • 95
          #64
          If you are trying to load xp with a sata drive, the problem is there is no sata driver in xp. That is why the operating system does not see the hard drive, but the hardware does. This won't happen if you load vista or win7. You can download the sata driver from gateways site.
          • b700029
            Banned
            • Sep 2010
            • 640
            #65
            The BIOS should also have an option to switch to IDE mode.
            No messing around with drivers then.
            • bazthespazz
              • Jan 2011
              • 11
              #66
              Well I found a copy of XP with SATA drivers and it found my HD and formatted it and installed fine but when it did it's last reboot I got a BSOD that said it experienced an error and it rebooted so fast I couldn't read what the error was. Also, to get it to boot at all I have to remove the battery. I'm going to try to install Win 7 and I'll let you know what happens. Thanks for the help.
              • bazthespazz
                • Jan 2011
                • 11
                #67
                Well I tried to install Win 7 and it won't even boot off the Win 7 DVD. It has no problem booting off the XP CD. Any ideas? Also, it's been plugged in for hours and the charging light is still red and it won't boot at all if the battery is left in it. ??? After checking filesponges pictures again, I just soldered the wire from the center pin of the AC jack to the one leg on the chip closest to the usb ports on the MB. Should I have soldered it to both?
                • Spitz
                  • Oct 2010
                  • 95
                  #68
                  That motherboard has problems on both sides of the power jack so you need to add a wire on both sides of the board. I have repaired about six of these and it is very rare that the jack needs replacing. The tracks on both sides just disintegrate around the center pin.
                  • bazthespazz
                    • Jan 2011
                    • 11
                    #69
                    I used filesponges method but instead of soldering to the center pin of the AC jack on the backside of the board and running the wire through a hole to solder the other end to the chip on the topside, I did all of my soldering on the top of the board. As I mentioned before, I soldered my jumper from the center pin of the jack to the leg on the chip closest to the USB ports. Could you please be more specific as to where I need to run the extra jumper? Also, can you think of any reason why it won't boot?
                    • Spitz
                      • Oct 2010
                      • 95
                      #70
                      On the top side, you need a wire from center pin to chip marked PD1 which you have already done. On the bottom, you need a wire from center pin to caps marked pc1 & pc2 on the side closest to the center pin.
                      • bazthespazz
                        • Jan 2011
                        • 11
                        #71
                        OK, I'll give it a try. Would that explain why the battery isn't charging?
                        • bazthespazz
                          • Jan 2011
                          • 11
                          #72
                          OK, I got it to load Win 7 and everything is running fine, as long as I don't plug in the battery or any USB devices. The USB ports work but if I try to boot with anything attached, including the battery, it hangs at the Gateway start screen. Do you think the extra jumper wire on the bottom of the board will solve my problem. Thanks again for all the help.
                          • Spitz
                            • Oct 2010
                            • 95
                            #73
                            It cannot hurt to try it. Normally the symptoms are that it will not charge or will not start when you press power on. Your symptoms are different. Are you sure your battery is good and not shorted?
                            • bazthespazz
                              • Jan 2011
                              • 11
                              #74
                              Not sure about the battery. I've got no way of checking it and I hate to spend money on a new one if it's really not bad. Any way to check it?
                              • Spitz
                                • Oct 2010
                                • 95
                                #75
                                Not without having access to another ma7 laptop. Do you have a batteries plus store, they will run a test of your battery and tell you if it is any good.
                                The boot problem with the usb I have seen before with desktops too. It may be a setting somewhere. Never took the time to figure it out.
                                • mdavidson
                                  • Apr 2012
                                  I Did The Fix And The Power Supply Is Blinking , I Think There Is A Short Somewhere, Any Help Please, Thanks
                                  • jap1122334
                                    • Apr 2012
                                    #77
                                    Thanks to this fantastic walkthrough another MA7 has just sprung back into life after being hidden in a cupboard for almost 2 yrs many thanks to all involved
                                    • Comfis
                                      • Oct 2011
                                      • 7
                                      #78
                                      Try to change PQ29 AO4407 and capacitor PC34 / near MAXIM 8724E/ .
                                      • Alf
                                        • Jun 2011
                                        #79
                                        Hi anyone i have hp g62 and the led on power only flashing ,,no on
                                        • bazthespazz
                                          • Jan 2011
                                          • 11
                                          #80
                                          Well I picked up a new battery from the "auction site" for $22.00 and I'm up and running. It seems to be charging just fine and it works great on just the battery and boots right up with the battery installed. One last question, How often should the cooling fan kick on? It comes on when you first boot it up but I've been on it now for over a half an hour and it hasn't come on once. Is that normal? Again, I'd like to thank everybody for all their help.
                                          • ipatch
                                            troubleshooting microsoft surface pro 4 no power no led charge light
                                            by ipatch
                                            hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                                            10-05-2023, 11:59 AM
                                          • usyusy
                                            Haier 7g-5h Plug in not charging, only charge when laptop power-off
                                            by usyusy
                                            Hi to all ,
                                            i have Haier 7g-5h laptop, it does not charge while the laptop is power-on, it only charge when the laptop is power-off condition.
                                            any guidance, clue please.
                                            Schematic is attached page 29
                                            11-21-2021, 10:44 PM
                                          • mikey5791
                                            Dell laptop model PP24L won't start from ac adapter
                                            by mikey5791
                                            Dear all,
                                            Bought this used Dell laptop PP24L(studio 1435) in Jan 2022. It was running smooth on 64 bit Windows 7 pro from processor Intel core Duo T6400@2Ghz with 2GB RAM. The laptop battery was charging and working fine until few months back the opening screen will display something like "replacing the battery warning", press F1 to continue. Normally i press F1, the laptop will proceed to Windows and i can use as normal.
                                            But last week, after i pressed F1, the laptop just shut down. I suspected the laptop battery is dead. So i pulled out the battery and...
                                            03-24-2023, 09:06 PM
                                          • versionlab
                                            Weird problem, laptop stays on when connected to another pc
                                            by versionlab
                                            Hi, I want to ask for advice about an interesting issue I've been having with a sony vaio laptop.
                                            Client came and said that "a desklamp touched the back of the lid while laptop was operating normally and it caused the office's circuit breaker to trip. Laptop had never turned on since".
                                            After taking the laptop apart (checked dc adapter everythin ok), I found a faulty MOSFET on the motherboard which I replaced. Laptop managed to turn on. However, while booting it shut down. Nothing else seemed faulty and thermals were ok. Shutting down was coming at random...
                                            10-26-2022, 03:43 AM
                                          • mon2
                                            HP250 G3 Battery not charging
                                            by mon2
                                            Hi. Have a HP250 G3 laptop (schematic attached) that will not charge the battery.
                                            1) The laptop works fine with the AC adapter.
                                            2) The laptop works fine with a pre-charged battery (HP original with 880 cycles). The battery was depleted when brought in for service and we purchased a new clone with 2 charge cycles on it. The clone battery was received DOA and also will not charge with the laptop.
                                            Then we purchased the NLBA1 tool which worked well to ping the clone and HP battery with success. While we could readout the parameters with the I2C / SMBUS...
                                            08-13-2021, 10:28 AM
