Gateway MA7 laptop won't charge or run off of A/C
+ More Options
Posts
  • filesponge
    • Jan 2011
    • 15
    • England
    #41
    Re: Gateway MA7 laptop won't charge or run off of A/C
    Bnash01 - Can you clarify a little, How do you know that your battery is fully charged ? The best way is to test on a fully working 2nd laptop if possible.
    Although a laptop may show the charging & fully charged lights, and may even take an hour or more to charge, the battery can still be faulty (broken circuit or dead or weak battery cells), and it may never be able to start the laptop up again.
    From what I can see, it does sound as if your battery is at fault. There is also a very slight possibility that the laptops charging circuit has stopped working, but that is a very very rare fault. Most likely just a broken battery.
    This will be the same for all laptops, not just the MA3 models.
    • moneypit
      #42
      I'm new to this board basically because I found this post. Do you recommend buying a new piece before doing the jumper mod? Or should I just do the jumper and it should fix this?
      From what I can see the piece looks ok.
      • heathric
        • May 2011
        #43
        obviously a particular unnamed family member tried using the wrong ac adapter when they lost the original, so I inherited a 6518gz with a blown PQ38 and PQ40
        Does anyone have the specs for the PQ38 and PQ40?
        Both of which are burned and cannot be read. Does anyone have the schematic or bom for this board?
        Thanks,
        Heath
        • Volkymaniac
          • Jun 2011
          • 9
          #44
          Hi everyone on this thread!!
          I have a Gateway MX6216 with this problem (thread title) and I can resolve it with the help of all of you. I want to said to everyone here very very thanks. I solder a jumper to the center pin pos of the dc jack to the two common legs of the diode. Everything works great, thanks a lot again.
          • Philface
            • Jul 2011
            #45
            I have one of these faulty MA7's. Anyone know where I can have it fixed?
            • Commander Gizmo
              • Jul 2011
              #46
              I just wanted to say a big thanks to filesponge for his pictures and description of the repair. I was able to use a piece of solid copper wire and bend it to build a new path from the inside the center post to the black fuse. The laptop powers up and works perfectly!
              • Robrote
                • Aug 2011
                #47
                Commander, did you replace the actual plug and do the bypass, or just the bypass?
                • Robrote
                  • Aug 2011
                  #48
                  Great instruction here. Thanks for all who have posted. A couple of quick question for this novice geek who will be attempting this....
                  - Do I need to replace the jack as well as doing the bypass?
                  - What size wire should I use to bypass? Soild or stranded wire?
                  - I'm assuming the M/B needs to be completely removed to attempt this?
                  Thanks in advance.
                  • festerboi
                    • Aug 2011
                    #49
                    Hi
                    i had the same problem on my gateway ma7 so i tried the jumper mod by put a wire from the centre pin and to the two points on the diode and made sure that it was insulated form anything and it work for ten minutes but then my laptop switched off and now it charges but when i try to switch it back onthe charge light goes off and nothing happens and dosent even attemped to start up.
                    And was wondering if anyone had an idea what could be wrong
                    many tanks
                    • juice0187
                      • Aug 2011
                      #50
                      hi, i have a mc7321u with the charging port broken just like the title says.. i searched and couldn't find a answer and seen this thread while searching. my question is if the gateway mc7321u is anything similar to the ma7..
                      thanks in advance.
                      • severach
                        • Aug 2007
                        • 1055
                        A broken jack needs to be replaced. The problem with the MA7 and similar laptops is that the board traces and vias break because the design does not withstand the normal forces from insertion and removal so the laptop won't charge even if the jack is perfectly good. Hasty solder patch jobs often result in a comeback in a few months. The jumper wires cross the broken parts to make the laptop work reliably again.
                        sig files are for morons
                        • juice0187
                          • Aug 2011
                          #52
                          ok, so i need a replacement dc jack.. do you know of a trusted site where i could order one.
                          • filesponge
                            • Jan 2011
                            • 15
                            • England
                            #53
                            Wow, i'd lost my link to this posting/site, just found it again by chance and I see it's been busy here
                            I will leave a few answers, just in case it helps somebody again later. . .
                            And well done to everybody who's had success with it
                            Moneypit - you only need to replace your socket if it's actually broken, but while you have the board out, it's often best to replace it as a matter of course - if only to make sure.
                            I check my own sockets by attaching a meter to a power plug on a wire, then wiggle the wire gently - if the ohms changes or goes off completely, it indicates a bad contact. Or use a very small screwdriver (remove the battery first!!!!) and see if the centre pin inside the socket moves even slightly. It should be solid in there, if it moves, replace the socket.
                            Heathric - sorry, i dont have access to one of these boards at the moment, and don't have the specs on those parts
                            Philface - It should be an easy repair for anybody who can solder, so TV repair shops or anything like that 'should' be happy to help. If they look shocked at the idea of bypassing a track or component, then find another repair shop - being horrified at such repairs is a sign the guy doesn't completely understand the how & why of circuits
                            Commader Giszmo - Glad it worked, a pleasure to help.
                            Robrote - it doesnt matter if you use stranded or solid, as long as the width and rating of wire can take the power going down it. Usually, a solid copper wire makes it easier though, as strands can separate and leave a stray strand that 'could' short out if not noticed. Plus copper can be bent to make exactly the shape of wire you want. What size of wire is usually down to experience, and things just look 'right'. Too thin and it will act like fuse wire and blow/get hot, too thick, it's a pain to fix to the board and can snap the solder away early in its life.
                            Festerboi - that sounds like you've got a bad solder join, or a short out (see what i mentioned above about using stranded wire). Try taking all wires off again, clean up all the solder points using solder braid, then refit new wires again. Theres a slight chance something else is now at fault, but most likely it's just a bad join somewhere. You will save a LOT of time by just redoing the job once more to see.
                            Juice0187 - Sorry, I'm not sure on how similar these boards are, i've seen several all from the same family, but each has its own little differences, generally though this bypass is about the same for all so far, luckily.
                            Have a look on ebay usually for a new jack, they are about £2.50 here in the UK, there's not much difference from one seller to the next.
                            Severach - good advice there, a rushed job isn't a good investment eh? I take about half an hour on most of mine now, 20 of that is for the actual soldering, then to all be checked over a few times, meter readings and things, all just in case. I'm very lucky with them I think.
                            • brianve
                              • Sep 2011
                              #54
                              when removing old jack removed sleeve of + pin as well. No idea where to hot wire pin to mother board untill i read these threads. Thanks alot. Hope i can be of help sometime
                              • brbled
                                • Sep 2011
                                #55
                                hello i hav a MA3 and will not power up or charge. i have seen what you talked about on the jumper is there a clear picture of what to do. the dc jack tested fine but still not working. thanks
                                • filesponge
                                  • Jan 2011
                                  • 15
                                  • England
                                  #56
                                  As far as I am aware, the MA3 is just about the same as the MA7, but maybe the none-UK version ?
                                  If you could take a close up clear photo of your own power/socket area of the board, somebody should be able to point out where you need to solder It's a main thing in trying to give any guide on this subject, any blurry or low resolution photo makes it risky trying to see where to solder as the boards have so many slight variations - just the manufacturers keeping us all runnin round in circles
                                  I've got a better camera now (Olympus X-44) with a super-close-up feature, but, i dont have any MA3/7 boards with me just now to show unfortunately. Just as a general possibly useful thing - I find it best to have the camera on either some kind of tripod (mins is a small one to fasten to a desk from MAPLIN, and also put the camera on 10 second (or 2 second is easier) delay. Most blurry close photos are caused by pressing the shutter button and making the camera move, but if using the timer, you just press and then concentrate on keeping the thing still.
                                  I'll drop by again in a day or two just in case.
                                  • nitram
                                    • Sep 2011
                                    #57
                                    in ma3 board if that particular diode shown is damage is there another one i could use
                                    • zubairqureshi
                                      • Nov 2011
                                      #58
                                      Can someone pls show the pictures for MA2 for this fix?
                                      • linux
                                        • Dec 2011
                                        #59
                                        Originally posted by runderwo
                                        By the way, when you add a jumper wire, pay attention to the conductive surfaces (one copper foil, one braid type) that rest between the power jack and the plastic case when the board is installed. Insulate with something in between. Otherwise you'll get a neat fireworks show and probably hate yourself for a little while...
                                        are there any other ways? https://www.badcaps.net/forum/images/icons/icon5.gif
                                        • theoj
                                          • Jan 2012
                                          #60
                                          HI, I'm new to this forum (have to say I've have been impressed by the depth of knowledge and willingness to share - there's a lot out there who have the knowledge and want to hang on to it). Anyway, enough digression, I have a MA7 with similar problems i.e. will run from charged battery etc. I stripped it down and everything looks ok at power socket, checked continuity though jack to board which is fine. On closer inspection the surface-mounted capacitor (C937), inboard from the network sockets looks a little burned at one end. Laptop was fine until an electrical storm. I live in Edinburgh, but storm was on Leros in the Agean, where I was holidaying. Any help appreciated - else it's the hardwire to battery terminals and external 12v supply mod from now on.
                                          • Klevjetack
                                            Charge a L19D3PDA battery externally from the laptop
                                            by Klevjetack
                                            Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                                            03-05-2024, 07:26 AM
                                            Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                            09-06-2024, 09:30 PM
                                            Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:47 AM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
                                          • Oyama65
                                            lenovo yoga 3.14 (80jh) laptop and will not power on or charge
                                            by Oyama65
                                            Mainboard model: BTUU1 NM-A381 REV: 1.0
                                            i have an lenovo yoga 3.14 (80jh) laptop and will not power on or charge, measured the battery voltage 0.00v dead flat.
                                            i managed to charged the battery, placed the battery back into the laptop and powered up.
                                            checked for shorts, checked mosfets, fuses and caps around battery and input not see anything, ive missed something.
                                            i wasn't getting negotiating voltage 19v only 5v. so i replaced the pu101 (BQ24715RGRR), once replaced i was getting negotiating voltage 19v but blinking white light 3sec...
                                            09-12-2024, 05:30 AM
