CH341A problem reading bios chip
  • JPToadstool
    • May 2020
    • 19
    • United Kingdom
    Morning all,
    Trying to create a BIOS backup of a Winbond 25Q80DVIG chip. I bought the CH341A with test clip from Amazon (this one). I could not get it to read with the test clip, I assume the test clip was not making contact with the pins. I have de-soldered the chip and soldered it onto a breakout board included, but when trying to read the BIOS, I get a power surge warning in Windows and a too high power draw error on Mac.
    Is this likely to be bad soldering, or another issue?
    • 30979
    Re: CH341A problem reading bios chip
    do you get that error without the flash chip installed in the programmer?
    • JPToadstool
      • May 2020
      • 19
      • United Kingdom
      No, only with it.
      • luckydip
        • Aug 2016
        • 159
        Did you insert the test clip correctly into the programmer (see pic)?
        Do you get a red light when you plug it in?
        Can you detect the chip in the software?
        • JPToadstool
          • May 2020
          • 19
          • United Kingdom
          Hi, thanks for the responses. I am not using a test clip as it didn't seem to be making contact with the pins with soldered to the M/B. I have desoldered and soldered onto the breakout board. I have a red light on power when plugging in - running without the breakout board installed shows the first message in the Terminal window. Plugging in with the breakout board and BIOS chip results in the second message and the notification about disabling USB.
          • luckydip
            • Aug 2016
            • 159
            Sorry, I have no experience in using this with macbooks. Have you got a pc to test it with?
            Looks like a connection/communication issue
            • JPToadstool
              • May 2020
              • 19
              • United Kingdom
              Okay, I tried the CH341A on an old Thinkpad I had laying around, also had a 25xx chip, and it read this using the clip whilst attached to the board just fine. I'll try desoldering the chip to another breakout board and see how that goes.
              • JPToadstool
                • May 2020
                • 19
                • United Kingdom
                I re-soldered it to a new breakout board and it worked fine. Thanks for your help though
                  • 20647
                  Some of the ch341a black pcb versions need a volt mod - https://www.eevblog.com/forum/repair...er-supply-fix/
                  • hotcrossedbuns999
                    M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                    by hotcrossedbuns999
                    My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                    1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                    2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                    3. I could only locate two chips that look like bios chips. Could someone verify this
                    01-03-2025, 12:32 PM
                  • intelg
                    HP Elitedesk 800 G6 lost BIOS admin password
                    by intelg
                    Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
                    Here is the hardware identification specs:
                    HP EliteDesk 800 G6 Desktop Mini PC
                    Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
                    BIOS ver S21 Ver. 02.05.01 01/05/2021
                    Born on date: 07/26/2021
                    SN MXL11841GN
                    SKU 3X8V9UCHABA
                    UUID 8116E79EF6FFE94DB0B98A3188270C5C
                    SYSTEM BOARD ID 8710
                    SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
                    11-03-2023, 02:05 AM
                  • Joluvillas
                    Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                    by Joluvillas
                    Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                    06-18-2024, 10:35 PM
                    by SMDFlea
                    Bad...
                    09-02-2021, 04:40 PM
                  • Azurain
                    Elitebook 840 G5 Bios Chip Soldering Question
                    by Azurain
                    I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
                    Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
                    04-14-2023, 06:58 PM
