HP 450 G5 - keyboard problem
  • CornholioGSM
    • Feb 2014
    • 264
    • CZECH
    i have here ex water smashed 450 g5 with mainboard da0x8cmb6e0.
    Water was mainly on and around kbc npce586ha2mx.
    KBC was desoldered, all cleaned and soldered back...on leg was repaired under microscope.
    Problem is, that some keys on kb wont work correctly - for example when i press "O" laptop turns on airplane mode.
    ...problem still with connected external keyboard. at first it seemed like keyboard problem...but i have tested another two 100% working keyboards and problem still.
    When is internal keyboard disconnected and is connected only usb kb then all works fine.
    I was not able to find service manual for this laptop.
    Soo what you mean? is needed to change kbc npce586ha2mx ?
    thx
  • emestee
    • 228
    Re: HP 450 G5 - keyboard problem
    The keyboard connector data lines go directly to the EC. You may want to test them one by one. Find schematics for a board with the same EC, keyboard lines are defined by EC hardware and pinout doesn't change between boards.
    Another alternative would be something silly like Fn function being on by default.
    • CornholioGSM
      • Feb 2014
      • 264
      • CZECH
      ...this ec is needed to be programmed or can i use directly another desoldered from another mainboard?
      • emestee
        • 228
        If I remember correctly from seeing it elsewhere, but dont quote me on it, it's self-programming - a blank EC would load its firmware from a SPI flash and store it internally. Quick google suggests it has nasty security features too.
          • 20659
          Edit: website in french language: https://www.ssi.gouv.fr/entreprise/c...-npce576ha2yx/
          Does it mean it can only be replaced with one from a donor board .
          • emestee
            • 228
            I don't think so. If anything, installing a programmed one from a donor board is probably a bad idea if it has security features enabled. There's simply no documentation on it. The russian engineers claimed to have made some progress, JTAG was mentioned but it's hush hush so far, so we don't have any data. There are supposedly EC dumps but I dont have access to them.
            Edit: upon some more googling tl;dr this EC is bad news. It is presumed to have unique OTP programming keys and so nothing to be done with it except replacement from an identical donor.
            • emestee
              • 228
              Ok here's some good news. The previous revision of this machine (Quanta X93A) has the same KBC. There's a reported case on russian forums where this KBC was successfully replaced with the 781 variant, and the bios was replaced with 25q80 or 25q128. The flashed BIOS was the official one with serial numbers copied from the original.
              Source (Russian): http://********/viewtopic.php?f=53&t=80018
              • CornholioGSM
                • Feb 2014
                • 264
                • CZECH
                soo what will be the simplest solution? buy new one from ali etc...then it will be self programmed from spi?
                • emestee
                  • 228
                  I would highly suggest you prove affirmatively that this is a KBC issue before trying to replace it.
                  • CornholioGSM
                    • Feb 2014
                    • 264
                    • CZECH
                    Re: HP 450 G5 (da0x8cmb6e0) - keyboard problem
                    *SOLVED*
                    ...i have found mainboard from 470 G5 ( 17" version with dGPU). ...soo i have changed kbc from this mainboard and all works fine without programming
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      *SOLVED*
                      Was the mb number same in 450 G5/470 G5??
                      • CornholioGSM
                        • Feb 2014
                        • 264
                        • CZECH
                        nono little different...give me few hours i will post it
                        • CornholioGSM
                          • Feb 2014
                          • 264
                          • CZECH
                          ...sorry my error...mainboard was same mb number - only with dGPU
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Hmm. So that leaves us still confused whether this kbc can be replaced from different mb. Will try to dig it and update if anything interesting found. I've not replaced this kbc so far and that's why want to know more.
                            • reformatt
                              • Feb 2020
                              • 1400
                              I just had a liquid damaged 430 G5 in. There are no schematics for the DA0X8BMB6G0 board; the DA0X8BMB6F0 board is basically the same design, albeit with components in different locations. Connections from the EC to the keyboard connector are the same (although the silkscreen has pin 1 at the wrong end).
                              Water spilt in the left side of the keyboard. It only affected the small daughterboard (which has a USB connector and the power button flex passes through it). Some corrosion on the connector from that board to the motherboard had corrosion on it, causing the machine to come on, then go straight off. However, after fixing that, keyboard not working, even with a new one. Keyboard connector etc buzzed out so I replaced the EC (NPCE586HA2MX) from some I got a while back from China. Can confirm this works without programming and keyboard now working ok. The water in the keyboard did indeed damage the EC, which was a bit surprising. There is no EC code in the BIOS, or a connected SPI ROM, so I'm thinking the functions of this IC are hard coded.
                              BTW, did have a screw up with the power LED not working after the EC replacement (I did have the power button hanging loose detached from the palmrest during troubleshooting). As there aren't any schematics, had to sit and buzz this out. To save others time, power LED should be an active low from pin 115 of the EC. This is connected to pin 5 of the 2N2007DW (K27) dual FET that is right next to that daughterboard connector. Pin 6 is the output and goes to pin 2 of the daughterboard connector. Replacing this FET fixed that fault. I guess this shorted when hanging free during troubleshooting. Wasted a good hour or so on this.
                              • SDNarcia
                                Dell 15R-5521 keyboard problem (KBC?)
                                by SDNarcia
                                Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
                                As additional information,...
                                07-20-2024, 10:47 PM
                              • MrDadosz
                                Lenovo Legion 15IMH05 keyboard problem
                                by MrDadosz
                                Hello, I have lenovo legion 5 15imh05 (board: nm-c911) and I have a problem with a keyboard.
                                When I hold power button for ~30 seconds or unplug RTC battery keyboard will work only one time. After laptop reset or shutdown, keyboard won't work.
                                In 90% cases when I unplug power supply and turn on laptop on a battery, keyboard works even after plugging power supply - I can't turn on laptop with a power supply and get keyboard working.
                                Shortcuts Fn + F1-F12 are working. Keyboard is fine.
                                I replaced IT8176FN-56A and reprogram it with a dump from previous chip and it worked for...
                                08-15-2024, 05:07 AM
                              • fmajbour
                                Acer Nitro 5 model A515-51 keyboard problem
                                by fmajbour
                                I have ACER Nitro 5 model AN515-51 main board model LA-E911P Rev 1A after replacing the mainboard keyboard stop working properly.
                                Some keys not working like Q,Z,C and some keys show deferent chr$ if i press K i will get I press D for F4 key etc...
                                i have tried all software issues like drivers test the keyboard on Windows 10 and Windows 11 and Linux with same problem.
                                I have check the keyboard connector on the mainboard every thing looks ok.
                                Then i replaced the keyboard with new one ......same problem exact same keys problem.
                                I need your advice if anyone face...
                                11-13-2023, 09:50 PM
                                HP ProBook 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
                                This specification for the HP ProBook 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse boardview and 450 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you...
                                09-06-2024, 06:21 AM
                                HP ProBook 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook 400 Specification for Upgrade or Repair
                                This specification for the HP ProBook 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse boardview and 430 G5 + Essential Top Load Case + USB Essential Keyboard & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you...
