MSI GE70 - MS-17561 - short
  • magneh
    • Apr 2014
    • 588
    • Portugal
    Hello guys
    During this crazy period, Im taking a look at some old stuff I have here lying around
    This MSI GE70 turns on , but no image.
    No cpu or gpu vcore. Cant find schematics. Already flashed bios with a clean dump, same thing.
    I finally got somewhere, I have 0 ohm resistance in Pchoke5 coil.
    Removed it, but when I inject current (1V, 1.5 A) cant find anything getting hot.
    Not sure what is the voltage at this coil, so im a bit afraid to go up and blow it for good
    Does anyone know or have a mobo like this one that could help me know more about this coil or voltage here?
    A pic with the wire on the side of the short, and the coil removed on the side.
    If not, ill just close the case, RIP.
    Thanks!
  • magneh
    • Apr 2014
    • 588
    • Portugal
    Re: MSI GE70 - MS-17561 - short
    Well Ive been again investing some time on this one, and even with 4A I cant find anything hot...which is amazing.
    Also I noticed a bubble on the chip7.
    What would you do with it?
    RIP right ?
    • piernov
      • Jan 2016
      • 4435
      • France
      Has it been reflowed?
      • String2016
        • Nov 2015
        • 2229
        • philippines
        I think the pch chip is dead
        • magneh
          • Apr 2014
          • 588
          • Portugal
          Hi Piernov!
          If it was, not by me
          But I would say no, does not seem like.
          Could the PCH chip be causing the short?
          Still should be getting hot with 4A right?
          Oh well...anyways chip is not good for sure with that popcorn bubble...
          • piernov
            • Jan 2016
            • 4435
            • France
            Popcorn at that spot should not happen randomly but rather by applying an excessive amount of heat (like when trying to reflow). Also the underfill around the die looks darkened.
            If someone tried to reflow it improperly, for sure it destroyed the balls under it and could be causing a full short to ground directly on the balls.
            • magneh
              • Apr 2014
              • 588
              • Portugal
              Yeah someone could have done some crap with the PCH before I got this laptop...shame...
              I have 1 logicboard probably repaired (found 1 capacitor in short) that could be compatible with this machine, but needs another CPU.
              Anyways this one will stay as a donor, as I dont replace BGA chips.
              Merci Piernov
              • sicilianul
                • Jul 2014
                • 70
                • Romania
                From my experience - when you have short with 0 and no heat - balls or underlayers are the problem.
                • magneh
                  • Apr 2014
                  • 588
                  • Portugal
                  Yes Sicilianul, makes totally sense.
                  I think its the case here.
                  Thanks!
                  • aaronkatrini
                    Help me find the short circuit on this WORKING Nvidia GTX1650
                    by aaronkatrini
                    Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
                    Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
                    04-18-2024, 03:15 PM
                  • Victor Moreira Silva
                    Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                    by Victor Moreira Silva
                    I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                    Well, my decice specs are the following:
                    Model: Acer Nitro 5 AN517-54-55T5
                    CPU: Intel Core i5-11400H
                    GPU: NVIDIA GeForce GTX 1650
                    Motherboard: GH51G LA-L181P Rev:1c
                    The symptom:
                    When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                    05-26-2025, 10:49 AM
                  • snow_sg1
                    MSI GS73 (MS-16K61) : help me find short (got thermal cam)
                    by snow_sg1
                    First : I've got a SMD rework station, thermal camera and good soldering station
                    This is my first "short" motherboard repair, this laptop was 25€ so no loss, it just for learning. I want to learn how to fixed board because I want this to become my job.
                    I've been fixing electronics for 15+ years, but mostly VCR and camcorder.
                    So, I checked power adapter pin to ground, no short, then I plugged the charger in, light on charger blink indicating short.
                    PQ19 mosfet got HOT straight away (viewed on thermal cam). Checked,...
                    09-13-2024, 03:30 PM
                  • Prott
                    PCB Layer to layer short on a low voltage power plane - how to find it?
                    by Prott
                    Hello!
                    Recently I have a problem finding a dead short (as far as my cheap multimeter is concerned) on a multilayered (12 layer) PCB. It is caused due to mechanical stress (warping the board and, I assume, cracking inner layers). Injecting voltage of 0.9 V (operational voltage of that part of the circuit) and drawing 0.5 W doesn't cause any visible hotspot on a thermal camera.
                    Does anybody have any tips & tricks in order to locate the short more or less precisely? The area has a lot of powerplanes, so it's both blessing and a curse.
                    Silly idea no. 1: Can I...
                    08-01-2024, 12:09 PM
                    KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
                    by momaka
                    For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
                    http://www.rmac.kingwin.com/products.../abt_650MM.asp
                    I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
                    What mostly drew me into buying it is its 2x PCI-E power connectors...
                    03-29-2022, 11:34 PM
