Lenovo IdeaPad s340 burned motherboard ?
  • Mike94990
    • Mar 2020
    • 29
    • Italy
    Re: Lenovo IdeaPad s340 burned motherboard ?
    Originally posted by ktmmotocross
    just measure rezistance on both side of capacitors to ground.
    if u dont have ram inserted and laptor start, than u must have ram on board, so try to remove inserted ram
    check if u have 1.2V on pl502
    I just remember that this pc has 4gb of ram integrated on the motherboard (i don't know where), so you are right.
    i'll check the other voltage and components
    • Mike94990
      • Mar 2020
      • 29
      • Italy
      i just find out that 1 capacitor was shorted, so i solder it again and........ it turn on!!!!!
      But There is a big problem: the temperature!
      When i turn the pc on, the fan started normally and after 1 sec it stop.
      I waited until the login screen (about 4 seconds) and the ssd and the black heatsink become very hot.
      What can i do?
      • Mike94990
        • Mar 2020
        • 29
        • Italy
        No one know?
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3608
          • slovakia
          did it turn off from heat when u let it run?
          • Mike94990
            • Mar 2020
            • 29
            • Italy
            I turned it off manually because it got too hot...
            i have a bit of fear to burn it totally
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3608
              • slovakia
              #26
              dont havefear. if it gets too hot it shut down itself.
              maybe it is programmed to start fan when hot. chips can withstand heat that burn your finger normally
              • Mike94990
                • Mar 2020
                • 29
                • Italy
                #27
                do i have to let it on and see what happen?
                Do i risk to burn everything?
                • Mike94990
                  • Mar 2020
                  • 29
                  • Italy
                  #28
                  sorry, i just read you replay... i hope that it's not burn the temperature sensor or something like that and it wont turn off
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3608
                    • slovakia
                    #29
                    no. every big chip/cpu, GPU, NB/ have inside sensor
                    check if u dont have bend heatpipe
                    • Mike94990
                      • Mar 2020
                      • 29
                      • Italy
                      #30
                      In the first image you can see the heatpipe in red and the very hot point in green.
                      Now i'm waiting for a capacimeter from amazon to measure the capacitor (do you know some other way to measure with a normal multimeter?) because.... i burn the first one near the pl501....
                      I need another capacitor (the one in the second image)
                      Every time a move sometring, the situation gets worse
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3608
                        • slovakia
                        #31
                        that green points is GPU, CPU and SSD controller. offcourse it is hot. just check if side of heatpipe near fan gets warmer
                        u dont need capacitor meter. just replace all three capacitors. it is cheaper
                        • Mike94990
                          • Mar 2020
                          • 29
                          • Italy
                          #32
                          can i replace che three capacitor with some other random capacitor of the same size? (like i did with the PL501)
                          do i need to check some value?
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3608
                            • slovakia
                            #33
                            u have schematic with values
                            • Mike94990
                              • Mar 2020
                              • 29
                              • Italy
                              #34
                              yep but i can't measure che capacity of the other capacitor (because i'll take the capacitor from another board but i can't measure their value)
                              I'm sorry for making you waste all this time but.... can you tell me the value?
                              I don't know how to find it in the schematics.
                              I feel so stupid, but i'm learning!
                              • ktmmotocross
                                Boardkiller
                                • Feb 2014
                                • 3608
                                • slovakia
                                #35
                                on board u see that capacitors is connected just after PL502. in schematics u see that it is 22u /microfarrads/ 6.3V
                                • Mike94990
                                  • Mar 2020
                                  • 29
                                  • Italy
                                  #36
                                  thanks for the replay, I didn't think those were the capacitors because they are 6 in the schematic (and i have only 3 capacitors).
                                  but ok,i'll find the capacitors and relace them!
                                  • ktmmotocross
                                    Boardkiller
                                    • Feb 2014
                                    • 3608
                                    • slovakia
                                    #37
                                    oh my god. dont u think that the other three can be on other place on board? it is schematic not boardview
                                    if u want to see others three find boardview
                                    • Mike94990
                                      • Mar 2020
                                      • 29
                                      • Italy
                                      #38
                                      I know the other capacitors may be elsewhere, but I wasn't sure...
                                      Now l'am looking for capacitors on other motherboards
                                      • Mike94990
                                        • Mar 2020
                                        • 29
                                        • Italy
                                        #39
                                        i'm here again with some update: i can't find anywhere that capacitor 22 microfarrads, 6.3V), i check the schematics of 10 old motherboard and.....nothing.
                                        So i try something (maybe very stupid, i don't know): i turn it on with 2 capacitors (not 3) and it seems to be working well.
                                        i check the temperature:
                                        -ssd m2: 66/68 degrees Celsius (misured with Hard Disk Sentinel)
                                        -CPU: core0 -> 57 degrees Celsius
                                        core1 -> 59 degrees Celsius
                                        core2 -> 72 degrees Celsius
                                        core3 -> 56 degrees Celsius
                                        (misured with speedFan).
                                        I'm worried about the ssd and the core2...
                                        The other temperature are normal?
                                        What do you think?
                                        • ktmmotocross
                                          Boardkiller
                                          • Feb 2014
                                          • 3608
                                          • slovakia
                                          #40
                                          What do you think?
                                          all cores have literallly same temp because it is on same chip. its just bad reading. that capacitors must not be there but u can have some instability so better add capacitors with same size.
                                            Lenovo IdeaPad S340 Notebook S Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad S340 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S340 boardview and S340 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad S340...
                                            09-06-2024, 03:30 PM
                                            09-06-2024, 03:21 PM
