Trying to identify a component
  • tH0RiN
    • Apr 2016
    • 6
    • España
    i think this is some voltage regulator. is between the chokes of 3VSB & 5VSB in a asus x570LD laptop board.
  • R_J
    • Jun 2012
    • 9535
    Re: Trying to identify a component
    Richtek RT8249CGQW
    • tH0RiN
      • Apr 2016
      • 6
      • España
      Originally posted by R_J
      Richtek RT8249CGQW
      Wow! Thanks!!
      • hobostove
        Corsair RM1000e - Help identify 5VSB Zener diode
        by hobostove
        Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
        Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
        There's a 22ohm resistor that's melted and open, but it still has the bands.
        The other part is a zener diode and it's top went to jesus, so I can't read the marking.
        It looks like the diode connects the source and drain of a TNY284...
        03-27-2025, 02:25 PM
      • прямо
        Viper22A 5VSB circuit
        by прямо
        So I have a cheap non working ATX PSU that I was learning to repair a decade ago. At the time, it blew the main fuse, bridger rectifier, NTC, and primary 9A 900V MOSFET. Replaced all except the MOSFET. 5VSB came back online. Then I poked around in it so much, measuring components one by one to a point I accidentally made the 5VSB circuit primary side went bang. Blown the AP8022 (Viper22A) PWM chip, along with a low resistance resistor and the PC817 opto isolator. I replaced them all.
        In the process of poking around, I also lost a zener diode that stabilize the voltage coming from...
        01-13-2024, 07:05 PM
      • kotel studios
        FSP300-60GTF - no 5VSB, PS_ON; 5VSB carnage
        by kotel studios
        Finally replaced all of the shorted 4148's and resistors and an blown tl431 on my FSP300-60GTF after 5VSB going crazy and destroying it self. Those components also made the secondary transistors appear shorted (while in reality they weren't).
        Powered it on through my dim bulb tester and they (bulbs) only flash once meaning primary caps are getting charged, but that's it. No 5VSB, PS_ON voltages.
        I am sure I have replaced the components correctly and that there weren't any shorted/blown traces left.
        Any ideas where to go next?
        02-23-2025, 11:47 AM
      • thesame
        DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
        by thesame
        Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
        The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
        02-27-2024, 04:31 AM
      • silver60618
        Lenovo Legion 7 - Help Identify IC
        by silver60618
        Hi gang, its a long shot, but working on Lenovo Legion Pro 7 motherboard NM-F091, and trying to identify this component near GPU with marking "eHFQH" that is burned and shorting the board. Looks like power management IC
        I couldnt find any schematic or boardview. The CPU side also has same chip. Any way to identify this chip? or take measurements from the good chip to determine what it is?
        Any help would be appreciated...
        07-02-2025, 12:16 PM
