la-9104p MB 7 Beeps error and no display
  • Spider1211
    • Oct 2019
    • 532
    • Mauritius
    #41
    Re: la-9104p MB 7 Beeps error and no display
    caps in ram area will show low rating
    @mcplslg123 how much is low? I have around 30 Ohms on the mlcc near RAM area.
    • piernov
      • Jan 2016
      • 4435
      • France
      #42
      VCC_AXG_SENSE is connected to +VCC_GFXCORE_AXG inside the CPU.
      VSS_AXG_SENSE is connected to ground inside the CPU.
      • Techtiger
        • Oct 2014
        • 1601
        • france
        #43
        another LA-9104P MB with out +VCC_GFXCORE_AXG but the interesting part is the Mob power’s up and working fine how is this possible ?
        INTEL Pentium 2127U
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          #44
          If you check with dmm then voltage will appear for a brief second on +VCC_GFXCORE_AXG. You need a scope to check this. Same on dell vegas turis 15341-1 mb.
          • Techtiger
            • Oct 2014
            • 1601
            • france
            #45
            Your are absolutely correct the voltage rise up 0.864 & Back to 0V is the SOC need to replace?
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              #46
              What is the problem you are facing?? You said at post#43-its working fine. Confused??
              • Techtiger
                • Oct 2014
                • 1601
                • france
                #47
                for the moment no problem with the Mob, but i have the spair Mob with +VCC_GFXCORE_AXG out put. why one with Voltage out put & with out ?
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  #48
                  The one with constant output on +VCC+GFXCORE_AXG is not giving display. Right??
                  • Techtiger
                    • Oct 2014
                    • 1601
                    • france
                    #49
                    Yep that's correct What is the reason for this
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      #50
                      Dont know the reason but what i've observed on this mb is that there will be no display when
                      01.You have constant voltage on GFX Coil
                      02.When there is No voltage for a brief second on GFX coil.
                      I've noticed the same behaviour on dell 15341-1 MB. Display comes only when there is a voltage on gfx coil for a split second only.
                      Trying to understand why.
                      • Techtiger
                        • Oct 2014
                        • 1601
                        • france
                        #51
                        Thanks for the describe in a more detailed way Mcplslg123
                        • macabook
                          by macabook
                          🧩 Initial Issue
                          Today, 02:17 PM
                        • lanovey
                          SF314-41 BIOS without internal display
                          by lanovey
                          Hello there,
                          I have a SF314-41 motherboard that i bought impulsively recently, the problem is that i only bought the motherboard only, nothing else. When i tried powering on the board with 19V (soldered on the DC IN port), and then shorting the pin 1-2 of the keyboard, the board is turning on (as indicated by the fan), however it seems like the board is displaying on the internal display as connecting to a display on the HDMI (external) does not display anything.
                          I tried connecting a USB keyboard, the keyboard is powered on, however pressing numlock do nothing (supposed to toggle...
                          06-13-2025, 02:38 AM
                        • AustinCER
                          HP ENVY Desktop TE01-1214 - No Display, Powers On, Corrupt BIOS
                          by AustinCER
                          I currently have an HP ENVY Desktop TE01-1214
                          S/N -
                          2MO22342GX
                          Motherboard - L75365-001
                          BIOS Chip - W25Q128JVSQ
                          Suspected Windows updates contained BIOS update in which, during update the Desktop PC displayed a black screen to the monitor while still powered on. Display image never restored.
                          Tested RAM in both slots, as well as new RAM. Tested a brand new known working i5-10th Gen GPU (Same CPU as original installed). Cleared CMOS. Tested the Desktop PC with a dedicated GPU connected, but still no display. Device will not POST when powered...
                          04-25-2025, 05:56 PM
                        • Vesko356
                          by Vesko356
                          08-11-2023, 03:27 AM
                        • ikelectro
                          After bios recovery by pen drive HP15s eq0007AU display flashing a light for short time.
                          by ikelectro
                          Schematic : DAOP5EMB6E0 REV:E​
                          I have tried manually flashed the bios, also tried hp bios recovery tools to recover the bios. But no luck. Display is not coming, 3 to 4 times recovery display is coming if I tried to recover by pen drive[win+ B]. But after restarts it goes to dark screen and a light is flashing after a certain time in the display + fan speeds increasing and decreasing. I have tried almost every bios for this motherboard avaiable in the internet.
                          Any help or guide to proceed?...
                          03-19-2025, 08:17 PM
