Hi all, need help in repairing this notebook. Any help across the world will be greatly appreciated. I am working on ACER Notebook Spin 7 Model SP714-51-M5H3 logic board. The notebook is working fine but only problem is the battery does not charge. The battery is brand new. On the first instance one of the Battery charge MOSFET blew out. I replaced it & started to get voltages on the battery terminals of the main logic board. But this voltage is 18.5 voltage not the regular 11~12volts & when I plug in the new battery the Mosfet turns hot. Then I replaced with original MOSFET (A5 GNE) & checked the other mosfet (AON7410), they were all good but no difference with the voltage still 18~19volts DC. Checked the Schematics (Acer VN7-592G Rayleigh 15292-1) & the charging chip BQ24780S. I noticed on Pin 27 ("Phase" PWR_CHG PH) its generating 18.5V whereas the voltage on this pin should be 11.5 ~13V. Then I replaced this chip with a brand new, NO LUCK., voltage is not getting under 18v. Checked all the components nearby, all diode & resistors seem to be ok. Any help or tips to repair this board will be greatly appreciated. Thanks in advance
Re: ACER Notebook Spin 7
Replace the high-side MOSFET that feeds the battery charging rail from B+OpenBoardView — https://github.com/OpenBoardView/OpenBoardView -
Hope I have attached the Schematics right., can you pls. identify me the MOSEF to check or replace on page 37 & Page 38, I would appreciateAttached FilesComment
Thanks., PU4404 this is the first MOSFET I checked & even replaced with original one., but still can't get the voltages lowered, still 18volts on the source whereas this volt on the source should be 12volt... any other tip will be greatly appreciated.Comment
Take another good look at your charger IC (BQ24780S) and make sure pins 26/27 not shorted together. Maybe try replacing that again. There isn't many places the 18V can be coming from if you are sure that the high side FET is good.Comment
Check PU4402 as well.
If it's not PU4402, replace charger IC and PU4404 at the same time, making sure charger IC is sitting flat on the board without solder bridges.OpenBoardView — https://github.com/OpenBoardView/OpenBoardViewComment
Thanks for all your replies. I checked the pin 26/27 & they are not short., checked under the microscope to see if I did not solder the chip right but all is fine.. Did a good ultra sonic cleaning to the chip & nearby components. This seriously has become a challenge for me.. Check the photo pls. of the replaced MOSFET & the location where I am checking & troubleshooting., & if one observes the inductor PL4401., it was draining so much amps when I installed the brand new battery that it became very hot & lost its color. But this was happening before with the old battery too, this is why the old battery does not give out any voltage on any of its battery terminal pins.. & if one observes the schematics, I see that pic of PU4402 is a PNP FET & when I actually check the PDF of this FET TPCC8103-GP, it clearly is a NPN channel. On the Gate & Source of this FET PU4402 I get 19Volts & on drain I should be getting around 12volts, whereas this is 19v too. So confusing!!!
The TPC8103 shows a P-channel when I looked it up, so matches the sch. The other charging FETS (HI/LOW) are N-ch.
https://www.digikey.ca/product-detai...-CT-ND/2310694
Have you replaced PU4402?
I had a similar issue where the battery wouldn't charge, but it would work with either battery or AC, and it ended up being the BQ24780S charging IC. I swore it was soldered correctly and even measured out the same to a known good board (diode mode). I eventually replaced the IC again and it worked.Comment
No, not replaced PU4402 as it shows good, I replaced the chip before too., but first I will replace the FET PU4402., maybe it shows good & there might be some internal switching problems. So you are saying that this is P-Channel MOSFET as per the schematics & as per the link you send. If so, then here lies the problem, MFG Have used AON7410 x 2 & the high side MOSFET is A5 GNE, all 3 N-Channel FETs. But this NB was untouched, only I did all the soldering & replaced parts. Let me try.Comment
I think the schematic you have is incorrect, or not the right one for your MB.
As per the BQ24780S pdf, the FETs are suppose to be N-ch. (1st page of attachment), including the BATFET (PU4402 in your case). All the FETs you have on the MB are N-ch as you have found out
I would still be looking at the PU4402, and also the BQ chip.Attached FilesLast edited by brew99; 06-21-2019, 05:11 PM.Comment
brew99., you are great & very helpful.... thank you buddy.. today I was bored enough to work on this motherboard again as I had others to look into. Tomorrow first thing in the morning I will go through the chip's PDF file & see what wrong am I doing... So you are saying to go with the BQ24870S schematics pdf to figure out the problem. "Brew99" I will run through the Application information of this chip's pdf 8.1 & 8.2 to see where am I wrong... Yes I think I have got the wrong schematics.. Does anyone have the right schematic for this motherboard ACER Spin 7 VN7-592G Rayleigh SLS 32bit 15292-1 ??? Thanks to all who are helping me out & figure out the problem...Comment
Good morning., I replaced all the N-Channel MOSFETs & even the BQ24780s chip but still no luck... Still generating 18v., it works fine with the battery & I notice that when on battery the FETs turn a bit hot, but when I plug in the original ACER power adapter, it burning hot. Any more tips will be greatly appreciated., I need to repair this, its become a challenge now... hope we all come up with a solution. Help me please.... ThanksComment
as for the schematic, I think it is correct, although from datasheet shows that adaptor fet and bat fet should be N-channel, but the function has been converted through pq4401? "just deduction"I think the schematic you have is incorrect, or not the right one for your MB.
I would still be looking at the PU4402, and also the BQ chip.Comment
			This specification for the Acer TravelMate TravelMate Spin B3 TMB311RN-31-C7XH Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the TravelMate Spin B3 TMB311RN-31-C7XH boardview and TravelMate Spin B3 TMB311RN-31-C7XH schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-07-2024, 05:20 AM
			This specification for the Acer Spin SP513-54N-79EY Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SP513-54N-79EY boardview and SP513-54N-79EY schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 02:34 PM
			This specification for the Acer Spin SP513-52N-3149 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SP513-52N-3149 boardview and SP513-52N-3149 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:51 AM
			This specification for the Acer Spin SP513-54N-75N1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SP513-54N-75N1 boardview and SP513-54N-75N1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 02:30 PM
			This specification for the Acer TravelMate B311R-31 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the B311R-31 boardview and B311R-31 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Acer...09-06-2024, 02:24 PM
 - Loading...
