Easynote TK85 reboot loop
  • Retrocomputer
    • Aug 2012
    • 47
    • Italy
    Hi!
    I'm quite a newbie in motherboard repairing, so please forgive me if I make some mistakes.
    As per title, I have a Packard Bell Tk85 (which has almost the same guts as the aspire 5742 or maybe 5733 (at least it surely has the same mobo, a Compal PEW71 LA6285P)
    which shows the following symptoms: as I press the power button, the blue lights show up, the fan starts spinning, and it tries to read from the HDD. after a few seconds, it shuts down and reboots. Nothing is ever shown on screen, at any time. No backlight nor any kind of image. If powered on from the battery, it continues to reboot as in a cycle, if powered from supply, it usually reboots one time and afterwards it stays on, with black screen. The fan works fine, the temperature sensing circuit seems to work well, it turns on and off the fan as the temperature floats. Another symptom is that it as I turn it down with the button, after a few secontds it boots up again on its own.
    Already stripped to the bare board with just ram, cpu, monitor and power button connected, nothing changes. If booted without any ram nothing changes again, no beeps or anything. What might the fault be on the mobo?
    I've already tried testing all the voltage rails, and it seems they're fine.
    I just checked the main voltages. They seems to be perfect, imho.
    +CPU_CORE: (@C272): 1.03V
    +0.75VS (@pin 204 DIMM1): 0.76V
    +1.05VS (@L1): 1.05V
    +1.05VS_VTT (@PJ12): 1.05V
    +1.5V (@pin 5 U24): 1.52V
    +1.5VS (@pin 3 U24): 1.52V
    +1.8VS (@R944): 1.83V (before and after resistance)
    +3VALW (@pin 9 U31 / pin 5 U26): 3.34V
    +3V_LAN (@L99): 3.36V
    +3VS (@pin 3 U26): 3.35V
    +5VALW (@pin 5 U25): 5.03V
    +5VS (@pin 3 U25): 5.03V
    +VSB (@R935): 18.95V before R, 18.43V after R, 19.18 when switched OFF
    +RTCVCC: (@pin 1 D1): 3.05V when ON, 2.75 when OFF
    All voltages seem stable, +3VALW, +3v_LAN, +5VALW, +VSB, +RTCVCC are all present with pc is switched off (S5 state).
    I've even tried reflashing both BIOS and EC with dumps found on here and on the web, but to no avail. The main BIOS chip is a Winbond W25Q32, the EC chip is a cFeon EN25F10.
    Do you have any ideas?
    Thank you very much!
    Davide
    Here's the schematic http://monitor.espec.ws/files/la-6582-r10_165.pdf
    Wasn't able to find any boardview, even if it would be of extreme help, since the mobo has next to no silkscreening.
  • Retrocomputer
    • Aug 2012
    • 47
    • Italy
    Re: Easynote TK85 reboot loop
    No ideas? If you need anything more, ask.
    • Techtiger
      • Oct 2014
      • 1601
      • france
      Test U16 SIO
      Pin 13
      Pin 100
      Pin 121
      Pin 84
      PL 10 +VGFX COREP
      Did you try with another CPU ?
      • Retrocomputer
        • Aug 2012
        • 47
        • Italy
        I was just going do write an update here as I worked for a bit longer on the mobo tonight. I found the probable culprit: by further examining the board, PU12, an ISL62881CHRT has a clear burnt spot on it, and a tiny bit of material ejected onto some tracks underneath. Since it's the voltage regulator for the GPU, it's quite clear why it didn't work!
        Do you think it might be useful to try to replace it?
        Thank you so much, the absence of +VGFX_COREP lead me on the (maybe) right path!
        • Retrocomputer
          • Aug 2012
          • 47
          • Italy
          Ha! Upon even closer inspection it seems that the fault started on pin 12, VIN, as there it was the most damage,it even lifted the trace off the board...
          • Techtiger
            • Oct 2014
            • 1601
            • france
            PU12 ISL62881CHRT Change it if the pad is broken put a jumper from PR263
            • Retrocomputer
              • Aug 2012
              • 47
              • Italy
              Hi! Good news here! Today the spare PU12 chip arrived and I soldered it, I needed to make an extremely thin bodge wire to recreate the burnt trace... it was the first time soldering a QFN package, let alone making a trace repair... it's probably not the best but here's my work.
              Oh and the laptop turned right on! It seems to be working fine now. Have yet to try with an hdd with an operating system on it.
              • Retrocomputer
                • Aug 2012
                • 47
                • Italy
                Hi!
                I still have an issue with this laptop.
                After that repair, it seems to work fine but after some time (5 to 15 minutes) it shuts itself off. It's not a thermal issue. I've read around it seems it may be something related to ME part. I've already flashed the latest bios from PB website using their own DOS tool. May it be useful to reflash it using a programmer?
                Thank you
                Davide
                • piernov
                  • Jan 2016
                  • 4435
                  • France
                  Dirty ME region will typically cause shutdown after exactly 30 minutes. Not randomly between 5 and 15 minutes. (which sounds more like a thermal or power issue)
                  If you want to clean ME region, you have to dump the BIOS with external programmer, clean ME in the dump (following win-raid tutorial for example), and flash back the cleaned dump.
                  • Retrocomputer
                    • Aug 2012
                    • 47
                    • Italy
                    Thank you very much! I've worked for a bit this afternoon on the laptop. I flashed another BIOS with a programmer, the equivalent Acer 5733, with PEW71 mobo. It's been working fine ever since, even if I'm facing another strange behaviour: after trying that, I flashed the original PB BIOS/ec, but the acer logo that came with the first flashing remained, and the keyboard fn layout is all screwed. Other than that, the laptop works great.
                    What can it be?
                    Thank you.
                    • piernov
                      • Jan 2016
                      • 4435
                      • France
                      The DMI information are now for the Acer laptop, or the DMI info were empty and set to Acer by default.
                      Either you have to flash a full dump for Packard Bell using an external programmer (to get the correct DMI info) or you can try to set them manually (if you know what they should be set to) using the DMI tools for Acer.
                      Can also probably merge the DMI info from the original dump to the new one, but requires more work to figure out what to port over.
                      • Retrocomputer
                        • Aug 2012
                        • 47
                        • Italy
                        That's what I thought, but I flashed the files from PB with an external programmer, wholly erasing thw two chips before every flash...How is it possible that it still thinks it's an Acer?
                        Thank you so much!
                        • piernov
                          • Jan 2016
                          • 4435
                          • France
                          Packard Bell and Acer files are the same. Only the DMI info programmed from factory is different.
                          Typically the default DMI info in the BIOS file show Acer logo.
                          • Retrocomputer
                            • Aug 2012
                            • 47
                            • Italy
                            Thank you again... I still don't understand, though, why files downloaded from PB (that showed the correct logo before as you can see in the picture I attached before) now shows the Acer logo... It wouldn't be an issue actually having another logo, but the fn keys layout is screwed (eg where I have the play/pause icon, it actually turns off/on the touchpad if pressed) Can it be connected in some ways?
                            Sorry for bothering you
                            Davide
                            • piernov
                              • Jan 2016
                              • 4435
                              • France
                              Again, since the original DMI info for that laptop (this specific Packard Bell model) were lost, the BIOS is now using the default parameters which are usually for the Acer-branded laptops.
                              • kevin_allein
                                Samsung GU58TU7199 reboot loop
                                by kevin_allein
                                Hi, I have two identical Samsung GU58TU7199, which both had the reboot loop. On that model TCON is integrated into the motherboard and there is only one FPC cable, which goes to a driver board driving half of the panel (left side seen from the rear of the TV) and than another FPC cable connecting left side to the right side.
                                The first one was easy, once I disconnected the FPC between left and right the TV did start up. I soldered a bridge on the motherboard on the test points as found here in the forum or on Youtube and half of the screen was coming up. I than tried the CK1..8 lines...
                                03-24-2024, 12:19 PM
                              • natiz
                                Samsung QE50Q60AA - Reboot loop
                                by natiz
                                I have a QE50Q60AA that won't stay on - when turning it on, it makes the sound and reboots right after (sound is ok).
                                Disconnecting the LVDS cable stops the restart loop but no image.
                                I tried the tape method mentioned in other threads in many variations, but I couldn't get it to properly work (either reboot loop, or no image).
                                Tested the caps on the left buffer board, no beeps.
                                What else can be checked?...
                                08-30-2024, 09:26 AM
                              • Yanleb
                                Samsung 4K UN55NU7100F stuck in a reboot loop
                                by Yanleb
                                Ok, I have this Samsung 4K UN55NU7100F that is stuck in a reboot loop.
                                I know this is not a backlight issue since when I disconnect the power cable from the main board the power supply starts and the backlight is working just fine. Each of the 6 LED strip connectors measure 116 volts.
                                I've found that when I disconnect any one of the two LVDS cables going from the main board to the LCD panel (it doesn't have a T-CON board) it is working just fine (with no picture as you can expect).
                                On a few occasions I found that reconnecting the disconnected LVDS...
                                03-19-2022, 02:13 AM
                              • nocnoc
                                Acer Swift 5 (SF514-52T) reboot loop mistery
                                by nocnoc
                                I'm quite new to this and trying to learn by help a friend with his SF514-52T that stopped booting after battery was replaced. I suspected the battery was bad but the problem persisted when putting back the original one (which is was still working although with reduced capacity).
                                When pressing the power-on button the symptoms are:
                                - Keyboard backlight and blue power LED turn on for about 5-7 seconds, and then flash off-on in ~3 seconds cycles (reboot loop).
                                - Display does not seem to turn on, although it sometimes seems to flash in between reboots....
                                04-21-2024, 06:42 AM
                              • Takeatry
                                Yet another Samsung QLED Boot Loop
                                by Takeatry
                                Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                                10-04-2024, 02:57 PM
