Samsung NC110 - Does not turn on.
  • bpjl
    • Jun 2016
    • 28
    • Polska
    Hello.
    I have a motherboard (Lennon BA92-07684B) from the Samsung NC110. The motherboard does not turn on.
    When the power is supplied, the green LED lights up, but the board does not draw any power. When you try to turn it on there is no reaction. Sometimes, however, the blue LED will blink and 120mA will be consumed. Then the TPS51125 chip (visible in the picture below) starts to heat up.
    When I connect the battery to the motherboard and connect the power supply, the difference is that the green LED turns red, which indicates charging and when the board has already responded to the button, the current consumption jumps between 180 and 230mA.
    I am asking you for help in solving the problem.
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: Samsung NC110 - Does not turn on.
    TPS51125 should not heat up. Measure resistance to ground on VREG3 and VREG5 pins.
    • bpjl
      • Jun 2016
      • 28
      • Polska
      Thank you for the quick reply. Here are the results of these measurements:
      • VREG3 = over 20MΩ (limit of my multimeter)
      • VREG5 = over 20MΩ (limit of my multimeter)
      • bpjl
        • Jun 2016
        • 28
        • Polska
        Originally posted by techtiger @ PRIVATE MESSAGE
        Yesterday I got the same MOB With similar issue no power at all it was the first MOSFET was not driving 19V to the Mob now it's working
        Mesures voltage
        Page 37 Schmatic
        U521 ic
        Pin 3.8.16.17 voltage
        L8 coil
        L9 coil
        Page 38
        Bat connect
        Pin 6.7 voltage
        Page 14 RTC
        D523 pin 1.3 voltage (3.3V MICOM)
        Page 36
        Coil L7 voltage
        U3 ic
        Pin 1.6 voltage
        This is your S5 state
        And the rest of the gray coils multimeter diode mode red probe to GND black to coil For resistance
        Report back
        The first MOSFET AO4807 works rather well for me:
        • D1 = 19V
        • D2 = 19V
        • S1 = 19V
        • S2 = 19V
        • G1 = 9.4V
        • G2 = 2.3V
        I do not have a schematic so I do not know which elements it is (especially that they are not described on the PCB)
        I suspect that "U521 ic" is a heating TPS51125. Here are the measurement results:
        • pin 3 = 2V
        • pin 8 = 3.3V
        • pin 16 = 18.9V
        • pin 17 = 4.9V
        Power button voltage?
        • Techtiger
          • Oct 2014
          • 1602
          • france
          try this Schmatic
          • bpjl
            • Jun 2016
            • 28
            • Polska
            Page 37 Schmatic
            L8 coil
            L9 coil
            Page 38
            Bat connect
            Pin 6.7 voltage
            • pin 6 = 0.4V
            • pin 7 = 0.4V
            Page 14 RTC
            There's no D523 on this schematic. On page 14 is D513 (BAT54C) and if it is this diode then:
            • pin 1 = 3.3V
            • pin 3 = 3.1V
            Page 36
            Coil L7 voltage
            U3 ic
            Pin 1.6 voltage
            • L7 = look @ picture above
            • U3 - can't find it on PCB
            • Techtiger
              • Oct 2014
              • 1602
              • france
              TPS 51125
              PIN 1.6.13.23 Voltage
              if TPS 51125 getting hot considering all the symptoms, it seems tps51125 is faulty itself. but I am not sure. you have to test caps & resreters near
              Bios Pin 8 Voltage
              KBC VCC pin14 Voltage
              In addition to TPS 51125 KBC might me be faulty if it's not sending ENTRIP1 and ENTRIP2
              may be some one else can take from this point
              • bpjl
                • Jun 2016
                • 28
                • Polska
                TPS 51125:
                • pin 1 = 1V
                • pin 6 = 1.4V
                • pin 13 = 1.2V
                • pin 23 = 0V
                Bios Pin 8 Voltage
                • pin 8 = 3.2V
                KBC
                • pin 14 = 3.2V
                • Techtiger
                  • Oct 2014
                  • 1602
                  • france
                  TPS 51125:
                  pin 23 = 0V on the pin23 of tps51125 you must be +3v that is your 3v/5v power good signal correct if i wrong some one else do you get 3.3V in power button ? try to flash bios with a working on or change TPS51125
                  • bpjl
                    • Jun 2016
                    • 28
                    • Polska
                    For lack of time, I put off work with this netbook for later. Then suddenly came the opportunity to buy exactly the same computer, with a broken screen, for little money.
                    Further solution to the problem was simple
                    Thank you all for your help and best regards.
                      09-07-2024, 05:50 AM
                      09-06-2024, 11:40 PM
                      09-06-2024, 08:40 PM
                      Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                      This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                      09-06-2024, 06:20 PM
