Lenovo Ideapad 305-14ibd... Check This Out
  • lorins_core
    BlackSmith
    • Dec 2012
    • 551
    • Philippines
    Good Day To All.
    Laptop Model: Lenovo Idea-Pad 305-14IBD
    MOBO PN: ZIWB2/ZIWB3/ZIWB1
    LA-B091P REV:3.0 2014-12-22
    *PROBLEM : No Display After 3 or 4 seconds turn of. ( Fan Spin then Stop)
    I Check The Following Voltages
    On Rails 20V - Present
    On 3.3VALW - Present
    On 5VALW - Present
    I try to flash the Rom Bios Not Luck
    Check the rails to this Parts (test Actual Plug in the Ac Adapter but system off)
    PQ301(AO4407AL_SO8)
    123 (S) - 20.4V
    4 (G) - 8.5V
    5678 (D) -20.4V
    PQ302 (AO4455_SO8)
    123 (S) - 20.4V
    4 (G) - 8.5V
    5678 (D) -20.4V
    But I notice why? Still 8.5V? either the System check volts turn on and Check turn off as a Same 8.5V? hmmm?
    Any Advice
    Tia
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Lenovo Ideapad 305-14ibd... Check This Out
    20V on B+ is fine. (gate voltage at 8.5V is perfectly fine too)
    Measure voltage on +CPU_CORE and PLT_RST#
    • lorins_core
      BlackSmith
      • Dec 2012
      • 551
      • Philippines
      Sir Here's the Result of Test
      Here The Result
      +CPU_CORE
      OFF= 0
      ON = 1.6V
      PLT_RST#
      OFF= 0
      ON= 0
      *OHM TEST*
      PL1102(+CPU_CORE) = .04 OHM
      U3 (PLT_RST#)= OPEN
      • piernov
        • Jan 2016
        • 4435
        • France
        Check SYS_PWROK, PCH_PWROK, H_CPUPWRGD
        • lorins_core
          BlackSmith
          • Dec 2012
          • 551
          • Philippines
          *SYS_PWROK =
          ON =2.3V then Drop Down
          OFF=.08 then Drop Down to 0.01V
          *PCH_PWROK=
          ON= 2.4V then Drop Down 0V
          OFF= .60V then Drop Down 0v
          *H_CPUPWRGD
          I cannot Found on Actual Mobo Part
          But I have A Schematic Diagram...
          Do you have ViewBoard fo This?
          • lorins_core
            BlackSmith
            • Dec 2012
            • 551
            • Philippines
            Follow Up for This....
            • lorins_core
              BlackSmith
              • Dec 2012
              • 551
              • Philippines
              Update For This.
              I Try To Change Power iC PU301- Original Part or PN of This BQ24735 Change To BQ24737.
              All of The Sudden Not luckily Turn ON. Now Totally Dead Set. i change and Back to The
              The Original Part BQ24735. owww..
              What Going On.
              Voltage Rail
              *Before
              PQ301(AO4407AL_SO8)
              123 (S) - 20.4V
              4 (G) - 8.5V
              5678 (D) -20.4V
              PQ302 (AO4455_SO8)
              123 (S) - 20.4V
              4 (G) - 8.5V
              5678 (D) -20.4V
              After
              Now ...
              PQ301(AO4407AL_SO8)
              123 (S) - 23.1V
              4 (G) - 23.1V
              5678 (D) -23.1V
              PQ302 (AO4455_SO8)
              123 (S) - 23.1V
              4 (G) - 23.1V
              5678 (D) - 0V
              Any Advice?
              • piernov
                • Jan 2016
                • 4435
                • France
                BQ247x7 and BQ247x5 are *not* compatible. You have to use the correct one.
                • lorins_core
                  BlackSmith
                  • Dec 2012
                  • 551
                  • Philippines
                  What Did you think?
                  The Power Ic. Broken BQ247x7?
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Originally posted by lorins_core
                    What Did you think?
                    Now you have short in B+ line and thats why pin5-8 of mosfet reads 0v
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Remove PR302(to isolate B+ line) and then connect ac adapter. Check voltage on PQ301/302 again.
                      • lorins_core
                        BlackSmith
                        • Dec 2012
                        • 551
                        • Philippines
                        I do your Advice remove the Resistor as you said PR302
                        Reading
                        PQ301(AO4407AL_SO8)
                        123 (S) - 24.3V
                        4 (G) - 24.3V
                        5678 (D) -24.3.V
                        PQ302 (AO4455_SO8)
                        123 (S) - 24.3V
                        4 (G) - 24.3V
                        5678 (D) - 0.8V
                        Other?
                        • lorins_core
                          BlackSmith
                          • Dec 2012
                          • 551
                          • Philippines
                          Originally Posted by lorins_core View Post
                          But do this simple test
                          I Jumper the PQ302 with back the PR302
                          Source To Drain
                          PQ301(AO4407AL_SO8)
                          123 (S) - 24.3V
                          4 (G) - 24.3V
                          5678 (D) -24.3.V
                          PQ302 (AO4455_SO8)
                          123 (S) - 24.3V
                          4 (G) - 24.3V
                          5678 (D) - 24.3V
                          The Voltage is Same as Same. Now the PIN no1 & no20 have 24.1 before Nothing Voltage.
                          1.try to Test press power on unit has been turn on But the Charging light Blinking color Orange.
                          2.try to Test with Battery Installed. press power on unit has been turn on But the Charging light Blinking color Orange. Fan Spin then 5 sec fan Stop Spin?
                          Both Light indicator on Power & Charging (Orange) Blinking
                          I dont Know meybe Sleep mode... hehehe
                          • lorins_core
                            BlackSmith
                            • Dec 2012
                            • 551
                            • Philippines
                            I think it is a one of may Hard Repair incounter...
                            Although I check the Always Voltage
                            3.3V now 4.2V
                            5V now 6.4V
                            High Voltage?
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3593
                              • slovakia
                              way too much but check again. there is not many way to have this high voltages
                              maybe u have bad battery in multimeter
                              • on/off
                                • Oct 2016
                                • 333
                                • Indonesia
                                First, sorry...
                                just talking about the fact on this thread.
                                Second. About Your diagnose.
                                You judge: No display
                                Symphtom: Power up but then shutdown immediately approx 3-10 second.
                                General of laptop problems:
                                -Doesn't react to power button and doen't charge the battery + led the adapter off immediately.
                                -Doesn't react to power button and doesn't charge battery.
                                -Doesn't react power button but the battery charging is working.
                                -Power on but the battery charging doesn't work.
                                -Power on but then shutdown immediately.
                                -Power on but doesn't display anything on the screen.
                                Third. I think that you working repair without any data include schematic, datasheet and learn from experience other people here in this forum section.
                                Starting from page 1 to 55. all pages must be reading properly.
                                example page 1 : Information about code board, manufacture, date of release.
                                page 2 and 3 : Note this!!!. if all system always voltages was Okay (B , 3Valw and 5Valw) you see all peripherals working control by Chipset (in this case Intel SoC-page 1 SoC act as center ).
                                that is the fact, from RTC (page 7,8 and 13), on/off button (pwrbtn signal-page 9) and other important signals should be trigger by intel Soc. That chip work need external chip for give command for any regulators (a part system power management inside SoC,page 9), that was handle by KBC (SIO/EC) chips. I think for safety SoC itself,
                                and of course also helped by bios chip as a Basic Input Output System. porpose to power up any voltage that require by Ram, SoC and CPU. As you know when we enter bios setup, only need 3 of components have working fine without sound, lan, hdd and so be attached (like desktop computer)
                                Reason : #post 1. 20V, 3valw and 5valw were present. so should be to checking what are any important signal to trigger for power plane S3 and S0 state (see voltage rails table).
                                Fourth : You have done for replacement to fix is far from your diagnose.
                                No display, but you replace ic of charger.
                                If 20V, 3 and 5 alw present, 70% that chip is Okay.
                                the worst thing is wrong replacement part, from BQ737 to BQ735.
                                Datasheet required to understand "How its Work"
                                BQ's family chip mostly act as power selector, whether are from adapter or battery source for feeding supply all systems.
                                see ACDRV and BATDRV signal to trigger gate of mosfet ACFET and BATFET.
                                BQ737 need P-Channel mosfet for ACFET and BATFET. Gate mostly need signal voltage half from VIN 19V/2 = approx 8V-9V (depend of resistor divider sircuit on schematic).
                                BQ735 nedd N-Channel mosfet for ACFET and BATFET. Gate mostly need signal voltage VIN+6V = approx 24V-27V.
                                These only that all what i've known. still far away from the real "how computer is work". Since we are here porpose to digging any knowledge about Troubleshooting laptop.
                                Really sorry and sad for this happened.
                                • on/off
                                  • Oct 2016
                                  • 333
                                  • Indonesia
                                  Hope it help:
                                  • lorins_core
                                    BlackSmith
                                    • Dec 2012
                                    • 551
                                    • Philippines
                                    hehehe Thanks Man... i think Already to Change little adjust Voltage.
                                    I decided to Change PU301... Same Original and PN:
                                    Answer... Done
                                    the Unit Work Fine... Only the Problem of this Laptop... PU301 i have a extra Unit no display take the PU301. same Part no.
                                    Well the Problem Solve... thanks to mcplslg123 & piernov & on/off for you explanation. you open my close mind for this Model...hehehe. Thanks Again
                                      Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                                      This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-07-2024, 05:20 AM
                                      Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                                      This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                                      This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                      Lenovo IdeaPad IdeaPad 3 17ITL6 Ultrabook 3 Specification for Upgrade or Repair
                                      This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-07-2024, 05:00 AM
                                      Lenovo IdeaPad IdeaPad 1 14IJL7 Notebook 1 Specification for Upgrade or Repair
                                      This specification for the Lenovo IdeaPad IdeaPad 1 14IJL7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 1 14IJL7 boardview and IdeaPad 1 14IJL7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
