Lenovo ID pin resistor values
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Hello, as you know, for Lenovo laptop, the AC adapters have an identification pin. They use a simple system with a resistor to ground from the ID pin.
    Here are some values for the resistors:
    65W adapter: 270 ohms
    45W adapter: 116.5 ohms (you can use 120)
    We had a T450s in with trouble recognizing adapter, due to poor quality power jack (not broken, just poor quality). Tried 3 adapters and it was hit and miss on all of them. I have disconnected the ID pin from the connector that plugs in the motherboard, and soldered a 270 ohm resistor from the connection of the ID pin to ground. Now any adapter plugged in is recognized as 65W, no problem charging the battery now.
    A working TV? How boring!
  • RethoricalCheese
    • Mar 2013
    • 1518
    • Estonia
    Re: Lenovo ID pin resistor values
    http://www.thinkwiki.org/wiki/Power_Connector
    I've also made a little tester for laptop chargers. Still a 1 hour prototype but one day it will be made into a real tool, hopefully this year.
    https://www.badcaps.net/forum/showthread.php?t=70627
    Oh and for some reason, some 65W chargers have resistor for 90W charger for some reason. So it's not always accurate.
    • petehall347
      • Jan 2015
      • 4426
      • United Kingdom
      so there is maybe a circuit that works out ohms law to find the wattage . or maybe 2 circuits .
      • RethoricalCheese
        • Mar 2013
        • 1518
        • Estonia
        You mean on the laptop side? Probably just makes up a voltage divider and uses a comparator to see if the voltage is lower or higher than reference. But I wouldn't actually know, have not looked at motherboard schematic to see what's there exactly.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Good Workaround boss......
          • starcellnindiri
            • Sep 2021
            • 7
            • Nicaragua
            did anyone knows about the value of lenovo 230w charger?
            i have one with 4500ohms i dont know if its good or bad
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3588
              • slovakia
              |45 W |120 Ω |
              |65 W |280 Ω |
              |90 W |550 Ω |
              |135W |1 kΩ. |
              |170W |1.9 kΩ|
              the resistance raises by wattage level. next wattage would have resistance little less than 4k
              • JaroTech
                • Mar 2015
                • 351
                You have the right value for your charger.
                https://www.thinkwiki.org/wiki/Power...230W_11.5_Amps
                • tomodachi
                  • Apr 2012
                  • 602
                  • Turkey
                  Originally posted by ktmmotocross
                  |45 W |120 Ω |
                  |65 W |280 Ω |
                  |90 W |550 Ω |
                  |135W |1 kΩ. |
                  |170W |1.9 kΩ|
                  any charger above 170w have 4.5~5 kOhms resistance.
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3588
                    • slovakia
                    than u have 230W charger
                    • nebv
                      • Aug 2014
                      • romania
                      Hi, my Thinkpad E560 can`t be powered up anymore . No LED. I changed the mainboard with another one apparently working before with all modules. Same problem. The charger is a 45W one, but the resistor has 178Ohm. I opened the connector and changed the resistor with 120Ohm. Same problem. Any Ideas? THX
                      • nebv
                        • Aug 2014
                        • romania
                        I even tried to put 10 0hm on the output of the charger (ca 2A) The charger can supply also 20V by 2A and seems to be OK.
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          Apparently isn't "certainly". Borrow another genuine charger to test. My gut instinct says you have a motherboard problem or power jack problem and the charger is fine.
                          • tarum2003
                            • Mar 2011
                            • 15
                            Hii..
                            What should be the resistance value for a 300 watt adapter?
                            • tarum2003
                              • Mar 2011
                              • 15
                              I found..
                              thnk. VUSAL expert
                              8.6KOHM
                              • mon2
                                • Dec 2019
                                • 14118
                                You have a 300 watt adapter?? How big is this thing??
                                • gica69
                                  Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
                                  by gica69
                                  I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
                                  Resistor shows orange range silver gold and green lines.
                                  Thanks in adv...
                                  07-21-2025, 09:49 PM
                                • Kobok
                                  Different (lower) resistor values on PCB?
                                  by Kobok
                                  Dear Alls,
                                  For sure it id a stupid question, but help me to understand. I am in a Dell 2007WFP revitalizing project - searching reason why not starting. Some resistors needed to replaced is is obvious. When I have soldered some resistors the measured (with multimeter) values were sometimes rather different written on them. I supposed these are wrong units so I desoldered and made a checking measurement and voilá the values is the same is written on. This happens only in case of a few resistors, most have the same values (+/- 10%) are written on it. "strange" SMD resistors =>103...
                                  09-19-2022, 07:30 AM
                                  Lenovo 3000 Series Schematic
                                  Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                  3000 C100 laptop with Braille keyboard
                                  Lenovo 3000 C
                                  C100, C200 - 15-inch XGA screen
                                  Lenovo 3000 N
                                  N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                  N500 - 15.4 inch screen.
                                  Lenovo 3000 V
                                  V100, V200 - 12.1-inch WXGA models
                                  Lenovo 3000 G
                                  G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                  10-04-2024, 06:05 AM
                                  Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                  This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                  09-06-2024, 06:40 AM
                                  This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                  09-06-2024, 06:06 AM
