DAUT3MB28C0 missing components on battery power circuits
  • magnetepazzo
    • Feb 2017
    • 85
    • italy
    Hi friends , I have received from a customer this pavilion dv5 with this mb DAUT3MB28C0, the problem is short in power and missing component near battery connector I think a capacitor and a diode, it's possible to say wath is pc120 and c654 ? thanks
    • 20633
    Re: DAUT3MB28C0 missing components on battery power circuits
    You need the schematic.What revision number is the board .
    DAUT3MB28C0 Rev:
    • magnetepazzo
      • Feb 2017
      • 85
      • italy
      DAUT3MB28C0 Rev:
      REV C
        • 20633
        Rev C is the ATI graphics version. Does it have DDR2 or DDR3 . There isn`t a free schematic for the ddr3 version , http://**************/load/noutbuki/.../307-1-0-29432 .For the DDR2 version schematic there isn`t an ATI version,only Nvidia, so there will be differences but you can use it for reference .
        • BlueMidnight
          • Jan 2015
          • 489
          It's important to note that the one component is actually marked PC128 and not PC120. It's a 10uF 25V capacitor.
          I'm not sure if the schematic available for purchase is any different or if they are all pre-production versions that don't show C654. There are also boardviews available, and they may or may not show C654. Any revision that shows it should be fine, as that circuit is pretty much the same for all of them.
          There's a thread on a Polish site where the exact same caps burned up. They ended up using a 2200pF 50V capacitor for C654 simply because that's what PC182 is. But that was just a wild guess. C654 certainly is a lower capacitance part than PC128 though, and is for reducing higher frequency noise on that power rail for either stability or EMI compliance reasons.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            dear friend, if your mobo has ati or nvidea-then its a colossal waste of time as all these mb has problems in graphics chip. So consider this also while investing your time on it.
            • magnetepazzo
              • Feb 2017
              • 85
              • italy
              ATI
              • tibd
                • Oct 2014
                • 189
                • Sweden
                More pics with wider view?
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • mkdj
                  ASUS X571 no power : battery issue?
                  by mkdj
                  Mark and model: ASUS X571
                  Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                  Tests already made:
                  - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                  - I have removed...
                  07-14-2025, 09:16 AM
                • techfreak9356
                  Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                  by techfreak9356
                  I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                  09-14-2023, 11:10 PM
                  NVDC charger configuration...
                  11-05-2024, 03:28 PM
                • ferah831208
                  Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                  by ferah831208
                  Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                  03-18-2025, 01:18 AM
