Asus Q502L does not boot up properly
    • 21457
    Re: Asus Q502L does not boot up properly
    I think PQ8102 is the culprit.Remove it and see if PU8100 still gets hot. I`d get a 2nd opinion from @caspian though.
    • tibimakai
      • Jan 2012
      • 3680
      I will remove both FETs(PQ8102 & 8103) and see what happens.
      • tibimakai
        • Jan 2012
        • 3680
        So there is no short, but for some reason, the output voltage is very low. 5V is 0.156V(76 Ohm) and 3.3V, is 0.043V(48 Ohm). PU8100 still getting hot.
          • 21457
          I think its just a process of elimination at this point.You removed PQ8102,8103 ,look at what else is connected to pin 18 of PU8100 ,theres PR8107,PC8106 and PL8101 . Remove all those parts and do a brief power test ,if the PU8100 still gets hot solder those parts back on,and go onto the next pin e.g. pin 1 - remove PR8103
          • tibimakai
            • Jan 2012
            • 3680
            Thank you, I will try that.
            What is low resistance, is pin #4, at only 2 Ohm.
            Do you think, that it's OK? To me, it sounds way to low.
            • tibimakai
              • Jan 2012
              • 3680
              I have been busy lately, with other stuff. I'm not giving up.
              I'm also working on an Onkyo home theater that had a power surge, so has a short somewhere. Working on my garage as well.
              I was thinking, that is a good idea to remove the two FETs(PQ8102 & PQ8103), from the output of PU8100 and turn it on? Or only, with the solder bridge(PJP8101) removed?
              • caspian
                • Oct 2015
                • 1591
                • Laptop
                #87
                it is great that you are back. I was away last week too. So I did not see the posts in page5 before. If you work on this laptop more often, Badcaps technicians do not forget the repair details, so they can help you better. If a big time gap is made between updates in this thread, I will forget the details and I have to read all the previous posts again. So far, I think you replaced PU8100 once. Please upload a photo of PU8100 and the components near it. If there is still any short there, do not connect power to the laptop. At this point, you have to remove a number of components until all the shorts are completely removed. First remove PQ8102 and PQ8103 and PJP8101. Then, if there is a short, remove PU8100. Then, if there is a short, remove the capacitors near PU8100. I hope there is a local IC supply, so that you can order and replace any IC easily. Thus, start removing them using a hot air station.
                • tibimakai
                  • Jan 2012
                  • 3680
                  I will come back to this, this weekend. Sorry about that, but I have a water pipe leak issue, my car had some issues, my wife's Kenwood unit died.
                    • 21457
                    Bad luck comes in threes. If you want to repair the kenwood - https://www.badcaps.net/forum/forumdisplay.php?f=8
                    • tibimakai
                      • Jan 2012
                      • 3680
                      Sorry, I don't get it with that link.
                      The only thing that happens with it, is the backlight comes on, the red triangular(reset button) LED and the fan.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        I took that picture. PCB is not cleaned, as you can see.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          Any help?
                            • 21457
                            Originally posted by tibimakai
                            Any help?
                            Yes, just need some time to read through the thread again.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              Sorry about that.
                              This was pointed toward caspian.
                              • caspian
                                • Oct 2015
                                • 1591
                                • Laptop
                                #95
                                First you have to remove the shorts. what have you done from the removing jobs that were recommended in Post88?
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  Forget about those, I will remove them today.
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    OK, I have removed PQ8102, PQ8103 and opened up PJP8101. At pin #18 of PU8100 I'm getting only 3.5V, and PU8100 is still hot.
                                    At coil PL8101(main 5V coil), I measure 77 Ohm. At coil PL8100(main 3.3V coil), I measure 15.7 Ohm.
                                    • caspian
                                      • Oct 2015
                                      • 1591
                                      • Laptop
                                      #98
                                      now, it is time to remove PU8100. then remeasure the resistances mentioned in Post98. then, keep PU8100 removed to be able to do some more measurements.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        Sorry to be so late, but I'm working on multiple devices.
                                        I have removed the PU8100(new once came in as well) and I have measured all the pins, here are the results:
                                        Pin #1= 36.2K, Pin #2= ~7K, Pin #3= 2 Ohm, Pin #4= 10k, Pin #5= 36K, Pin #6= 220K and goes up, Pin #7= 94K, Pin #8= 15.6K, Pin #9= OL, Pin #10= 10K, Pin #11= OL, Pin #12= 6k goes down, Pin #13= 5M and goes up, Pin #14= ~14K, Pin #15= OL, Pin #16=23K and goes up, Pin #17= OL, Pin #18= 15K and it goes up, Pin #19= 170M and goes up, Pin #20= 200k and goes up.
                                        At PL8101, it starts around 1M, than drops and then goes up toward 15k.
                                        At PL8100 it is a stable 15.6 Ohm.
                                        • caspian
                                          • Oct 2015
                                          • 1591
                                          • Laptop
                                          #100
                                          now remove PQ8100, PQ8101 and open up PJP8102, PJP8103, PJP8104, and PJP8105. then, connect PJP8101. then, measure resistance on PL8100. keep previous components removed.
                                          • throwaway327
                                            by throwaway327
                                            Model No: RC72LA
                                            Serial No: SBNVKD001014459
                                            06-18-2025, 05:52 PM
                                          • jrodefeld
                                            Asus laptop won't boot (no power) - possible bad caps?
                                            by jrodefeld
                                            I would like to see if anyone could help me salvage a very expensive laptop that is no longer working.
                                            The model:
                                            Asus Zenbook Pro Duo UX582L
                                            I have used this laptop lightly since I purchased it new in 2022. I have always taken precautions to take care of it the best I could, and have never done anything that would risk causing damage to it or shorten it's life.
                                            However, around six months ago, the laptop stopped working on battery power. It continued to work fine when plugged in, but as soon as power was disconnected,...
                                            09-02-2024, 04:55 PM
                                          • acata
                                            Asus X450LC REV 2.2 can't boot to anything
                                            by acata
                                            I get this Asus X450LC REV 2.2 can't boot from SATA, ODD or USB flash drive.
                                            Power on normally. Boot to bios ok.
                                            But I can't normal boot from HDD (windows 7) just freeze on the animation. I can't boot from pre-installed SSD windows 10, bsod: driver pnp watchdog. I can't boot USB flash drive Hiren boot CD or linux mint.
                                            10-10-2023, 05:15 AM
                                          • lukkihapsi
                                            Asus Vivobook X515JA Weird Boot Issue
                                            by lukkihapsi
                                            Asus Vivobook X515JA Laptop
                                            Issue :
                                            Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
                                            Tried :
                                            Cleaned inside for dust, applied fresh thermal paste. No Change!
                                            Removed keyboard, Trackpad, fingerprint sensor. No Change!
                                            Removed Internal SSD. No Change!
                                            Updated BIOS to latest version. No Change!
                                            Removed battery and pressing power button for 1 minute. No Change!
                                            Weird Part :
                                            Upon turning laptop ON, screen lights up - stays black,
                                            I...
                                            07-07-2025, 12:07 PM
                                          • futadmytro
                                            Asus g713qm-es94 stuck on boot bios problem
                                            by futadmytro
                                            sn^M4NRKD02753616E
                                            MB- g533-6050a3250201-MB-A03
                                            Stuck on boot after ROG logo, did not enter to bios
                                            In flash bios , laprop boot but have video issue
                                            orig bios...
                                            06-25-2025, 08:07 AM
