Asus Q502L does not boot up properly
  • tibimakai
    • Jan 2012
    • 3680
    I have picked up this laptop, without hard drive and only with the motherboard soldered memory.
    It starts up, LED is on and fan spins slow/fast/slow/fast a couple of times, that settles, on the fast spin. Nothing shows on the screen, not even backlight. I have tried with external monitor, still nothing.
    I have to admit a mistake that I have made, but did not change a thing.
    While it was on, I have pulled the display plug and blew up a capacitor, that goes to the battery(16.3V).
    If I plug in the charger, the battery LED is on.
    I don't have experience, with laptop repairs. I have repair equipment.
    I would appreciate any help, that I could get.
    Asus Q502LA-BBI5T12
    • 20659
    Re: Asus Q502L does not boot up properly
    I think on this model the soldered memory is VRAM. Install some memory and see, and replace the blown cap. There`s no motherboard schematic available, but there is a boardview file, i can`t find a free one anywhere. https://***********/threads/asus-q502la.20646/ .EDIT: if you need the boardview ask on this forum if anyone has it .
    • tibimakai
      • Jan 2012
      • 3680
      OK, I have soldered in another capacitor. No change.
      There are two pins at the display connector, that it seems like a previous person "played" with it, because they are not nice and straight. To me, it seems like they should still make contact, though.
      I have removed a FET above it, because it seemed like it is shorted, but after I have removed it, it wasn't.
      I'm kind of confused about these FETs, how they should show with the meter.
      There are two at the bottom, that at least one shows like it is shorted.
      Definitely, the 1.8V coil gets pretty warm. With Ohm meter, shows 27 Ohms, which is not good.
      CPU is cold.
      I have also installed a memory card, but did not change anything.
      • BlueMidnight
        • Jan 2015
        • 489
        The part that blew by the display connector was a ferrite bead. Not a capacitor.
        That 1.8V rail is CPU core power (which can range anywhere from 1.5V to 1.84V for that CPU). It's supposed to have a low resistance. That goes along with low voltage and high current. Reading double digits for resistance is not alarming.
        The other places labeled as a short to ground are really just... ground. Those pairs of FETs are buck converters. They have a supply voltage on one side of the pair, ground on the other, and the output voltage in the middle.
        • tibimakai
          • Jan 2012
          • 3680
          So, if the "capacitor" is gray, than it is ferrite bead?
          What are these boardviews? I have never heard about them before.
          If the 1.8V is there, why the cpu is not getting warm?
          What should I look for?
          Thanks kotnatan, but I don't know what to do there. I have past the test and I'm stuck there.
          • tibimakai
            • Jan 2012
            • 3680
            I have forgot to mention, that if I plug in the power adapter, it constantly reboots, I can't stop this process. On battery, the fan just keeps spinning, at high RPM and can be stopped, with a long press of the power button.
            Why initially, the fan RPM keeps changing, before it settles on high constant RPM?
            It could be, a bad BIOS chip as well?
            • kokono
              • Jun 2018
              • 203
              At this time, i have exactly this problem in Asus X555LD
              "It starts up, LED is on and fan spins slow/fast/slow/fast a couple of times, that settles, on the fast spin. Nothing shows on the screen, not even backlight. I have tried with external monitor, still nothing."
              "that if I plug in the power adapter, it constantly reboots, I can't stop this process. On battery, the fan just keeps spinning, at high RPM and can be stopped, with a long press of the power button."
              any person have idea ?
              my cpu and chip graphic ist warm
              • tibimakai
                • Jan 2012
                • 3680
                I have just read your thread today and I thought the same thing, that sounds the same issue.
                I'm new to laptop repair.
                I'm wondering, can't be a corrupt BIOS chip?
                It seems, like I have the right voltages as well.
                Do you know the history of yours? What happened to it?
                I have purchased it like this, so I don't know.
                • kokono
                  • Jun 2018
                  • 203
                  your motherboard have onboard RAM ?
                  • tibimakai
                    • Jan 2012
                    • 3680
                    Yes, and the seller has mentioned, that bad RAM may be the case.
                    Can we cut the trace, that powers it?
                      • 20659
                      No. Your motherboard is different to @kokono .In his case the memory MAY be bad,there are some guides on how how to disable his RAM which involves moving caps and resistors to different places., if you do a google search "x555l disable ram" theres some guides on youtube,various forums, and bios/schematic sellers such as vinafix also sell guides. @BlueMidnight is giving you advice, it would help though if you had the schematic, if you can`t get one for free buy one,they don`t cost much.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        I don't have a problem buying the schematic, but from where?
                        On the Russian site, I'm lost.
                        I will find a ferrite bead and I will replace that capacitor, but I don't have any other lead, that I can follow.
                        • tibimakai
                          • Jan 2012
                          • 3680
                          Anybody has a BIOS dump?
                          I'm trying one, posted on this forum, but it makes the laptop even worse.
                          Power LEDs, just keeps blinking under AC adapter.
                            • 20659
                            Upload your original bios if you saved a backup .
                            • tibimakai
                              • Jan 2012
                              • 3680
                              I will when I get home.
                              I'm new to flashing. I have a TL866A programmer.
                              When I did a Verify, I had a bunch of red FFFFFs. I don't remember, what was the error in red.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                I hope, that is OK how I did it.
                                I have re-flashed the original chip, with this file, without any errors.
                                Later I will solder it back, to see what happens.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  I'm looking at the original dump and to me, it seems like it is empty. I did something wrong, when I have read it?
                                  • cacla
                                    • Apr 2015
                                    • 442
                                    In asus system there is 2 models i will need the sn to find the right one but still i will upload the 2 files
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      I'm at work right now, so I don't have that. I will check that when I get home.
                                      The model number is this: Asus Q502LA-BBI5T12. 4th gen i5 CPU.
                                        • 20659
                                        Are you using a clip to read the bios,or have you desoldered it. Is your tl866 software up to date, and what part number is the bios .
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • jrodefeld
                                          Asus laptop won't boot (no power) - possible bad caps?
                                          by jrodefeld
                                          I would like to see if anyone could help me salvage a very expensive laptop that is no longer working.
                                          The model:
                                          Asus Zenbook Pro Duo UX582L
                                          I have used this laptop lightly since I purchased it new in 2022. I have always taken precautions to take care of it the best I could, and have never done anything that would risk causing damage to it or shorten it's life.
                                          However, around six months ago, the laptop stopped working on battery power. It continued to work fine when plugged in, but as soon as power was disconnected,...
                                          09-02-2024, 04:55 PM
                                        • acata
                                          Asus X450LC REV 2.2 can't boot to anything
                                          by acata
                                          I get this Asus X450LC REV 2.2 can't boot from SATA, ODD or USB flash drive.
                                          Power on normally. Boot to bios ok.
                                          But I can't normal boot from HDD (windows 7) just freeze on the animation. I can't boot from pre-installed SSD windows 10, bsod: driver pnp watchdog. I can't boot USB flash drive Hiren boot CD or linux mint.
                                          10-10-2023, 05:15 AM
                                        • lukkihapsi
                                          Asus Vivobook X515JA Weird Boot Issue
                                          by lukkihapsi
                                          Asus Vivobook X515JA Laptop
                                          Issue :
                                          Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
                                          Tried :
                                          Cleaned inside for dust, applied fresh thermal paste. No Change!
                                          Removed keyboard, Trackpad, fingerprint sensor. No Change!
                                          Removed Internal SSD. No Change!
                                          Updated BIOS to latest version. No Change!
                                          Removed battery and pressing power button for 1 minute. No Change!
                                          Weird Part :
                                          Upon turning laptop ON, screen lights up - stays black,
                                          I...
                                          07-07-2025, 12:07 PM
                                        • futadmytro
                                          Asus g713qm-es94 stuck on boot bios problem
                                          by futadmytro
                                          sn^M4NRKD02753616E
                                          MB- g533-6050a3250201-MB-A03
                                          Stuck on boot after ROG logo, did not enter to bios
                                          In flash bios , laprop boot but have video issue
                                          orig bios...
                                          06-25-2025, 08:07 AM
