Asus Q502L does not boot up properly
  • tibimakai
    • Jan 2012
    • 3680
    Re: Asus Q502L does not boot up properly
    I'm committed to repair it. I will buy what is needed.
    The ferrite bead is already purchased, I just need to replace it.
    • caspian
      • Oct 2015
      • 1589
      • Laptop
      #62
      you need to do lots of measurements. first, start with Post58 when you will have free time.
        • 20508
        Can you also test,with no power to the board PR8108,it should be 10K ohms and PQ8101 pin 4 ohms to gnd
        • tibimakai
          • Jan 2012
          • 3680
          PL8100 is 450 Ohm and PL8101 it keeps changing, but it is around 16 kOhm, to GND.
          PR8108 it measures 9.38 KOhm.
          PQ8101 pin 4 to GND, measures: 134.6 kOhm.
          No problem measuring a lot, this is my hobby, fixing electronics. I have the equipment to do it, as well. Fluke 189, 87V.
          Usually, I repair Onkyo receivers. I used to repair LCD/LED TVs.
          • caspian
            • Oct 2015
            • 1589
            • Laptop
            #65
            without the main battery, plug the AC adapter in but do not turn the laptop on. then, check whether PU8100 gets hot or not. In addition, measure voltage on PL8100 , PL8101 , and pin7 of PU8100. unplug the AC adapter ASAP if PU8100 is getting hot.
            • tibimakai
              • Jan 2012
              • 3680
              The IC gets hot, when I plug in the AC.
              Before, it used to reboot over and over, with AC. With battery, only started once.
              PL8100 and PL8101 voltages are raising and dropping, since it is rebooting. The 5V(PL8101) does not reach 5V, only 3.9V.
              • tibimakai
                • Jan 2012
                • 3680
                Soon I will measure pin #7.
                • caspian
                  • Oct 2015
                  • 1589
                  • Laptop
                  #68
                  In addition, measure resistance on all pins of PU8100 and report if you find any pin with less than 1000 ohms.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    I'm stopped, because I don't trust my soldering job, on the PWM.
                    I don't have a microscope and I can't be sure if it is soldered correctly.
                    Every time I try re-soldering, I'm getting different results. Now I have lost 3V(0.8V), 5V is only 0.8V, but nothing oscillates.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      #70
                      It seems Either 3v or 5v(or both) lines are shorted. Might be 2 pins got connected while soldering or reading voltage.
                        • 20508
                        Soldering these small qfn chips without a microscope is very difficult,its 50/50 . USB microscopes are quite good,and cheap,the andonstar ones are ok.Its a good idea to find a few scrap boards and practice on those first,and theres lots of youtube videos
                        https://www.youtube.com/watch?v=mr1UVPsExiE
                        https://www.youtube.com/watch?v=c_Qt5CtUlqY
                        • tibimakai
                          • Jan 2012
                          • 3680
                          I have a cheap Celestron microscope, but unfortunately I can use only to inspect with it. It doesn't have a proper stand.
                          The biggest problem now is, that I have ripped off, pin #9 trace. I will give it a try, with a thin wire, but ods don't look good, to be a successful repair.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            I have managed to solder the IC back. Definitely, I have a shorted on the 5V rail.
                            I have measured all the FETs around the IC, and only only one shows short PQ8103, but after I have removed it, it measures good and short is still there.
                              • 20508
                              With PQ8103 removed which pin measures short.If its pin 4 remove PC8102 and check pin 4 again.If its pin 5 can you desolder the jumper at PJP8101, test if 5V is stable,and also measure without power ohms to gnd .
                              • tibimakai
                                • Jan 2012
                                • 3680
                                I have re-soldered PQ8103, right after removing it.
                                Right now, pin 4 is not shorted. Pin 5 is shorted.
                                Pin 5, shows about 1.3 Ohm. Capacitor is not shorted. It shows 1nF(on PCB w/Fluke 189).
                                It seems like, the IC(TPS1285B) that I have just soldered in, it may be shorted?
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  OK, I have managed to solder in, the PU8100 and I have low resistance on these three pins.
                                  Pin #14: 2.34 Ohm (+5V SUSO)
                                  Pin #15: 1.94 Ohm (P_5VSUS_DL_30)
                                  Pin #18: 2.32 Ohm (P_5VSUS_LX_30)
                                    • 20508
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      One one side, I measure 19.5V and on the other, only 3.55V.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        Where should I measure the 5V, at the coil?
                                        • tibimakai
                                          • Jan 2012
                                          • 3680
                                          OK, I have de-soldered PJP8101 and at the 5V coil, I'm getting 0.055V. At 3V coil, I'm getting 0.017V.
                                          I have also noticed, that at Pin #3(PU8100) I have 2 Ohm, at capacitor PC8103).
                                          At 5V coil, I measure 76 Ohm.
                                          PU8100, is still getting very hot very fast. Should I order another one?
                                          • throwaway327
                                            by throwaway327
                                            Model No: RC72LA
                                            Serial No: SBNVKD001014459
                                            06-18-2025, 05:52 PM
                                          • jrodefeld
                                            Asus laptop won't boot (no power) - possible bad caps?
                                            by jrodefeld
                                            I would like to see if anyone could help me salvage a very expensive laptop that is no longer working.
                                            The model:
                                            Asus Zenbook Pro Duo UX582L
                                            I have used this laptop lightly since I purchased it new in 2022. I have always taken precautions to take care of it the best I could, and have never done anything that would risk causing damage to it or shorten it's life.
                                            However, around six months ago, the laptop stopped working on battery power. It continued to work fine when plugged in, but as soon as power was disconnected,...
                                            09-02-2024, 04:55 PM
                                          • acata
                                            Asus X450LC REV 2.2 can't boot to anything
                                            by acata
                                            I get this Asus X450LC REV 2.2 can't boot from SATA, ODD or USB flash drive.
                                            Power on normally. Boot to bios ok.
                                            But I can't normal boot from HDD (windows 7) just freeze on the animation. I can't boot from pre-installed SSD windows 10, bsod: driver pnp watchdog. I can't boot USB flash drive Hiren boot CD or linux mint.
                                            10-10-2023, 05:15 AM
                                          • lukkihapsi
                                            Asus Vivobook X515JA Weird Boot Issue
                                            by lukkihapsi
                                            Asus Vivobook X515JA Laptop
                                            Issue :
                                            Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
                                            Tried :
                                            Cleaned inside for dust, applied fresh thermal paste. No Change!
                                            Removed keyboard, Trackpad, fingerprint sensor. No Change!
                                            Removed Internal SSD. No Change!
                                            Updated BIOS to latest version. No Change!
                                            Removed battery and pressing power button for 1 minute. No Change!
                                            Weird Part :
                                            Upon turning laptop ON, screen lights up - stays black,
                                            I...
                                            Yesterday, 12:07 PM
                                          • futadmytro
                                            Asus g713qm-es94 stuck on boot bios problem
                                            by futadmytro
                                            sn^M4NRKD02753616E
                                            MB- g533-6050a3250201-MB-A03
                                            Stuck on boot after ROG logo, did not enter to bios
                                            In flash bios , laprop boot but have video issue
                                            orig bios...
                                            06-25-2025, 08:07 AM
