Yoga 700 11ISK multiple shorts
  • MichR
    • Jan 2016
    • 42
    • Italy
    I've got this Yoga laptop for a reasonable price. Seller said it suddenly turned off. However, he or someone else tried to repair it, making the situation even worse: he told me the NPCE388 has been replaced, but nothing else was done.
    Actually, some power supply jumpers have been desoldered. Sadly, all of these rails are shorted to ground.
    Before going on, take a look at the motherboard. This is the best quality picture I could find of it:
    And this is a particular of my board:
    I could not find any schematics of this board over the web. Luckily, I could find many similarities with the Yoga 3 motherboard, whose schematic I attached in this thread (look below).
    Thanks to this document I could name the shorted rails, which you can see in the image above in red text.
    I tried to supply the board with a constant current generator in order to isolate the short (up to 1A, with about 0.5W dissipated from the board). Sadly, I could not notice any component heating up. Actually, some of them warm up, but not that much, and I don't want to break anything since these boards are quite expensive.
    I also tried to desolder the EC since, according to schematics, many rails are going there and previous owner has replaced it, but the result didn't change.
    So I am looking for some help to isolate the issue.
    What's more, in the nearby of the EC there is a 3A linear regulator (APL5930). By comparing my board to the new one I could state that some of the components (in particular, configuration resistors that sets the output voltage and the output filter capacitor) are missing or misplaced.
    A pull-up resistor for the EC is also missing, but I've already placed a new one there.
    According to schematics, the two configuration resistors must be 1.54k and 1.74k. I could find the 1.74k in the correct position, but the two in the red circle are 10k (probably the pull-up resistor) and a 2.2k, which doesn't make much sense when calculating output voltage (I would get 0.8*(1+2.2k/1.74k)=1.81V, while with the schematics values, 0.8*(1+1.54k/1.74k)=1.51V). Also there's a 1nF capacitor, while in the schematics is used a 10nF one.
    If any with a similar board could measure the resistors and tell me the value will be really helpful. If not, at least please confirm that the generated voltage is 1.5V so that I can put a new 1.54k resistor there.
    Thank you
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Yoga 700 11ISK multiple shorts
    Putting up missing components is very difficult without schematics or exact same mb. However, That's secondary but priority should be to remove shorts. Without short removal, no point in pondering over the values of missing parts.
    • MichR
      • Jan 2016
      • 42
      • Italy
      Thank you for your prompt response.
      I know this is secondary but it was the first thing I noticed when i disassembled the laptop. However, I am still focused on finding the shorts.
      I searched online some information about the ICs on the board, looking for one that may be the culprit. I could not find anything related. However, I found the schematics (attached below) of another Lenovo notebook that uses the same audio codec (Realtek ALC3240). According to it, the IC is powered by +3VALW and +1.8VS (the Yoga 3 schematics had 1.5VS!). So it's probable that the resistor I found (2.2k) was the correct one.
      Also, this makes it a good candidate for shorts, since two of three rails converge there. I will check it better.
      • khaahk
        • Dec 2013
        • 764
        • Estonia
        I have a b921 on my table, check for +5v short (if you have one) on U52 and U2905. Also the npce388 might need to be programmed to function correctly if you resolve the shorts.
        • MichR
          • Jan 2016
          • 42
          • Italy
          No shorts on +5V, but I checked anyway - nothing. However, I found pins 1 and 4 of D45 are shorted to ground, so I decided to desolder it. Differently than Yoga 3, these are connected to a pair of differential lines, much probably U2DN1, U2DP1 (USB 2.0 pair) if I follow Yoga 3 schematics.
          I believe this is sufficient to state that CPU is the issue here. What do you think?
          • khaahk
            • Dec 2013
            • 764
            • Estonia
            if the diode is gone and usb data lines are short to gnd then sadly yes.
            • MichR
              • Jan 2016
              • 42
              • Italy
              That's a pity. Is there anything I could do? May a reflow be of any help?
              • khaahk
                • Dec 2013
                • 764
                • Estonia
                No, only change of cpu, but you don't know what else is burned on that mb. It is not reasonable to continue this repair.
                • Stevie2001
                  • Apr 2018
                  • 183
                  • irland
                  1: test the caps
                  2: test transistors
                  put black probe on gnd and use red on them pins if both side beeps its bad for caps.
                  transistors se if 3 legs short with gnd.
                  the mofsets look at the code google the datasheet and check the pins and ignore the gnd pins and test if other pins is short with gnd.
                  if you have dc power supply it will help to inject amps to find heat.
                  check dcin mofsets
                  JDCIN1
                  U2905
                  Q2421
                  PD103
                  PD105
                  PQ101
                  PQ102
                  PQ103
                    • 20795
                    @stevie2001 , if you take the time to read the whole thread you`ll see that the problem has nothing to do with the mosfets, its a different problem altogether, and...these guys know what they`re doing .
                    • MichR
                      • Jan 2016
                      • 42
                      • Italy
                      Thanks. A new CPU costs about 60USD, but I don't have the tools to replace it. I thought a reflow could have helped if the shorts are among BGA balls, but I cannot be sure. The only option left is to buy a new motherboard, which costs more than 150USD. In my opinion it's way too much for such a board.
                      I think I'll have to sell the whole laptop as is.
                      • piernov
                        • Jan 2016
                        • 4435
                        • France
                        Full short to ground are not caused by the solder balls but rather by the die itself that's internally shorted.
                        Better throw that motherboard in the trash.
                        • MichR
                          • Jan 2016
                          • 42
                          • Italy
                          Alright.
                          A last thought for whoever stumbles across this thread: Yoga 3 motherboard (LA-B921P) should be compatible with Yoga 700. Form factors look the same and connectors are disposed in the same positions (Yoga 700 - Yoga 3). Also, lower and upper cases, as well as all the daughter boards, are the same for both! (I checked in the maintenance manual).
                          Even if CPU is a bit worse in performance, it may give more runtime on battery since it's 5270mAh (Yoga 700) vs. 4650mAh (Yoga 3)
                          • tomodachi
                            • Apr 2012
                            • 602
                            • Turkey
                            Just in case if someone come across to similar case like 3VALW dead short, they can be sure they need a new board cuz their CPU is toasted.
                            • MichR
                              • Jan 2016
                              • 42
                              • Italy
                              Originally posted by MichR
                              Alright.
                              Here I am some months later. I finally bought a new Yoga 3 motherboard and replaced the old shorted one. I must tell you that:
                              - a Yoga 3 sensor board must be bought, otherwise the screen won't automatically rotate nor dim. This is mainly caused by the different accelerometer chip used in these two computers.
                              - the measured capacity of the battery is exactly the same specified in Yoga 3 battery, regardless of the extra available capacity of Yoga 700 battery.
                              Another issue is caused by WLAN whitelisting in BIOS. After some hours I came up with the attached modified BIOS. It is based on a clean BIOS file (extracted from the setup file from Lenovo website) and removes whitelist and the BIOS flash descriptor lock. The original BIOS had this lock which prevented flashing the BIOS via Intel FPT utility, so in order to flash the modified BIOS you must use a SPI programmer.
                              Included in the attached archive are the original BIOS and EC files.
                                Lenovo Yoga Yoga 6 13ALC7 Notebook Specification for Upgrade or Repair
                                This specification for the Lenovo Yoga Yoga 6 13ALC7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 6 13ALC7 boardview and Yoga 6 13ALC7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-07-2024, 05:00 AM
                                Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook 700 Specification for Upgrade or Repair
                                This specification for the Lenovo Yoga Yoga 7i (16? Intel) 2 in 1 Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Yoga 7i (16? Intel) 2 in 1 Laptop boardview and Yoga 7i (16? Intel) 2 in 1 Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                Lenovo Yoga X1 Yoga Gen 6 Hybrid (2-in-1) Specification for Upgrade or Repair
                                This specification for the Lenovo Yoga X1 Yoga Gen 6 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga Gen 6 boardview and X1 Yoga Gen 6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                Lenovo Yoga Yoga 6 13ALC7 Notebook 700 Specification for Upgrade or Repair
