hp g62-a46se cannot power on
  • BlueMidnight
    • Jan 2015
    • 489
    Re: hp g62-a46se cannot power on
    See if this schematic matches your board. If so, page 5 shows the power sequence. The steps are numbered in red. Measure each signal/rail in order until you find something that doesn't seem right. And then measure some more. Then post it all here.
    • gabiz_ro
      • Mar 2011
      • 171
      • Romania
      Bios chip is powered by +V3.3S from +V3.3A via PQ763
      +V3.3A is from +V3.3AL via PQ2
      +V3.3AL is enabled by EC_ALW_EN from EC
      +V3.3S is enabled by SLP_S3#_3R from MCH
      Schematic
      • String2016
        • Nov 2015
        • 2238
        • philippines
        thanks for the response and schematic meritosari but i checked on the pins of the power switch 3.3v is present but no voltages on the main bios chip.where should i check next please
        • String2016
          • Nov 2015
          • 2238
          • philippines
          thanks all for the response ill make a measurement and post it here
          • JaroTech
            • Mar 2015
            • 351
            Measure the voltages on PQ762.
            • String2016
              • Nov 2015
              • 2238
              • philippines
              #26
              Thanks for the response jarotech I have attached the image and measurement of the chip, I dont know which is the PQ762
              • JaroTech
                • Mar 2015
                • 351
                PQ762 is a 6-pin chip, you have three similar ones next to the SD card connector.
                • String2016
                  • Nov 2015
                  • 2238
                  • philippines
                  #28
                  thanks for the response jarotech already uploaded the image and measurements i dont know which is the pq762
                  • String2016
                    • Nov 2015
                    • 2238
                    • philippines
                    #29
                    anyone please help on this
                    • meritosari
                      • Oct 2010
                      • 774
                      • Indonesia
                      #30
                      You didn't reply what BlueMidnight's advise.
                      • String2016
                        • Nov 2015
                        • 2238
                        • philippines
                        #31
                        @meritosari i did not answer because some of the components i cannot find on the board.i have attached the image of pq762
                        • gabiz_ro
                          • Mar 2011
                          • 171
                          • Romania
                          #32
                          3 revision schematics and boardview
                          foxconn star federer.rar
                          Seems like "run_on_load" is 0V
                          Measure voltage on PQ779 (is 3 pin transistor,located on right top of white socket in photo) and PR765
                          Better look at photo
                          • meritosari
                            • Oct 2010
                            • 774
                            • Indonesia
                            #33
                            Thanks for boardview.
                            @string2016
                            just more info:
                            I think what BlueMidnight mean that you should make note like ex sequence already upload
                            • String2016
                              • Nov 2015
                              • 2238
                              • philippines
                              #34
                              thanks for the schematic and boardview PR765=10K ohms and PQ779 pin1 D=0V pin2 S=12.2V and pin3 G=12V. I noticed also that pq762 pin5 when touch by probe power led goes on and its connected to pin3 on the power switch and also checked PQ780 no voltage
                              • gabiz_ro
                                • Mar 2011
                                • 171
                                • Romania
                                #35
                                Check on PQ778 while pressing power
                                But I think "SLP_S3#_3R" is missing.
                                • String2016
                                  • Nov 2015
                                  • 2238
                                  • philippines
                                  #36
                                  thanks for the response gabiz i check pq778 pin1 d=12 when pressing power switch drops to 0v but laptop turns on fan at full speed but when i removed charger and plugged in again and try not turning on.by the way i when i switch i just short pin3 on the power switch because power button ribbon is broken
                                  • gabiz_ro
                                    • Mar 2011
                                    • 171
                                    • Romania
                                    #37
                                    When press power if PQ778 drops to 0 then in that time "run_on_load" must be around 10V
                                    As result in that time +V5S,+V3.3S and +V1.5_VDDQ are present.
                                    Check if are or not.
                                    • String2016
                                      • Nov 2015
                                      • 2238
                                      • philippines
                                      #38
                                      when i checked again the PQ778 tried to switch on this time from 12v when switch on to 10v then goes to 12v again
                                      • JaroTech
                                        • Mar 2015
                                        • 351
                                        What voltage do you have on the gate of PQ778?
                                        • String2016
                                          • Nov 2015
                                          • 2238
                                          • philippines
                                          #40
                                          thanks for the response jarotech on the source and gate of PQ778 there is 0v drain have 12v
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                            09-06-2024, 05:59 AM
                                            HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-12-2024, 02:15 PM
                                            HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation Specification for Upgrade or Repair
                                            This specification for the HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Power 15.6 inch G9 Mobile Workstation PC boardview and ZBook Power 15.6 inch G9 Mobile Workstation PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                                            09-07-2024, 05:20 AM
