Asus K53SD: short when chassis is closed
  • DS-1
    • Jun 2015
    • 82
    • Italy
    Hi guys,
    I've changed the DC jack to a K53SD Asus mb. The new DC jack is working good, but when I close the chassis of the notebook (the upper plastic part) nothing happens when I hit the button), while if I lift up the plastic, the button makes the notebook starts.
    What should I check according to your experience?
    Thanks!
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Asus K53SD: short when chassis is closed
    Does it apply enough pressure on the metal button when you press the plastic button?
    • DS-1
      • Jun 2015
      • 82
      • Italy
      This is not a question of pressure. If I sligthly lift it up and press the button, it turns on.
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        In addition, it is also possible that some metal section of the keyboard or the upper case makes contact with the mainboard. If so, cover it by some plastic tape. Probably, there is no other reason making such a short.
        • DS-1
          • Jun 2015
          • 82
          • Italy
          The issue was that the power button was covered with a conductive tape (it was used by Asus to put a part of the power button circuit to ground).
          I removed it and now it works fine.
          • OOF DIO
            ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
            by OOF DIO
            (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
            (Had 3 problems, now just 1)
            I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
            I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
            I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
            04-19-2025, 05:03 PM
          • jkucukov
            Asus ZenBook 13 UX333F External Short - Fast Battery Drain - Need Help
            by jkucukov
            I'm trying to see if someone could help me with my Asus Zenbook 13 UX 333F with given symptoms that I've experience during a recent external short.
            During last laptop charge, as I was moving the DC power supply, I caused the two leads (+ -) to touch. After that event the laptop stopped charging and pulling amps form the power supply. The only way the laptop will come on is with the power supply connected and the battery having some charge to it, battery drains immediately after short operation (it gets to Windows log in screen before it shuts off). The laptop would power on, show...
            02-05-2025, 09:27 PM
          • CICCIVALENTI
            Help ! ASUS K53SD ASUS REV.5
            by CICCIVALENTI
            Hello everyone, I'm writing here maybe someone will be able to help me, for two days I've been trying to repair a notebook (ASUS K53SD) without success. the PC turns on and the Asus logo appears but it doesn't go on, it doesn't enter the bios and it does nothing else. after having done numerous tests such as changing the ram hdd etc. I read somewhere that it could be the bios, I bought a programmer (ch341a with clip) but even by flashing memory I had no results, it remains on the Asus logo screen. I attached some photos. Thanks in advance
            12-15-2023, 09:52 AM
            ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
            This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
            09-07-2024, 02:50 AM
            ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
            This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
