Mosfet...
  • lorins_core
    BlackSmith
    • Dec 2012
    • 551
    • Philippines
    Mosfet...
    Have A Nice Day To All
    I have A Questions about this MOSFET
    A5 VNE - N Channel
    P0903BEA (A5 GND, A5 GNC, A5 VNE, A5 GNB) [DFN-8]
    Spec's:N-Channel Enhancement Mode MOSFET 30V 9mΩ 48A
    any brand Can Same Or can Substitute For This N Channel Mosfet
    TIA
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Mosfet...
    try AON7408
    https://cdn.badcaps-static.com/pdfs/...0d5f5f21e1.pdf
    • lorins_core
      BlackSmith
      • Dec 2012
      • 551
      • Philippines
      Re: Mosfet...
      Thanks for been there. i Appreciate your answer but can't turn on the System
      • dj8452000
        How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
        by dj8452000
        I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
        02-18-2025, 08:28 AM
      • tmaster21
        Ideapad 100 NM-A841, P channel mosfet on laptop in.
        by tmaster21
        Hello guys. i'm having problems here with this lenovo 110 with board NM-A841 laptop. There is an P channel(pq302) and after it i start ,i have 19v but with time, it decreases or if i press "power on" switch or jumper j6 , it falls to 0 and back to 19v. There is no short and works good on battery, but won't charge or charge until the voltage drop like i explain after P mosfet.
        Well i suspect that this mosfet is no good. if you look to skematic i have steady 19v on P2 but start to decrease on P3 like if the mosfet is dying . the gate of boot N an P mosfet are the same: is steady...
        07-17-2023, 09:48 AM
      • KABY
        bad P0903BEA mosfet compatibility
        by KABY
        hi i have one question about mosfet
        is it possible to change bad mosfet with other one from differente laptop !!!
        or its recommanded to replace it with identicale mosfet
        in my case i have bad P0903BEA mosfet
        thanks for accepting
        10-11-2023, 11:40 AM
      • eccerr0r
        old X58 triple channel board... memtest86 memory speed?
        by eccerr0r
        Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
        Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
        Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
        06-28-2025, 09:06 AM
      • Tarot Superstars
        Reading N-Channel Mosfet Junctions (1N65)
        by Tarot Superstars
        Hi.
        I have a Mosfet in a power adaptor circuit and I want to know what is the Gate, Drain and Source.
        I have a data sheet and it shows which is the gate (#1) and I assume 2 and 3 are Drain and Source.
        But when I read it with a multimeter I read that it's likely not that.
        It seems to show that wire 3 is the gate and the other two are drain and source.
        I want to know because I want to design tests on the mosfet to see if it is broken.
        However, the gate of U1 (the pulse width modulator) is connected to wire 1 indicating it IS the gate...
        09-27-2023, 01:46 PM
