Toshiba c55 charging issue
  • akande
    • Dec 2017
    • 278
    • Nigeria
    need help on this pc, toshiba c55 its not responding to charger \. have check the voltage there is 3.2v on battery terminal and other componet responsible for charging seem good pls help me out
  • flat-earther
    ASUS X54H laptop thinks it's always charging even with charger unplugged
    by flat-earther
    The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
    Windows also shows ''Plugged in'' when charger is not connected.
    This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
    Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
    If I let battery run out and say it has 3% Windows will...
    06-24-2025, 09:32 AM
  • Simone Vergani
    Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
    by Simone Vergani
    I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
    To assist with troubleshooting, I'm attaching two power circuit schematics:
    • Power
    03-05-2025, 02:25 PM
  • ahmarzo
    la-j081p charging issue
    by ahmarzo
    Have Dell la-j081p laptop with battery issue.
    First the laptop was not charging pqb25 was short after changing pqb25 and pqb26 the laptop starts charging and runs properly on charger but battery it shutdown after 10 seconds.
    And when powered on only on battery the laptop turns off after 8-10 second without giving display.have tried another battery on another working laptop and it's working fine
    I have changed charging ic and pqb25 ,pqb26 and pqb13.
    When adapter is disconnected the laptop stays on battery for 8-10 sec then abruptly shutdown everytime.
    This is the link...
    04-24-2025, 05:16 AM
  • DominikPechac
    MacBook Air A1466 820-00165 Charging Issue
    by DominikPechac
    I have a problem identifying a problem on this MacBook Air A1466 with board 820-00165.
    A customer came in with a problem, the laptop was not charging. Otherwise, it works fine - runs from a battery without an issue. The battery is original, the customer also provided his original charger.
    However, when I was diagnosing the issue, I turned the laptop off, checked the board, etc. When I put everything back together, the laptop was charging (I inserted the charger and then turned the laptop on). After unplugging the charger and plugging it back,...
    04-05-2024, 02:20 AM
  • shahnld
    Msi gs66 charging issue
    by shahnld
    Good Evening Masters..
    My msi gs66 has a weird issue. It had a shorted mosfet on vram rails and 1x current sense to gpu or vram was melted,. I replaced the mosfet and currenr sense resister and the laptop started to work,
    but When plugged in it says battery is 99% and as soon as i remove the charger the laptop shutsdown.. beside this issue laptop is fully functional.
    So i opened it and i checked voltage on battery +. Without charger in MV's, when i plug in the charger then voltage on battery+ connector goes to 19.75v and then starts to drop until MV's. This...
    01-26-2025, 05:13 PM
