HP CQ71;No LEDS except connector LED 6 sec.
  • patpin
    • Jun 2017
    • 19
    • luxemburg
    Hallo,
    I m checking a MOBO DA00P6MB6D0 rev D.
    With or without battery I see a Led coming ON at the ext. power connector when connecting it. After 6 seconds it goes OFF. No other LEDS ON; Pow butt does nothing.
    At the ext.DC IN connector:
    pin 3 =1,5V=also present when LED OFF
    Pin 4: 2,65V when LED ON ; otherwise 0V
    Can someone help me? Thanks
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Re: HP CQ71;No LEDS except connector LED 6 sec.
    check DC jack pins for being shorted.
    • khaahk
      • Dec 2013
      • 771
      • Estonia
      Try bios first.
      • patpin
        • Jun 2017
        • 19
        • luxemburg
        The S5_ON Doesnt come ON after pressing POW BUTTON. KBC death? How can I test?
        • patpin
          • Jun 2017
          • 19
          • luxemburg
          Not shorted; I have 19V at PQ48.
          • dycc
            Vision
            • Nov 2011
            • 625
            • Côte d'Ivoire
            Give bios pin 8 and pin 5 voltages ???????????
            Normally you should have 3.3v at pin 8 and 0.2 at pin 5
            • patpin
              • Jun 2017
              • 19
              • luxemburg
              Forgot to mention that the LED at the female external-PS-connector remains OFF. Havent found the label for that LED.
              I have charged the MBAT to 10.5V.
              Is correct 3.3V at 8; only 0,033 at pin 5. CMOS BATT+ is 2.96V
              The power button goes to 0V on pressing.
              The RSMRST# remains at 0V also on pressing.
              DNBSWON#1 measured on D18: is 3,35 and remains when pow.butt pressed (with DMM and Bitscope)
              LID_EC# is 3,3V so I guess this is an OPEN LID .
              I have 3.3V at KBC on PIN 67. KBC is not hot.
              I consume 10,48 mA; when I press power button: 10,55mA.
              • khaahk
                • Dec 2013
                • 771
                • Estonia
                You can make measurements until the end of time, try to reprogram bios at first. If no change then start to measure again.
                • patpin
                  • Jun 2017
                  • 19
                  • luxemburg
                  The problem is I have no programmer. On the other hand I have a scope. Do you have an idea on why PIN 5 of BIOS is so low ?
                  • khaahk
                    • Dec 2013
                    • 771
                    • Estonia
                    It is data line, so if no data or data is infrequent then multimeter shows mean value which is very low. If you have a scope then look if impulses are present on pin 2, 5, 6. But it still gives you nothing if you have no idea what data should be moving. Find a spi programmer if you want to move forward with repairing it.
                    • patpin
                      • Jun 2017
                      • 19
                      • luxemburg
                      OK. In the mean time can we look at the charger not functioning? charge led is OFF. BAT V remains 10.3V
                      PU5 has 5V on PIN 1;
                      ACSET (on the PR99): 2,09V
                      6251EN: (on the PR98): 1,15V
                      UGATE (on the PQ6 pin 4): 10V; no pulses; L gate 0V but no pulses (pin 4 on PQ4)
                      VREF PIN 8: 2,77V
                      Should receive CC-SET from KBC: I measure (on PR102): OV (I think it should be 1.2V)
                      Probably same cause: KBC not functioning?
                      • patpin
                        • Jun 2017
                        • 19
                        • luxemburg
                        Nobody an idea?
                        • JaroTech
                          • Mar 2015
                          • 351
                          Hi, what voltage do you have on pin 2 of PQ7 and pin 2 of PQ67?
                          • Tomylee
                            No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
                            by Tomylee
                            Sorry for the person who’s going to read all this !
                            I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
                            While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
                            During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
                            07-11-2025, 11:52 AM
                          • howardc64
                            by howardc64
                            Problem
                            08-04-2024, 10:36 PM
                          • 5mall5nail5
                            Help identifying connector for ASUS 4090 Strix RGB LED connector
                            by 5mall5nail5
                            Hi All -
                            I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
                            Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
                            05-04-2025, 07:47 AM
                          • Pipolups
                            Corsair K70 LUX RGB dying LEDs
                            by Pipolups
                            Hi there !
                            I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                            Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                            10-08-2024, 11:58 AM
                          • michhak
                            Toshiba Satellite M50-A keyboard connector on LA-A481P motherboard
                            by michhak
                            Hi guys,
                            i have a damaged keyboard connector on my older Toshiba Satellite M50-A laptop. I know there is LA-A481P motherboard. In attachment pictures there is a real looking connector and i also found a schematic to the connector. But i need help with finding a real electronic part to replace the damaged connector. e.g. on aliexpress (or different page).
                            It is 34pin connector and the length from pin n.1 to pin n.34 is 26mm. So it means a pitch length is 0.764 mm. I have seen connectors with 0.5mm , 0.7mm , 0.8mm and 1mm pitch length. But not with 0.75. Is it some special custom connector...
                            11-17-2021, 05:45 AM
