tps51225c issue
  • rookieme
    • Oct 2014
    • 397
    • Greece
    tps51225c issue
    I have a LA-9981p with liquid damage.
    The 5 and 3 V were missing and VIN pin at tps51225c was burned so I replaced the tps and connected the VIN line.
    Now the regulator is burning hot and I get no voltage at PL100 & PL101.
    So far I have removed kbc, all 4 upper & lower mosfets of tps51225c, open pads PJP100 - 103 and replaced again with a new regulator.
    The tps still burns hot, I get no short at VREG3 or VREG5 and I get the 3,2 and 5V stable at their pins.
    Anyone have an idea what to try?
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: tps51225c issue
    how much voltage is on Vin now?
    have you checked tps51225's pins for being shorted together or to ground?
    • rookieme
      • Oct 2014
      • 397
      • Greece
      Re: tps51225c issue
      vin = 17,4V
      So far I've checked all pins and there is non shorted to ground.
      From optical inspection non of them is shorted with the next one also
      What could cause tps to overheat as VREG3 & VREG5 are the only outputs now and non of them is shorted?
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        Re: tps51225c issue
        Vin may be still shorted.
        how much resistance-to-gnd is on Vin?
        is there any voltage on PL100 and PL101?
        • rookieme
          • Oct 2014
          • 397
          • Greece
          Re: tps51225c issue
          vin~ 73kohm
          PL100 & PL101 are both 0V as I have all four mosfet removed
          • caspian
            • Oct 2015
            • 1591
            • Laptop
            Re: tps51225c issue
            it is normal for tps51225 to get a bit warm.
            how much voltage is on DC-jack?
            • rookieme
              • Oct 2014
              • 397
              • Greece
              Re: tps51225c issue
              dc-jack gets 19,6 V
              tps51225 get hot enough so you cannot hold your finger on it, somehow it manages to get that way for a long time without get burned [gives stable 5V and 3V at VREG3 &5]
              • mielta
                • Apr 2015
                • 368
                Re: tps51225c issue
                Hi
                remove PL100 and PL101 und check short to ground
                give with a laboratory power supply 3v behind PL100 and check amp
                • rookieme
                  • Oct 2014
                  • 397
                  • Greece
                  Re: tps51225c issue
                  Even with both coils removed the regulator still run hot to touch.
                  Currently I don't have such power supply, the resistance to ground at the output of PL100 is 15 kohm but at PL101 is only 37 ohm.
                  The fact is that when I give power at that linw with the help of a l-ion battery nothing gets hot.
                  update:
                  I removed pu800 and it's upper mosfet any short at 5V line is gone
                  tps still runs hot
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Re: tps51225c issue
                    Try replacing ene 9012. Will require programming after install with programmer like RT809 or svod etc.
                    • caspian
                      • Oct 2015
                      • 1591
                      • Laptop
                      Re: tps51225c issue
                      I think you measured resistance-to-gnd on Vin by mistake. please measure it again to make sure.
                      if it did not solve the problem, the next step will be removing PL102. then check whether TPS gets hot or not. then, measure resistance-to-gnd on the two pads under PL102.
                      • OOF DIO
                        ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
                        by OOF DIO
                        (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
                        (Had 3 problems, now just 1)
                        I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
                        I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
                        I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
                        04-19-2025, 05:03 PM
                      • rounin
                        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                        by rounin
                        🛠 Original Issue
                        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                        04-19-2025, 01:18 AM
                      • ugamazing
                        by ugamazing
                        12-17-2024, 07:05 PM
                      • shahnld
                        Lenovo legion 5 pro startup issue
                        by shahnld
                        Good day Experts
                        I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                        A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                        And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                        08-24-2025, 12:31 PM
                      • ahmarzo
                        Acer laptop battery draining issue
                        by ahmarzo
                        Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                        Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                        08-02-2025, 06:39 AM
