tps51225c issue
  • rookieme
    • Oct 2014
    • 397
    • Greece
    tps51225c issue
    I have a LA-9981p with liquid damage.
    The 5 and 3 V were missing and VIN pin at tps51225c was burned so I replaced the tps and connected the VIN line.
    Now the regulator is burning hot and I get no voltage at PL100 & PL101.
    So far I have removed kbc, all 4 upper & lower mosfets of tps51225c, open pads PJP100 - 103 and replaced again with a new regulator.
    The tps still burns hot, I get no short at VREG3 or VREG5 and I get the 3,2 and 5V stable at their pins.
    Anyone have an idea what to try?
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Re: tps51225c issue
    how much voltage is on Vin now?
    have you checked tps51225's pins for being shorted together or to ground?
    • rookieme
      • Oct 2014
      • 397
      • Greece
      Re: tps51225c issue
      vin = 17,4V
      So far I've checked all pins and there is non shorted to ground.
      From optical inspection non of them is shorted with the next one also
      What could cause tps to overheat as VREG3 & VREG5 are the only outputs now and non of them is shorted?
      • caspian
        • Oct 2015
        • 1589
        • Laptop
        Re: tps51225c issue
        Vin may be still shorted.
        how much resistance-to-gnd is on Vin?
        is there any voltage on PL100 and PL101?
        • rookieme
          • Oct 2014
          • 397
          • Greece
          Re: tps51225c issue
          vin~ 73kohm
          PL100 & PL101 are both 0V as I have all four mosfet removed
          • caspian
            • Oct 2015
            • 1589
            • Laptop
            Re: tps51225c issue
            it is normal for tps51225 to get a bit warm.
            how much voltage is on DC-jack?
            • rookieme
              • Oct 2014
              • 397
              • Greece
              Re: tps51225c issue
              dc-jack gets 19,6 V
              tps51225 get hot enough so you cannot hold your finger on it, somehow it manages to get that way for a long time without get burned [gives stable 5V and 3V at VREG3 &5]
              • mielta
                • Apr 2015
                • 368
                Re: tps51225c issue
                Hi
                remove PL100 and PL101 und check short to ground
                give with a laboratory power supply 3v behind PL100 and check amp
                • rookieme
                  • Oct 2014
                  • 397
                  • Greece
                  Re: tps51225c issue
                  Even with both coils removed the regulator still run hot to touch.
                  Currently I don't have such power supply, the resistance to ground at the output of PL100 is 15 kohm but at PL101 is only 37 ohm.
                  The fact is that when I give power at that linw with the help of a l-ion battery nothing gets hot.
                  update:
                  I removed pu800 and it's upper mosfet any short at 5V line is gone
                  tps still runs hot
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Re: tps51225c issue
                    Try replacing ene 9012. Will require programming after install with programmer like RT809 or svod etc.
                    • caspian
                      • Oct 2015
                      • 1589
                      • Laptop
                      Re: tps51225c issue
                      I think you measured resistance-to-gnd on Vin by mistake. please measure it again to make sure.
                      if it did not solve the problem, the next step will be removing PL102. then check whether TPS gets hot or not. then, measure resistance-to-gnd on the two pads under PL102.
                      • OOF DIO
                        ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
                        by OOF DIO
                        (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
                        (Had 3 problems, now just 1)
                        I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
                        I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
                        I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
                        04-19-2025, 05:03 PM
                      • rounin
                        MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                        by rounin
                        🛠 Original Issue
                        ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                        04-19-2025, 01:18 AM
                      • ugamazing
                        by ugamazing
                        12-17-2024, 07:05 PM
                      • elmark
                        HP 15-cw1002ua strange keyboard issue
                        by elmark
                        HP Pavilion 15-CW1002UA
                        S/N 5CD0251CBC
                        P/N 7KE54EA
                        Hello guys!
                        I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                        It powers on OK and has no other issues except the following:
                        • CAPS LOCK does not work at all
                        • Fn button toggles Flight Mode
                        • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                        • (with SHIFT pressed: 't%' and 'y^' respectively)
                        I initially thought it was a keyboard malfunction (internal short, etc.),
                        but when I press and hold...
                        06-27-2025, 01:10 AM
                      • Simone Vergani
                        Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                        by Simone Vergani
                        I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                        To assist with troubleshooting, I'm attaching two power circuit schematics:
                        • Power
                        03-05-2025, 02:25 PM
