emachines d725 cannot turn on with power button
  • String2016
    • Nov 2015
    • 2229
    • philippines
    Re: emachines d725 cannot turn on with power button
    update done i replaced with different power switch board and make jumper form pin 7 and 8 and soldered on the switch and now i can turn on the laptop when i try before on the original switch board same issue original switch board is shorted. thanks again for the help and response friends
    • raajkumar
      • Mar 2015
      • 354
      • Srilanka
      Finally you won in this case. Good luck. But did you found the actual problem and which part has malfunctioned ?
      • themosttogain
        HP Envy 13-BA1565na with intermittent power button
        by themosttogain
        Hope someone can give me some suggestions on this because i'm at my wits end with it...
        I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
        Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
        07-12-2024, 03:03 AM
        ACER eMachines PT.NCAE2.071 eMachines EL1850 E5800 Specification for Upgrade or Repair
        This specification for the ACER eMachines PT.NCAE2.071 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the eMachines PT.NCAE2.071 boardview and eMachines PT.NCAE2.071 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
        09-12-2024, 03:36 PM
      • TimeRabbit07
        Asus FX517ZC charges but power button does nothing
        by TimeRabbit07
        Hi all!
        I've got an Asus FX517ZC on the bench at the moment and I just can't figure out what's going on with it.
        Here are its various numbers and identifiers:
        Model short: FX517Z
        Model long: FX517ZC-HN114W
        SN: NANRCX01S57842E
        CN: 3SDB 12M
        MFD: 2022-10
        Motherboard model: DA0NJLMBAE0 REV E
        Symptoms:
        The laptop's charge light comes on, but when the power on button is pressed nothing happens. No fan spin, no caps lock, no screen or keyboard backlight, nothing.
        History so far:
        The...
        09-04-2024, 05:48 PM
      • reessi
        Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
        by reessi
        With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
        No corrosion any where!
        Tried a replacement power button off ebay and the same.
        Very occasionally it will work with the power button connected!
        Same results with or without the battery.
        Can it be a fault with the Audio board or the mainboard?
        The touch Id assembly connects through the Audio board first then to the Mainboard.
        Flex...
        06-26-2024, 03:31 PM
      • x_orange90_x
        Seven Leagues Slot Machine stop button issues
        by x_orange90_x
        I don't know if anyone here has experience with Japanese slot (pachislo) machines, but I sure hope so. I bought this machine last week in semi-working order. It would play and the reels would spin, but the stop buttons would not stop them at all. I found that the high-frequency filtering tantalum capacitor was bad on the reel stop board, along with the fuse being blown. I replaced the fuse and removed the capacitor. I haven't replaced the cap yet because I didn't have one on hand, but it's not necessary for the operation of the machine.
        The issue now is the Stop buttons are intermittently...
        02-12-2025, 10:01 AM
