HP dv7-1245ef 1 blink every 3 seconds
  • piernov
    • Jan 2016
    • 4437
    • France
    This laptop has got a Compal LA-4083P motherboard, with a discrete GPU NVidia 9600M GT (G96-630-C1).
    When you turn it on, the fan spins, but nothing shows up on the screen. After about 10 seconds, the caps lock/num lock indicators start to blink every 3 seconds.
    Removing the RAM doesn't make a difference, I tried with another CPU and done a CMOS reset. I tried heating the GPU too, nothing changed.
    I still think the GPU is dead, what do you think?
  • fester
    • May 2017
    • 158
    • Slovakia
    Re: HP dv7-1245ef 1 blink every 3 seconds
    1 blink mean cpu not functional so meassure all cpu voltages first.Have you schematic for this board?
    • piernov
      • Jan 2016
      • 4437
      • France
      Thanks, CPU and GPU VCore were here, but I found +1.5VS and +VCCP shorted: southbridge partially shorted. I'm quite surprised to get VCore on a board with a half dead ICH, but that's how it is…
      Also there is a small bubble on the northbridge package. I guess someone was here before me and rehot the chips already…
      I'll try to solder a new ICH, but this board is probably beyond repair.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        Rare to see an ICH shorted indeed. This may be beyond economical repair if the Northbridge ends up being bad as well, chips can be scavenged from any old board as they rarely fail but the work hours you put into that won't pay off.
        A working TV? How boring!
        • piernov
          • Jan 2016
          • 4437
          • France
          Ok so the northbridge was dead too. Rather than spending 2 hours replacing both chips only to find out the GPU is dead as well or some other issue, I ordered another "working" motherboard. Obviously it didn't work. At least that one would be easy to fix, PQ402 shorted, and on top of that I've got a donor board. Not messing with it until I'm refunded though.
          • EbrahimSiami
            Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
            by EbrahimSiami
            I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
            **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
            **What I have tried so far:**
            1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
            07-02-2025, 02:31 PM
          • cloo
            Panasonic ZT60 plasma tv with strange behavior and 8 blink code
            by cloo
            I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
            It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
            So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
            After doing a factory reset this problem was gone and the picture was back to...
            01-06-2025, 06:02 AM
          • zklgfs
            Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
            by zklgfs
            I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
            08-11-2025, 02:14 PM
          • twonk9098
            Lenovo Legion 5 high fan spin turns off after 34 seconds
            by twonk9098
            I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
            I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
            I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
            I have tried a few new bios but exactly...
            07-14-2024, 11:19 AM
          • EazyBone
            Un50cu7000 2 blink oddity *partially solved
            by EazyBone
            I write this to maybe help another with this TV.
            So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
            The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
            03-18-2024, 10:24 PM
